Problème ma macro change
La macro ci-dessous fonctionne par bouton, mais j'aimerai la faire fonctionnée par Sub change.
Que quand je change une cellule il lance la macro
Merci d'avance
ActiveSheet.Unprotect ("BibleYo")
'N° de détenu = nombre de lignes
If Cells(6, 2) = "1" Then
a = 18
End If
If Cells(6, 2) = "2" Then
a = 21
End If
If Cells(6, 2) = "3" Then
a = 24
End If
If Cells(6, 2) = "4" Then
a = 27
End If
If Cells(6, 2) = "5" Then
a = 30
End If
If Cells(6, 2) = "6" Then
a = 33
End If
If Cells(6, 2) = "7" Then
a = 36
End If
If Cells(6, 2) = "8" Then
a = 39
End If
If Cells(6, 2) = "9" Then
a = 42
End If
If Cells(6, 2) = "10" Then
a = 45
End If
If Cells(6, 2) = "11" Then
a = 48
End If
If Cells(6, 2) = "12" Then
a = 51
End If
If Cells(6, 2) = "13" Then
a = 54
End If
If Cells(6, 2) = "14" Then
a = 57
End If
If Cells(6, 2) = "15" Then
a = 60
End If
If Cells(6, 2) = "16" Then
a = 63
End If
If Cells(6, 2) = "17" Then
a = 66
End If
If Cells(6, 2) = "18" Then
a = 69
End If
If Cells(6, 2) = "19" Then
a = 72
End If
If Cells(6, 2) = "20" Then
a = 75
End If
If Cells(6, 2) = "21" Then
a = 78
End If
If Cells(6, 2) = "22" Then
a = 81
End If
If Cells(6, 2) = "23" Then
a = 84
End If
If Cells(6, 2) = "24" Then
a = 87
End If
If Cells(6, 2) = "25" Then
a = 90
End If
If Cells(6, 2) = "26" Then
a = 93
End If
If Cells(6, 2) = "27" Then
a = 96
End If
'Efface les totaux par détenus
Columns("BR:BR").Select
Selection.ClearContents
'Efface les totaux par jours
Range(Cells(a + 2, 11), Cells(a + 2, 41)).ClearContents
Range(Cells(8, 42), Cells(a, 42)).ClearContents
For i = 8 To a
For j = 11 To 41
If Cells(i, j) = "X" Then
Cells(a + 2, j) = Cells(a + 2, j) + 1
End If
Next
Next
For i = 8 To a
For j = 11 To 41
Cells(i, 70) = Cells(i, 70) + 1
End If
Next
Next
For i = 8 To a
If Cells(i, 70) <> "" Or Cells(i + 1, 70) <> "" Then
Cells(i, 42) = Cells(i, 70) + Cells(i + 1, 70)
End If
Next
For i = 8 To a
If Cells(i, 6) <> "" Then
Cells(i + 2, 42).Select
With Selection.Font
.ThemeColor = xlThemeColorDark1
.TintAndShade = 0
End With
' Cells(i + 2, 42).ClearContents
End If
Next
ActiveSheet.Protect ("BibleYo")
    déjà pour éviter la trop longue liste de if cells(2,6), restons simple
    If range("F2")>0 then: a=(range("F2")-1)*3 +18
    et on supose que la valeur qui change est bien F2 ?
    Si oui la valeur dans F2 est elle une saisie ou le résultat d'une formule dans F2 ?
    1. C'est une saisie
        Il semble y avoir des incohérences comme
        puis + loin
        cells(i,70) a pour valeur mini 1 et donc le
        est toujours Vrai
        je me trompe ou pas ?
    2. Contributeur
      re,
      sans réponse et en attendant
      a copier dans le module feuille concernée (par ex feuil1(feuil1)
      Option Explicit
      Private Sub Worksheet_Change(ByVal Target As Range)
      Static Flag As Boolean
      Dim Derlig As Byte
      Dim Zone As Range, Cellule As Range
      Dim Nbre As Integer, Cptr As Integer, Col As Byte, Lig As Byte
      If Target.Address = "$B$6" And Flag = False Then
      Flag = True
      If Target > 0 Then
      Application.ScreenUpdating = False
      Derlig = (Target - 1) * 3 + 18
      '---------nettoyage
      Columns("BR").ClearContents
      Range("K20:AO98").ClearContents
      Range("AP8:AP96").ClearContents
      '--------------comptage
      ' zone de recherche
      Set Zone = ActiveSheet.Range(Cells(8, "K"), Cells(Derlig, "AO"))
      Nbre = Application.CountIf(Zone, "X")
      'recherche des "X" dans la zone
      With Zone
      Set Cellule = Zone.Find(what:="X", LookIn:=xlValues)
      For Cptr = 1 To Nbre
      Col = Cellule.Column
      Lig = Cellule.Row
      'comptage jours
      Cells(Derlig + 2, Col) = Cells(Derlig + 2, Col) + 1
      Cells(Lig, "BR") = Cells(Lig, "BR") + 1
      'comptage détenus
      Cells(Lig, "AP") = Cells(Lig, "BR") + Cells(Lig + 1, "BR")
      Set Cellule = .FindNext(Cellule)
      Next
      End With
      For Lig = 8 To Derlig
      If Cells(Lig, "F") <> "" Then Cells(Lig + 2, "AP").Font.ThemeColor = xlThemeColorDark1
      Next
      ActiveSheet.Protect
      End If
      Flag = False
      End If
      End Sub
      1. Désolé, mais je n'avais pas de connexion internet.
        Je ne sais pas pourquoi, mais sans rien faire ça fonctionne.
        Merci énormément et désolé.
