Installation de atm impossible sur Gentoo
A chaque fois que je lance "emerge linux-atm" je reçois le code suivant:
localhost ~ # emerge linux-atm
Calculating dependencies... done!
>>> Verifying ebuild Manifests...
>>> Emerging (1 of 1) net-dialup/linux-atm-2.4.1-r2 to /
* linux-atm-2.4.1.tar.gz RMD160 SHA1 SHA256 size ;-) ... [ ok ]
* checking ebuild checksums ;-) ... [ ok ]
* checking auxfile checksums ;-) ... [ ok ]
* checking miscfile checksums ;-) ... [ ok ]
* checking linux-atm-2.4.1.tar.gz ;-) ... [ ok ]
>>> Unpacking source...
>>> Unpacking linux-atm-2.4.1.tar.gz to /var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work
* Applying linux-atm-2.4.1-gcc4.patch ... [ ok ]
* Applying linux-atm-2.4.1-declarations.patch ... [ ok ]
* Running elibtoolize in: linux-atm-2.4.1
* Applying install-sh-1.5.patch ...
* Applying ltmain-1.5.patch ...
* Applying portage-1.5.10.patch ...
* Applying relink-1.4.1.patch ...
* Applying sed-1.5.6.patch ...
* Applying uclibc-conf-1.2.0.patch ...
>>> Source unpacked.
>>> Compiling source in /var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1 ...
* econf: updating linux-atm-2.4.1/config.sub with /usr/share/gnuconfig/config.sub
* econf: updating linux-atm-2.4.1/config.guess with /usr/share/gnuconfig/config.guess
./configure --prefix=/usr --host=x86_64-pc-linux-gnu --mandir=/usr/share/man --infodir=/usr/share/info --datadir=/usr/share --sysconfdir=/etc --localstatedir=/var/lib --libdir=/usr/lib64 --build=x86_64-pc-linux-gnu
creating cache ./config.cache
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking build system type... x86_64-pc-linux-gnu
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... missing
checking for working autoconf... found
checking for working automake... missing
checking for working autoheader... found
checking for working makeinfo... found
checking for gcc... gcc
checking whether the C compiler (gcc -O2 -pipe -fno-strict-aliasing ) works... yes
checking whether the C compiler (gcc -O2 -pipe -fno-strict-aliasing ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking how to run the C preprocessor... gcc -E
checking for flex... flex
checking for flex... (cached) flex
checking for yywrap in -lfl... no
checking lex output file root... lex.yy
checking whether yytext is a pointer... no
checking for bison... bison -y
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for ld used by GCC... /usr/x86_64-pc-linux-gnu/bin/ld
checking if the linker (/usr/x86_64-pc-linux-gnu/bin/ld) is GNU ld... yes
checking for /usr/x86_64-pc-linux-gnu/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependant libraries... file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )
checking for object suffix... o
checking for executable suffix... no
checking command to parse /usr/bin/nm -B output... ok
checking for dlfcn.h... yes
checking for file... /usr/bin/file
checking for ranlib... ranlib
checking for strip... strip
checking for objdir... .libs
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.lo... yes
checking if gcc supports -fno-rtti -fno-exceptions... yes
checking whether the linker (/usr/x86_64-pc-linux-gnu/bin/ld) supports shared libraries... yes
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking if libtool supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
creating libtool
checking for perl... /usr/bin/perl
checking for asm/errno.h... yes
checking for linux/atmsap.h... yes
checking for main in -lresolv... yes
updating cache ./config.cache
creating ./config.status
creating Makefile
creating doc/Makefile
creating m4/Makefile
creating src/Makefile
creating src/include/Makefile
creating src/lib/Makefile
creating src/test/Makefile
creating src/debug/Makefile
creating src/qgen/Makefile
creating src/saal/Makefile
creating src/sigd/Makefile
creating src/maint/Makefile
creating src/arpd/Makefile
creating src/ilmid/Makefile
creating src/ilmid/asn1/Makefile
creating src/man/Makefile
creating src/led/Makefile
creating src/lane/Makefile
creating src/mpoad/Makefile
creating src/switch/Makefile
creating src/switch/debug/Makefile
creating src/switch/tcp/Makefile
creating src/config/Makefile
creating src/config/init-redhat/Makefile
creating src/extra/Makefile
creating src/extra/linux-atm.spec
creating src/extra/ANS/Makefile
creating config.h
make all-recursive
make[1]: Entering directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1'
Making all in m4
make[2]: Entering directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/m4'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/m4'
Making all in src
make[2]: Entering directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/src'
