How to reset Philips hi-fi system?
alexalex38 Posted messages 11 Status Member -
Bonjour, I would like to know how to reset my Philips MCM275 hi-fi system? It no longer reads the CDs inside... Thank you.
  1. sawsix Posted messages 4824 Registration date   Status Member Last intervention   1 036
    You take a cotton swab and you soak it in demineralized water (definitely do not use bottled water or tap water, nor any other liquid product!!! Only demineralized water!! It's the water we put in steam irons ;)
  2. alexalex38 Posted messages 11 Status Member 1
    I've already tried, but it's still not working. I think it needs to be reset because this problem appeared right after I plugged my phone into the USB ... Thanks anyway :)
