Audio issue with an ion usb turntable
cepawam
solersa -
solersa -
Hello,
I have an ION TTUSB10 turntable that I connect to the USB port of my PC, but there is no sound!
In fact, if I want to listen to music from my PC while the turntable is connected, there is no sound. I have to close the program (e.g.: iTunes), unplug the USB, and reopen the program to get sound. All of this happens on Windows XP Pro. There are no problems on Vista!
I used this turntable without any issues by following the manual:
CHOOSE AN OPTION OTHER THAN "USB AUDIO CODEC" from audio in "sounds" audio" in the control panel.
I selected: REALTEK AC97 AUDIO with my XP
NO PROBLEMS afterwards; I can listen to the music before importing it and also while importing it.
Before burning, I check that I haven't deleted the correct line (song name). Speaker icon: OK
Exclamation point icon: deleted; in this case, you need to redo the import of this song to maintain the correct conversion.
During conversions, do not stop the device or click elsewhere unexpectedly. -
Check your audio settings, both with the outputs and inputs you are using. Have you installed the driver for the turntable?
New update! This time it's working, the problem is that it only works when I reinstall the CD. But unfortunately, I have to do it every time I turn off the PC...