Making all in include
make[3]: Entering directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/src/include'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/src/include'
Making all in lib
make[3]: Entering directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/src/lib'
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2atm.c
mkdir .libs
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2atm.c -fPIC -DPIC -o .libs/text2atm.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2atm.c -o text2atm.o >/dev/null 2>&1
mv -f .libs/text2atm.lo text2atm.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c atm2text.c
rm -f .libs/atm2text.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c atm2text.c -fPIC -DPIC -o .libs/atm2text.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c atm2text.c -o atm2text.o >/dev/null 2>&1
mv -f .libs/atm2text.lo atm2text.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c atmequal.c
rm -f .libs/atmequal.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c atmequal.c -fPIC -DPIC -o .libs/atmequal.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c atmequal.c -o atmequal.o >/dev/null 2>&1
mv -f .libs/atmequal.lo atmequal.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sdu2cell.c
rm -f .libs/sdu2cell.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sdu2cell.c -fPIC -DPIC -o .libs/sdu2cell.lo
sdu2cell.c: In function 'sdu2cell':
sdu2cell.c:21: warning: pointer targets in passing argument 5 of 'getsockopt' differ in signedness
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sdu2cell.c -o sdu2cell.o >/dev/null 2>&1
mv -f .libs/sdu2cell.lo sdu2cell.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2qos.c
rm -f .libs/text2qos.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2qos.c -fPIC -DPIC -o .libs/text2qos.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2qos.c -o text2qos.o >/dev/null 2>&1
mv -f .libs/text2qos.lo text2qos.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c qos2text.c
rm -f .libs/qos2text.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c qos2text.c -fPIC -DPIC -o .libs/qos2text.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c qos2text.c -o qos2text.o >/dev/null 2>&1
mv -f .libs/qos2text.lo qos2text.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c qosequal.c
rm -f .libs/qosequal.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c qosequal.c -fPIC -DPIC -o .libs/qosequal.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c qosequal.c -o qosequal.o >/dev/null 2>&1
mv -f .libs/qosequal.lo qosequal.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sap2text.c
rm -f .libs/sap2text.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sap2text.c -fPIC -DPIC -o .libs/sap2text.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sap2text.c -o sap2text.o >/dev/null 2>&1
mv -f .libs/sap2text.lo sap2text.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2sap.c
rm -f .libs/text2sap.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2sap.c -fPIC -DPIC -o .libs/text2sap.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2sap.c -o text2sap.o >/dev/null 2>&1
mv -f .libs/text2sap.lo text2sap.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sapequal.c
rm -f .libs/sapequal.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sapequal.c -fPIC -DPIC -o .libs/sapequal.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c sapequal.c -o sapequal.o >/dev/null 2>&1
mv -f .libs/sapequal.lo sapequal.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c misc.c
rm -f .libs/misc.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c misc.c -fPIC -DPIC -o .libs/misc.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c misc.c -o misc.o >/dev/null 2>&1
mv -f .libs/misc.lo misc.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c ans.c
rm -f .libs/ans.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c ans.c -fPIC -DPIC -o .libs/ans.lo
ans.c: In function 'ans':
ans.c:65: warning: pointer targets in passing argument 4 of '__dn_expand' differ in signedness
ans.c:80: warning: pointer targets in passing argument 4 of '__dn_expand' differ in signedness
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c ans.c -o ans.o >/dev/null 2>&1
mv -f .libs/ans.lo ans.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c common.c
rm -f .libs/common.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c common.c -fPIC -DPIC -o .libs/common.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c common.c -o common.o >/dev/null 2>&1
mv -f .libs/common.lo common.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c diag.c
