Probleme de gravure avec pioneer DVR-112D
Bonjour, j'ai un probleme de gravure avec mon lecteur pionner DVD-RW DVR-112D. Depuis que je l'ai installé, j'arrive a lire mais pas a graver. Merci de votre aide Voici le log :
Admin
XPSP2
1A20-020N-0132-2525-1258-0359*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 17:35:32
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15e
(Nero Express)
Recorder: <PIONEER DVD-RW DVR-112D>Version: 1.21 - HA 1 TA 0 - 6.6.0.15
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <CREATIVE CD5233E >Version: 1.00 - HA 1 TA 1 - 6.6.0.15
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y080L0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-112D atapi Port 1 ID 0 DMA: On
CdRomPeripheral : CREATIVE CD5233E atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-112D D: CDRom3
CREATIVE CD5233E E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 124MB (127608kB)
Memory in use : 75 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
23.3.2008
CD Audio
15:03:40 #1 CDADOC -1 File Cdadoc.cpp, Line 1465
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 06:00.72, Pause frames: 150, Filters: 0, Name: '01 KAYSHA on dit quoi -.mp3'.
Track 02: Length: 05:27.43, Pause frames: 150, Filters: 0, Name: '02 TEEYAH coupé décalé.mp3'.
Track 03: Length: 05:20.68, Pause frames: 150, Filters: 0, Name: '03 BORO SANGUY & LINO VERSACE la jet.mp3'.
Track 04: Length: 06:18.38, Pause frames: 150, Filters: 0, Name: '04 DOUK SAGA proclamation.mp3'.
Track 05: Length: 04:44.43, Pause frames: 150, Filters: 0, Name: '05 DJ ARAFAT femmes.mp3'.
Track 06: Length: 07:49.11, Pause frames: 150, Filters: 0, Name: '06 grippe aviaire - dj Lewis DJ CRAPS sequence ku-p-d-k-lé coupe decale 192kbps.mp3'.
Track 07: Length: 05:29.63, Pause frames: 150, Filters: 0, Name: '07 DJ RESSOURCE la jet dj.mp3'.
Track 08: Length: 05:58.35, Pause frames: 150, Filters: 0, Name: '08 DJ JACOB attalakou méga.mp3'.
Track 09: Length: 04:25.69, Pause frames: 150, Filters: 0, Name: '09 TATA KENY sexyboulance.mp3'.
Track 10: Length: 05:05.21, Pause frames: 150, Filters: 0, Name: '10 MEIWAY voilà string.mp3'.
Track 11: Length: 04:14.54, Pause frames: 150, Filters: 0, Name: '11 DREAM TEAM hommage à Drogba.mp3'.
Track 12: Length: 04:19.43, Pause frames: 150, Filters: 0, Name: '12 MULUKUKU DJ merci seigneur.mp3'.
Track 13: Length: 05:01.06, Pause frames: 150, Filters: 0, Name: '13 SHANAKA YAKUZA drogbacité.mp3'.
Track 14: Length: 04:42.18, Pause frames: 150, Filters: 0, Name: '14 ERICSON LE ZOULOU bongo bongo.mp3'.
Total size: 75:26.59
15:03:41 #2 Text 0 File Burncd.cpp, Line 2946
Protection contre les ruptures activés
15:03:41 #3 Text 0 File Reader.cpp, Line 127
Reader running
15:03:41 #4 Text 0 File Writer.cpp, Line 122
Writer PIONEER DVD-RW DVR-112D running
15:03:41 #5 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
15:03:41 #6 Text 0 File Burncd.cpp, Line 3231
Turn on Disc-At-Once, using CD-R/RW media
15:03:42 #7 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 339358 ( 75:26.58)
15:03:42 #8 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO (enabled: CD)
15:03:42 #9 Text 0 File DlgWaitCD.cpp, Line 2457
Recorder: PIONEER DVD-RW DVR-112D;
CDR code: 00 97 22 67; OSJ entry from: Daxon Technology, Inc.
