No color on TV via SCART
Solved
kris22170 Posted messages 184 Status Member -
Hello,
for a few days now I haven't had color on a TV in a room that is connected to another TV in another room (same images of course).
It's a 10-meter Scart cable (the image is satisfactory).
If someone can tell me, before I open the socket, what the pin number is.
Thank you in advance.
  1. kris22170 Posted messages 184 Status Member 24
    Hello and thank you for your response.
    Here is what I found on the internet
    [URL=http://imageshack.com/f/1qprisepritel3j][IMG]http://img62.imageshack.us/img62/5945/prisepritel3.jpg[/IMG][/URL]
    But I couldn't find the list of colors that I have on my socket.
    Are there different colors depending on the brands of cable?
    Thank you and talk to you later, I hope.
  2. STARGATE43 Posted messages 13754 Registration date   Status Contributor Last intervention   2 648
    Hello Kris, I don't think there are predefined color codes for SCART cables. I just opened 2 at home, and unfortunately, it's not standardized. I’ll show you in a picture the colors used for these 2 cables:
    --> http://hpics.li/4af9a12
    Here are these 2 SCART connectors. I think that from one manufacturer to another, the colors change; that's all I can tell you about this topic.
    Best regards.
    No problem, only... solutions!!! :-)
    IF YOU FEEL YOUR ISSUE IS RESOLVED, PLEASE MARK IT AS SUCH, THANK YOU.
  3. kris22170 Posted messages 184 Status Member 24
    Thank you STARGATE43 for your help
    You just ruined my hope. I think I'm going to have to change the cable. It's not too much for the price, around €25 to €30, but it's for the installation of the cable.
    Thanks again.
  4. STARGATE43 Posted messages 13754 Registration date   Status Contributor Last intervention   2 648
    Sorry to disappoint you Kris, and again, I've only shown you 2 different cables ;-)
    As for the price, given the arrival of HDMI, SCART cables are even cheaper than that.
    Best regards and have a great weekend ;-)
    No problem, just... solutions!!! :-)
    IF YOU BELIEVE YOUR ISSUE IS RESOLVED, PLEASE MARK IT AS SUCH, THANK YOU.
  5. kris22170 Posted messages 184 Status Member 24
    You're welcome.