rm -f .libs/diag.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c diag.c -fPIC -DPIC -o .libs/diag.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c diag.c -o diag.o >/dev/null 2>&1
mv -f .libs/diag.lo diag.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c kptr.c
rm -f .libs/kptr.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c kptr.c -fPIC -DPIC -o .libs/kptr.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c kptr.c -o kptr.o >/dev/null 2>&1
mv -f .libs/kptr.lo kptr.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2ip.c
rm -f .libs/text2ip.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2ip.c -fPIC -DPIC -o .libs/text2ip.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c text2ip.c -o text2ip.o >/dev/null 2>&1
mv -f .libs/text2ip.lo text2ip.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c timer.c
rm -f .libs/timer.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c timer.c -fPIC -DPIC -o .libs/timer.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c timer.c -o timer.o >/dev/null 2>&1
mv -f .libs/timer.lo timer.lo
/bin/sh ../../libtool --mode=compile gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c unix.c
rm -f .libs/unix.lo
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c unix.c -fPIC -DPIC -o .libs/unix.lo
unix.c: In function 'un_recv_connect':
unix.c:70: warning: pointer targets in passing argument 6 of 'recvfrom' differ in signedness
unix.c: In function 'un_recv':
unix.c:81: warning: pointer targets in passing argument 6 of 'recvfrom' differ in signedness
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c unix.c -o unix.o >/dev/null 2>&1
mv -f .libs/unix.lo unix.lo
/bin/sh ../../libtool --mode=link gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -version-info 1:0:0 -o libatm.la -rpath /usr/lib64 text2atm.lo atm2text.lo atmequal.lo sdu2cell.lo text2qos.lo qos2text.lo qosequal.lo sap2text.lo text2sap.lo sapequal.lo misc.lo ans.lo common.lo diag.lo kptr.lo text2ip.lo timer.lo unix.lo -lresolv
rm -fr .libs/libatm.la .libs/libatm.* .libs/libatm.*
gcc -shared text2atm.lo atm2text.lo atmequal.lo sdu2cell.lo text2qos.lo qos2text.lo qosequal.lo sap2text.lo text2sap.lo sapequal.lo misc.lo ans.lo common.lo diag.lo kptr.lo text2ip.lo timer.lo unix.lo -lresolv -Wl,-soname -Wl,libatm.so.1 -o .libs/libatm.so.1.0.0
(cd .libs && rm -f libatm.so.1 && ln -s libatm.so.1.0.0 libatm.so.1)
(cd .libs && rm -f libatm.so && ln -s libatm.so.1.0.0 libatm.so)
ar cru .libs/libatm.a text2atm.o atm2text.o atmequal.o sdu2cell.o text2qos.o qos2text.o qosequal.o sap2text.o text2sap.o sapequal.o misc.o ans.o common.o diag.o kptr.o text2ip.o timer.o unix.o
ranlib .libs/libatm.a
creating libatm.la
(cd .libs && rm -f libatm.la && ln -s ../libatm.la libatm.la)
make[3]: Leaving directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/src/lib'
Making all in test
make[3]: Entering directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/src/test'
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c aread.c
/bin/sh ../../libtool --mode=link gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o aread aread.o ../../src/lib/libatm.la
mkdir .libs
gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o .libs/aread aread.o ../../src/lib/.libs/libatm.so -lresolv -Wl,--rpath -Wl,/usr/lib64
creating aread
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c awrite.c
/bin/sh ../../libtool --mode=link gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o awrite awrite.o ../../src/lib/libatm.la
gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o .libs/awrite awrite.o ../../src/lib/.libs/libatm.so -lresolv -Wl,--rpath -Wl,/usr/lib64
creating awrite
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c ttcp.c
ttcp.c:164: warning: function declaration isn't a prototype
ttcp.c:165: warning: function declaration isn't a prototype
ttcp.c:166: warning: function declaration isn't a prototype
ttcp.c:167: warning: function declaration isn't a prototype
ttcp.c:168: warning: function declaration isn't a prototype
ttcp.c:169: warning: function declaration isn't a prototype
ttcp.c:170: warning: function declaration isn't a prototype
ttcp.c:171: warning: function declaration isn't a prototype
ttcp.c:172: warning: function declaration isn't a prototype
ttcp.c:173: warning: function declaration isn't a prototype
ttcp.c:174: warning: function declaration isn't a prototype
ttcp.c:175: warning: function declaration isn't a prototype
ttcp.c:176: warning: function declaration isn't a prototype
ttcp.c:177: warning: function declaration isn't a prototype
ttcp.c:181: warning: function declaration isn't a prototype
ttcp.c:190: warning: return type defaults to 'int'