ATIP Data:
Special Info [hex] 1: D0 00 80, 2: 61 16 43 (LI 97:22.67), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
15:03:42 #10 Text 0 File DlgWaitCD.cpp, Line 445
>>> Protocol of DlgWaitCD activities: <<<
15:03:42 #11 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (01 KAYSHA on dit quoi -.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 27072 (27072) = #27072/6:0.72
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 27072 blocks [PIONEER DVD-RW DVR-112D]
1: TRM_AUDIO_NOPRE (02 TEEYAH coupé décalé.mp3)
original disc pos #0 + 24568 (24568) = #24568/5:27.43
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24568 blocks [PIONEER DVD-RW DVR-112D]
2: TRM_AUDIO_NOPRE (03 BORO SANGUY & LINO VERSACE la jet.mp3)
original disc pos #0 + 24068 (24068) = #24068/5:20.68
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24068 blocks [PIONEER DVD-RW DVR-112D]
3: TRM_AUDIO_NOPRE (04 DOUK SAGA proclamation.mp3)
original disc pos #0 + 28388 (28388) = #28388/6:18.38
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 28388 blocks [PIONEER DVD-RW DVR-112D]
4: TRM_AUDIO_NOPRE (05 DJ ARAFAT femmes.mp3)
original disc pos #0 + 21343 (21343) = #21343/4:44.43
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21343 blocks [PIONEER DVD-RW DVR-112D]
5: TRM_AUDIO_NOPRE (06 grippe aviaire - dj Lewis DJ CRAPS sequence ku-p-d-k-lé coupe decale 192kbps.mp3)
original disc pos #0 + 35186 (35186) = #35186/7:49.11
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 35186 blocks [PIONEER DVD-RW DVR-112D]
6: TRM_AUDIO_NOPRE (07 DJ RESSOURCE la jet dj.mp3)
original disc pos #0 + 24738 (24738) = #24738/5:29.63
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24738 blocks [PIONEER DVD-RW DVR-112D]
7: TRM_AUDIO_NOPRE (08 DJ JACOB attalakou méga.mp3)
original disc pos #0 + 26885 (26885) = #26885/5:58.35
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 26885 blocks [PIONEER DVD-RW DVR-112D]
8: TRM_AUDIO_NOPRE (09 TATA KENY sexyboulance.mp3)
original disc pos #0 + 19944 (19944) = #19944/4:25.69
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19944 blocks [PIONEER DVD-RW DVR-112D]
9: TRM_AUDIO_NOPRE (10 MEIWAY voilà string.mp3)
original disc pos #0 + 22896 (22896) = #22896/5:5.21
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22896 blocks [PIONEER DVD-RW DVR-112D]
10: TRM_AUDIO_NOPRE (11 DREAM TEAM hommage à Drogba.mp3)
original disc pos #0 + 19104 (19104) = #19104/4:14.54
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19104 blocks [PIONEER DVD-RW DVR-112D]
11: TRM_AUDIO_NOPRE (12 MULUKUKU DJ merci seigneur.mp3)
original disc pos #0 + 19468 (19468) = #19468/4:19.43
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19468 blocks [PIONEER DVD-RW DVR-112D]
12: TRM_AUDIO_NOPRE (13 SHANAKA YAKUZA drogbacité.mp3)
original disc pos #0 + 22581 (22581) = #22581/5:1.6
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22581 blocks [PIONEER DVD-RW DVR-112D]
13: TRM_AUDIO_NOPRE (14 ERICSON LE ZOULOU bongo bongo.mp3)
original disc pos #0 + 21168 (21168) = #21168/4:42.18
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21168 blocks [PIONEER DVD-RW DVR-112D]
15:03:42 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [PIONEER DVD-RW DVR-112D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 14:
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 64026144, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 64026144 64378944 122162880, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 122162880 122515680 179123616, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 179123616 179476416 246244992, ISRC ""
5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 246244992 246597792 296796528, ISRC ""
6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 296796528 297149328 379906800, ISRC ""
7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 379906800 380259600 438443376, ISRC ""
8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 438443376 438796176 502029696, ISRC ""
9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 502029696 502382496 549290784, ISRC ""
10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 549290784 549643584 603494976, ISRC ""
11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 603494976 603847776 648780384, ISRC ""
12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 648780384 649133184 694921920, ISRC ""
13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 694921920 695274720 748385232, ISRC ""
