Need help with a small HP LaserJet 1320 printer troubleshooting.
Auré -
jeannets Posted messages 28397 Registration date   Status Contributor Last intervention   -
Hello,
My HP Laserjet 1320 printer, which was working perfectly until now, no longer wants to print. One of the three lights on the printer (icon of a container with dots inside) is lit orange, and I don't know what that means. Can you help me? Thank you very much in advance.
Configuration: Windows 7 / Mozilla 11.0
  1. jeannets Posted messages 28397 Registration date   Status Contributor Last intervention   Ambassadeur 6 603
    Hello,
    It's probably the "Toner" that is empty... if I believe your description of the icon... A photo could confirm or deny this diagnosis..
    1. Auré
      Thank you very much Jeannets,
      What is toner? Does it mean we need to refill ink?
  2. jeannets Posted messages 28397 Registration date   Status Contributor Last intervention   Ambassadeur 6 603
    As its name suggests, it is a Laser printer, its full name should be "HP LaserJet 1320tn"...
    -- You don't put ink in these printers... because they don't print with ink...
    They print by burning a black powder deposited on the paper... This black powder is called 'Toner', located in a reservoir, it has a certain number of copies and then it needs to be replenished.
    If that's the problem..?? Lacking a photo, I can only guess.
    But normally there is a manual with the printer that explains the meaning of all these indicators.
