I can't write on PowerPoint anymore...
Solved
Floux812 Posted messages 4 Status Membre -
Hello everyone, I want to create a PowerPoint but I can't write any text in the boxes (my keyboard works just fine...)
Is there a special trick to do this (considering my PowerPoint is in English, I didn't want to go in blind!
Thanks in advance!
Se0x94 Posted messages 580 Registration date   Status Membre Last intervention   128
Yes, you just need to click on the text box. Insert > Text >
Text box
I love andouillette with mashed potatoes.
9
Floux812 Posted messages 4 Status Membre 4
Thank you Se0x94 for your response, but unfortunately, it does not work, the cursor blinks but when I try to write something, nothing happens :(
2
Mike-31 Posted messages 18405 Registration date   Status Contributeur Last intervention   5 145
Hi,
and in another application like Word, does your keyboard work properly?
Cheers
Mike-31
A period of failure is a perfect time to sow the seeds of knowledge.
2
Yes, it works very well!
I just turned off and on my Mac, and I can write in PowerPoint again!!
Thank you for your help, I don't know where the bug came from, the main thing is that everything is back to normal!
Have a very nice day!
2
Hello,
did you perhaps change the default font color by any chance!
try writing a piece of text and then try to highlight it as if you wanted to select it, the text area will take on a bluish color but if you have text it will be visible or the font color will change
and then you come back after the test
See you
Mike-31
Hello Mike-31!
Tested but it doesn't work, nothing is being typed, the cursor isn't moving, it's impossible to select anything because there's nothing to select... :/