14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 748385232 748738032 798525168, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0x00
-150 | 1 | 0 | 0x21 | 0x00
0 | 1 | 1 | 0x21 | 0x00
27072 | 2 | 0 | 0x21 | 0x00
27222 | 2 | 1 | 0x21 | 0x00
51790 | 3 | 0 | 0x21 | 0x00
51940 | 3 | 1 | 0x21 | 0x00
76008 | 4 | 0 | 0x21 | 0x00
76158 | 4 | 1 | 0x21 | 0x00
104546 | 5 | 0 | 0x21 | 0x00
104696 | 5 | 1 | 0x21 | 0x00
126039 | 6 | 0 | 0x21 | 0x00
126189 | 6 | 1 | 0x21 | 0x00
161375 | 7 | 0 | 0x21 | 0x00
161525 | 7 | 1 | 0x21 | 0x00
186263 | 8 | 0 | 0x21 | 0x00
186413 | 8 | 1 | 0x21 | 0x00
213298 | 9 | 0 | 0x21 | 0x00
213448 | 9 | 1 | 0x21 | 0x00
233392 | 10 | 0 | 0x21 | 0x00
233542 | 10 | 1 | 0x21 | 0x00
256438 | 11 | 0 | 0x21 | 0x00
256588 | 11 | 1 | 0x21 | 0x00
275692 | 12 | 0 | 0x21 | 0x00
275842 | 12 | 1 | 0x21 | 0x00
295310 | 13 | 0 | 0x21 | 0x00
295460 | 13 | 1 | 0x21 | 0x00
318041 | 14 | 0 | 0x21 | 0x00
318191 | 14 | 1 | 0x21 | 0x00
339359 | lead-out | 1 | 0x01 | 0x00
15:03:42 #13 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 10x (1 500 Ko/s)
15:03:42 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:03:42 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #27222
15:03:42 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #51940
15:03:42 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #76158
15:03:42 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #0): write at #104696
15:03:42 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #0): write at #126189
15:03:42 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #0): write at #161525
15:03:42 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #0): write at #186413
15:03:42 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #0): write at #213448
15:03:42 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #0): write at #233542
15:03:42 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #0): write at #256588
15:03:42 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #0): write at #275842
15:03:42 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #0): write at #295460
15:03:42 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #0): write at #318191
15:03:42 #28 Text 0 File Mmc.cpp, Line 16845
StartDAO : CD-Text - On
15:03:42 #29 Text 0 File Mmc.cpp, Line 21627
Set BUFE: Buffer underrun protection -> ON
15:03:43 #30 Text 0 File Mmc.cpp, Line 17134
CueData, Len=240
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 06 02 48
21 02 01 00 00 06 04 48
21 03 00 00 00 0b 20 28
21 03 01 00 00 0b 22 28
21 04 00 00 00 10 37 21
21 04 01 00 00 10 39 21
21 05 00 00 00 17 0f 47
21 05 01 00 00 17 11 47
21 06 00 00 00 1c 02 27
21 06 01 00 00 1c 04 27
21 07 00 00 00 23 35 32
21 07 01 00 00 23 37 32
21 08 00 00 00 29 19 26
21 08 01 00 00 29 1b 26
21 09 00 00 00 2f 19 49
21 09 01 00 00 2f 1b 49
21 0a 00 00 00 33 35 43
21 0a 01 00 00 33 37 43
21 0b 00 00 00 39 01 0d
21 0b 01 00 00 39 03 0d
21 0c 00 00 00 3d 11 43
21 0c 01 00 00 3d 13 43
21 0d 00 00 00 41 27 23
21 0d 01 00 00 41 29 23
21 0e 00 00 00 46 2a 29
21 0e 01 00 00 46 2c 29
01 aa 01 01 00 4b 1a 3b
15:04:11 #31 Text 0 File Cdrdrv.cpp, Line 1288
15:04:11.859 - PIONEER DVD-RW DVR-112D\H1 T0 : Queue again later
15:04:11 #32 Text 0 File Cdrdrv.cpp, Line 1288
15:04:11.921 - PIONEER DVD-RW DVR-112D\H1 T0 : Queue again later
15:04:12 #33 SCSI -400 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0B080000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0xA8
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1B 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x04 0x93 0x10 0x00 0x0E
0x26 0x08 0x10 0xFA 0xA8 0x03
15:04:12 #34 CDR -400 File Writer.cpp, Line 311
Unspecified target error
15:04:15 #35 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
15:04:15 #36 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
15:04:22 #37 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 10x (1 500 Ko/s)
15:04:22 #38 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
15:04:22 #39 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 05/10/2006 03:42:42
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 15/08/2007 23:33:10 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 21:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
MERCI ENCORE car la je suis paumé..... SEBASTIEN
Internet Explorer 6.0
  1. ptdrrrrrr !!! trop fort fo le mettre dans un betisier celui la ,ptdrrrrr
    1. Toi, Va te faire mettre et va repondre aux questions dont tu peux repondre. Merci
