192.168.1.1 [ seulement l'aide de la box ]
sandjay974
guigui2512 Posted messages 1243 Registration date Status Member Last intervention -
Hello
For some time now I haven't been able to access the page http://192.168.1.1/ which normally shows me my router's page.
In trying to solve the problem I (unfortunately modified) my IP to see if it would work, so I set it to: 192.168.1.10
but still nothing! So I wanted to reset the previous IP address by checking the automatic box.
Now nothing works! I think it stayed on 192.168.1.10 but it doesn't work!
I have a only box, a bewan my computer is connected to the box by an ethernet cable,
maybe you will need this: [URL=http://www.monsterup.com][IMG]http://www.monsterup.com/upload/1255107846340.jpg[/IMG][/URL]
if you could tell me the procedures to follow,
if you need any other details!
don't hesitate!
Thank you in advance!
don't hesitate!
Configuration: Windows Vista Firefox 3.0.14
You have several network connections... a connection to the local network and a tunnel connection. You use the local network connection because the tunnel is a card for a private network.
The default gateway should not be the same as your IP...
Normally it is 192.168.1.1. -
You go to the control panel, network connection. You double-click on your connection, properties, scroll down to Internet Protocol (TCP/IP), double-click on it, and in both tabs, you should check, obtain an IP address automatically, and Automatic private IP address...
Is everything in place? -
Well, that's weird... Is it not a problem with your box? Are your wires properly connected?
Yes, I also find it weird!
Yes, all the cables are properly connected!
Everything was working fine before. -
Try rebooting your box for 5 seconds.
do not turn off for 5 seconds and then reconnect
To access your connection settings (e.g., 192.168.1.1), it's the same address as the default gateway...
Have a good day -
Check resolved next to your first message to say that the discussion is closed
Good evening
