Bluetooth connection problem with car radio
julien -
tribun Posted messages 64900 Registration date   Status Member Last intervention   -
Hello,
I have the most basic Wiko and it won’t connect to my car radio from a Pioneer FH-X700BT; it tells me it needs a PIN code or that the access key is incorrect. Can someone help me
thanks
Configuration: iPhone / Chrome 28.0.1500.94
1 answer
  1. tribun Posted messages 64900 Registration date   Status Member Last intervention   12 687
    Hello
    You need to go to the menu of your Wiko and under connectivity enable Bluetooth and search for Bluetooth devices.
    If recognition is performed normally we enter the code 0000 or 1234 depending on the phone.
    Do you have the user manual for your Wiko? if yes! look inside.
    Who loves instruction! finds knowledge that comes from reflection!
    PS. Create a restore point often! it solves quite a few problems.
