Color issue in PDF conversion and printing
Eanil
Eanil -
Eanil -
Hello,
I am contacting you about a question that has been bothering me for quite some time.
I work in Illustrator CS5 (no images, just vector) and with CMYK documents.
I also use the basic CMYK palette.
These are therefore printable colors almost as they are if I'm not mistaken.
My problem is that when I want to convert it to PDF for printing (save as => PDF) with any settings (I've tried everything), sometimes it outputs colors that are totally different from what I had in Illustrator.
And this doesn’t happen all the time (even more surprisingly).
What is even more incomprehensible to me is that if I open this same PDF with strange colors on another PC, it shows the correct colors.
So I thought it was a problem with my Acrobat and that it would print correctly.
In the end, the printer printed everything with the wrong colors.
Another time, I directly gave the Illustrator file to the printer (digital printing and not offset), and he converted it to PDF himself, and once again it resulted in the wrong colors.
Do you know where the problem might come from?
As a reminder, my document is indeed in CMYK, and my colors are taken from the CMYK palette as well.
Thank you in advance!
Configuration: Windows 7 / Chrome 33.0.1750.154
- 1
- 2
Next
No printer has RGB ink (it doesn't exist)
Inks are necessarily CMYK, as color printing is done through subtractive mixing (httpt://www.newtone.fr/cours_colorimetrie_additif_soustractif.php)
Some consumer printers are called RGB and do their own little magic
Professional digital printers work with CMYK inks compliant with European standards (Euroscale)
They have RIPs (an element that converts the provided print files into a dot pattern applied to the photoreceptors of the printing engine)
Therefore, they do not convert anything unless the operator deliberately decides to, just like when adjusting the ink cartridges of an offset printer.
Basically, a screen (which has a color gamut, the ability to provide colors) much broader than a printer sends the colors directly to the eye (additive mixing) while a printed page reflects the part of the light determined by the pigments present on the paper (subtractive mixing)
This explains, among other things, why the color rendering of printed materials is completely different depending on ambient light.
A true printing professional will therefore work with RGB using the CMYK profile that corresponds to THEIR machine to achieve the best possible conversion.
Once the RGB to CMYK conversion has been made upstream, it is irreversible; you cannot return to RGB with the CMYK file to make a better conversion.
Those who want to work with CMYK files (necessarily created with a profile somewhere in the graphic chain) do not actually understand the processing of a digital workflow and shift the blame for poor color quality by saying "it's your file that is bad"
Photoshop, for example, uses US standard CMYK inks (swop) by default, which produce prints that are too dark on a press with Euroscale inks.
Oh dear, I see that the problem (printing what I have on the screen) is still so delicate to solve.
A good solution is to create your own "proofs" on a personal inkjet printer.
Don't laugh, you can achieve very good results by calibrating your screen with a probe and having print profiles created for your printer (and paper) by specialized companies like the excellent Christophe Métairie
You send him a print of test charts made with your equipment, and he creates a profile by analyzing this print with a spectrophotometer
http://www.cmp-color.fr/Imprimante.html
- 1
- 2
Next