ttcp.c:190: warning: function declaration isn't a prototype
ttcp.c: In function 'main':
ttcp.c:291: warning: passing argument 2 of 'strtoul' from incompatible pointer type
ttcp.c:281: warning: suggest explicit braces to avoid ambiguous 'else'
ttcp.c:368: warning: cast from pointer to integer of different size
ttcp.c:423: warning: pointer targets in passing argument 5 of 'getsockopt' differ in signedness
ttcp.c:432: warning: pointer targets in passing argument 5 of 'getsockopt' differ in signedness
ttcp.c:441: warning: pointer type mismatch in conditional expression
ttcp.c:459: warning: pointer type mismatch in conditional expression
ttcp.c:488: warning: passing argument 2 of 'accept' from incompatible pointer type
ttcp.c:488: warning: pointer targets in passing argument 3 of 'accept' differ in signedness
ttcp.c:495: warning: passing argument 2 of 'getpeername' from incompatible pointer type
ttcp.c:495: warning: pointer targets in passing argument 3 of 'getpeername' differ in signedness
ttcp.c:648: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int'
ttcp.c:652: warning: format '%#x' expects type 'unsigned int', but argument 4 has type 'char *'
ttcp.c: At top level:
ttcp.c:663: warning: function declaration isn't a prototype
ttcp.c:677: warning: function declaration isn't a prototype
ttcp.c:688: warning: return type defaults to 'int'
ttcp.c:688: warning: function declaration isn't a prototype
ttcp.c:702: warning: function declaration isn't a prototype
ttcp.c:765: warning: function declaration isn't a prototype
ttcp.c:775: warning: function declaration isn't a prototype
ttcp.c:796: warning: function declaration isn't a prototype
ttcp.c: In function 'prusage':
ttcp.c:819: warning: assignment discards qualifiers from pointer target type
ttcp.c:829: warning: format '%d' expects type 'int', but argument 3 has type '__time_t'
ttcp.c:829: warning: format '%01d' expects type 'int', but argument 4 has type '__suseconds_t'
ttcp.c:835: warning: format '%d' expects type 'int', but argument 3 has type '__time_t'
ttcp.c:835: warning: format '%01d' expects type 'int', but argument 4 has type '__suseconds_t'
ttcp.c:857: warning: format '%d' expects type 'int', but argument 3 has type 'long int'
ttcp.c:863: warning: format '%d' expects type 'int', but argument 3 has type 'long int'
ttcp.c:870: warning: format '%d' expects type 'int', but argument 3 has type 'long int'
ttcp.c:875: warning: format '%d' expects type 'int', but argument 3 has type 'long int'
ttcp.c:880: warning: format '%d' expects type 'int', but argument 3 has type 'long int'
ttcp.c:885: warning: format '%d' expects type 'int', but argument 3 has type 'long int'
ttcp.c:890: warning: format '%d' expects type 'int', but argument 3 has type 'long int'
ttcp.c:895: warning: format '%d' expects type 'int', but argument 3 has type 'long int'
ttcp.c:900: warning: format '%d' expects type 'int', but argument 3 has type 'long int'
ttcp.c:900: warning: format '%d' expects type 'int', but argument 4 has type 'long int'
ttcp.c:911: warning: function declaration isn't a prototype
ttcp.c:926: warning: function declaration isn't a prototype
ttcp.c:939: warning: function declaration isn't a prototype
ttcp.c:965: warning: return type defaults to 'int'
ttcp.c:965: warning: function declaration isn't a prototype
ttcp.c: In function 'Nread':
ttcp.c:965: warning: declaration of 'fd' shadows a global declaration
ttcp.c:93: warning: shadowed declaration is here
ttcp.c:966: warning: declaration of 'buf' shadows a global declaration
ttcp.c:96: warning: shadowed declaration is here
ttcp.c:970: warning: unused variable 'len'
ttcp.c:1001: warning: return type defaults to 'int'
ttcp.c:1001: warning: function declaration isn't a prototype
ttcp.c: In function 'Nwrite':
ttcp.c:1001: warning: declaration of 'fd' shadows a global declaration
ttcp.c:1002: warning: declaration of 'buf' shadows a global declaration
ttcp.c:1010: warning: passing argument 5 of 'sendto' from incompatible pointer type
ttcp.c:1027: warning: function declaration isn't a prototype
ttcp.c: In function 'delay':
ttcp.c:1032: warning: passing argument 2 of 'select' from incompatible pointer type
ttcp.c:1032: warning: passing argument 3 of 'select' from incompatible pointer type
ttcp.c:1032: warning: passing argument 4 of 'select' from incompatible pointer type
ttcp.c:1046: warning: function declaration isn't a prototype
ttcp.c: In function 'mread':
ttcp.c:1046: warning: declaration of 'fd' shadows a global declaration
ttcp.c: In function 'pattern':
ttcp.c:697: warning: control reaches end of non-void function
ttcp.c:48: warning: 'RCSid' defined but not used
