Philips FWM377 HiFi System: sound issue
cavacestbonok Posted messages 21 Status Member -
Support Philips Posted messages 2396 Status Member -
Hello everyone!
This morning, when trying to turn it up louder, I heard a strange noise and now my speakers only work halfway. The speakers consist of two woofers. A big one and a small one on top. The big ones aren't working anymore, but the small ones are.
I've checked the connections, and they seem fine to me. Moreover, the fact that the small woofers work on both makes me think the connections are correct.
Does anyone have an idea what the problem might be?
Thanks in advance!!
  1. Char Snipeur Posted messages 10112 Registration date   Status Contributor Last intervention   1 331
    Hi.
    If the problem is indeed related to the increase, the cause is easily found: the fencing of the enclosures.
    Solution: buy others... AND stop pushing the sound so much.
    True submission is when the slaves worry about the price of cotton.
    Char Snipeur
    2
    1. Fermiparadox Posted messages 11515 Registration date   Status Member Last intervention   2 941
      And get speakers that can handle the power of the amplifier.
    2. Char Snipeur Posted messages 10112 Registration date   Status Contributor Last intervention   1 331
      Yes and no. The issue with amplifier potentiometers is that they are preamps whose sensitivity is poorly respected, which leads to the saturation of the power amp and the risk of damaging the speakers as well. :-(
      I need to find the link that explains all of this well.
  2. Support Philips Posted messages 2396 Status Member 554
    Dear Customer,
    We are sorry for the issues you have encountered with your mini-chain.
    We recommend that you check the following:
    - Adjust the volume.
    - Unplug the headphones.
    - Check if the speakers are properly
    connected.
    - Ensure that the exposed ends of the speaker wires are properly secured.
    - Make sure that the bitrate of the recorded MP3 CD is between 32 and 256 kbit/s with a sampling frequency of 48 kHz, 44.1 kHz, or 32 kHz.
    If you still encounter issues after this, we strongly advise you to contact one of our advisors at 0157324065 so that we can assist you.
    Sincerely,
    AB
    Philips France Advisor
    @PhilipsCare_FR
