Samsung tablet not charging: red cross on battery
Solved
mumu3008 Posted messages 2 Status Member -
 Marie -
Hello
I have a Samsung Galaxy Tab 2 10.1. I'm having problems when I charge it
I changed the charger and the cable. I got a Samsung one and it worked very well for a few days, but today when I plug the tablet in to recharge, the charging keeps cutting in and out (when I plug it in, the battery lights up, there’s a beep, the battery turns off, there’s a beep, the battery lights up............)
I have a second brand-new Samsung charger and a new (non-branded) cable. In order for it to work, I have to plug the cable in when the tablet is off; otherwise, I get a red cross on the battery. The charging takes a very long time. The tablet does not charge if it is on, and if it discharges too much, it won’t turn back on for 2 days...
If anyone can explain what’s happening and what I should do to make it work properly
Thank you
  1. pograve Posted messages 703 Registration date   Status Member Last intervention   139
    I recently had a problem with that!
    I tinkered with the cable that I made myself
    if you’re interested, I’ll post the pinout diagram
    in any case, it charges now with any block (original or not).
    66
    1. Laflame
      I would like this diagram... thank you.
      1. pograve Posted messages 703 Registration date   Status Member Last intervention   139 > Laflame
        Good evening
        Here is a detailed diagram I made for you
        I placed the tablet so you can clearly locate the top side of the connector
        Best regards
    2. paquito34 Posted messages 28 Status Member
      thank you
    3. paquito34 Posted messages 28 Status Member
      I rewired the cable too, and it worked for a while, then I took apart the tablet to examine the connection plug closely to see if there were any defects, and there aren't any defects... I'm still searching...
    4. paquito34 Posted messages 28 Status Member
      I think about a communication problem.
      I plug and unplug and after a while it ends up working.
      Good luck.
