Problem to activate the Fujitsu Siemens wifi
waleed
Stemib Posted messages 4 Status Member -
Hello,
Voile my concern and I can’t get the wifi to activate on my laptop. It’s a Fujitsu Siemens Esprimo Mobile V6535, it runs Windows 7, it’s a Pentium dual-core i...
It was under Vista, everything worked, and pressing FN-F1 turns on the wifi. Since the Windows 7 update, everything works fine except the wifi; it won’t activate.
With an Ethernet cable it works, and without it it shows that the wifi card (the driver and Qualcomm Atheros AR5007EG Wireless Network Adapter) is not active. I did a update with Driver Genius Pro and nothing works.
If someone has a trick or a solution, I’ll take it.
Thanks for your answers
Configuration: Windows 7 / Internet Explorer 9.0
1 answer
Good evening,
go to: Control Panel\All Control Panel Items\Network and Sharing Center and click on the option at the top left "change adapter settings", then right-click on "Wireless Network Connection" and enable it-
Hello,
I have exactly the same problem with a Fujitsu Siemens esprimo, running Vista, unable to connect to wifi while the Ethernet connection works fine! I looked for Network and Sharing Center in Control Panel\All Control Panels but there isn't! There’s Security Center, or Network Connections, or Wireless Network Setup Wizard, but no trace of "change adapter settings".
If you have a solution I’m all ears. ;)
