No radio on TNT sat with Strong SRT
BONOBO -
 steph -
Hello,
I just replaced Canalsat with TNTsat using a Strong SRT 7400, but I am not receiving the 40 French radio channels and the few additional TV channels such as Euronews and TV5Monde, for example.
It is stated on the website tntsat.tv
Thank you in advance for your help.
  1. geotrouvetout
    page 7 of the manual...
    5.2.2 Adjusting the Channels
    This menu allows you to configure the clear satellite channels in different modes.
    Satellite: specify the name of the satellite.
    Converter type: Indicate the type of frequency converter used. To change the converter settings, press OK after highlighting this item. For more details on configuring converters, (see LNB regulation 5.2.3)
    Repeater: highlight the item and press OK. The list of repeaters appears on the right side of the screen. You can use a repeater to check the signal strength and quality of reception. The list of repeaters contains the predefined devices.
    Once all settings are configured, you can start the channel search.
    Press the RED button to configure the clear channels of all the transponders of the satellite.
    2
  2. Anonymous user
    There is an additional installation to be done.
    I can't remember the command, but it's listed in the menu and it's not automatic.
    1. jey
      Hi
      in case there is no radio reception, you just need to reset the decoder to factory settings and redo the basic searches.
      remember to turn off your decoder at night to receive updates.
      jey
    2. steph
      Hello, I tried to set it up as you said but I'm not able to...
      I made the changes but I still don't have any radios...