/bin/sh ../../libtool --mode=link gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o ttcp_atm ttcp.o ../../src/lib/libatm.la
gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o .libs/ttcp_atm ttcp.o ../../src/lib/.libs/libatm.so -lresolv -Wl,--rpath -Wl,/usr/lib64
creating ttcp_atm
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c align.c
/bin/sh ../../libtool --mode=link gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o align align.o ../../src/lib/libatm.la
gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o .libs/align align.o ../../src/lib/.libs/libatm.so -lresolv -Wl,--rpath -Wl,/usr/lib64
creating align
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c aping.c
/bin/sh ../../libtool --mode=link gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o aping aping.o ../../src/lib/libatm.la
gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o .libs/aping aping.o ../../src/lib/.libs/libatm.so -lresolv -Wl,--rpath -Wl,/usr/lib64
creating aping
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c br.c
/bin/sh ../../libtool --mode=link gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o br br.o ../../src/lib/libatm.la
gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o .libs/br br.o ../../src/lib/.libs/libatm.so -lresolv -Wl,--rpath -Wl,/usr/lib64
creating br
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c bw.c
/bin/sh ../../libtool --mode=link gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o bw bw.o ../../src/lib/libatm.la
gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o .libs/bw bw.o ../../src/lib/.libs/libatm.so -lresolv -Wl,--rpath -Wl,/usr/lib64
creating bw
/usr/bin/perl ./mkerrnos.pl </usr/include/asm/errno.h \
>errnos.inc || { rm -f errnos.inc; exit 1; }
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c isp.c
isp.c: In function 'send_msg':
isp.c:40: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int'
isp.c: In function 'recv_msg':
isp.c:52: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int'
bison -y -d ispl_y.y && mv y.tab.c ispl_y.c
ispl_y.y:37.28-37: warning: symbol TOK_LISTEN redeclared
if test -f y.tab.h; then \
if cmp -s y.tab.h ispl_y.h; then rm -f y.tab.h; else mv y.tab.h ispl_y.h; fi; \
else :; fi
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c ispl_y.c
gcc -DHAVE_CONFIG_H -I. -I. -I../.. -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -c ispl_l.c
In file included from ispl_l.l:7:
../../config.h:15:1: warning: "YY_USE_CONST" redefined
ispl_l.c:38:1: warning: this is the location of the previous definition
lex.yy.c:1343: warning: 'yyunput' defined but not used
/bin/sh ../../libtool --mode=link gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o isp isp.o ispl_y.o ispl_l.o ../../src/lib/libatm.la -lfl
gcc -I../../src/include -O2 -pipe -fno-strict-aliasing -Wall -Wshadow -Wpointer-arith -Wwrite-strings -Wstrict-prototypes -o .libs/isp isp.o ispl_y.o ispl_l.o ../../src/lib/.libs/libatm.so -lresolv -lfl -Wl,--rpath -Wl,/usr/lib64
/usr/lib/gcc/x86_64-pc-linux-gnu/4.1.2/../../../../x86_64-pc-linux-gnu/bin/ld: cannot find -lfl
collect2: ld returned 1 exit status
make[3]: *** [isp] Error 1
make[3]: Leaving directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/src/test'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/work/linux-atm-2.4.1'
make: *** [all-recursive-am] Error 2
* ERROR: net-dialup/linux-atm-2.4.1-r2 failed.
* Call stack:
* ebuild.sh, line 49: Called src_compile
* environment, line 2660: Called die
* The specific snippet of code:
* emake || die "emake failed"
* The die message:
* emake failed
* If you need support, post the topmost build error, and the call stack if relevant.
* A complete build log is located at '/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/temp/build.log'.
* The ebuild environment file is located at '/var/tmp/portage/net-dialup/linux-atm-2.4.1-r2/temp/environment'.
* Messages for package net-dialup/linux-atm-2.4.1-r2:
* Call stack:
* The die message:
* emake failed
localhost ~ #
Merci d'avance
Configuration: Windows Vista
    Tout est là :
    Il faut installer la librairie "fl". Installe là et tape :
    ldconfig
    Puis refais ton emerge... Sous debian, j'ai cru voir que c'était un morceau de flex :
    (root@aldur) (~) # apt-file search libfl\.
    flex: /usr/lib/libfl.a
    flex: /usr/lib/libfl.so
    flex-old: /usr/lib/libfl.a
    Donc installe au préalable le paquet flex. En fait je pense qu'il manque une dépendance sur flex dans le paquet que tu cherches à installer.
    Bonne chance
    1. ça marche!!!!
      Merci pour votre aide...
      ps: il sufit de lancer "emerge flex" pour installer flex sous gentoo!!
