Probleme JBOSS
salut
svp lorsque j'essaye de demarrer JBOSS un erreur s'affiche disant que mon fichier persistance fonctionne mal ...
voila l'erreur
23:45:48,358 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-6) MSC00001: Failed to start service jboss.persistenceunit."Gestion-Hotel.jar#UP_GestionHotel": org.jboss.msc.service.StartException in service jboss.persistenceunit."Gestion-Hotel.jar#UP_GestionHotel": Failed to start service
at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1780) [jboss-msc-1.0.1.GA.jar:1.0.1.GA]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [:1.7.0_79]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) [:1.7.0_79]
at java.lang.Thread.run(Thread.java:745) [:1.7.0_79]
Caused by: javax.persistence.PersistenceException: [PersistenceUnit: UP_GestionHotel] Unable to build EntityManagerFactory
at org.hibernate.ejb.Ejb3Configuration.buildEntityManagerFactory(Ejb3Configuration.java:908)
at org.hibernate.ejb.Ejb3Configuration.buildEntityManagerFactory(Ejb3Configuration.java:884)
at org.hibernate.ejb.HibernatePersistence.createContainerEntityManagerFactory(HibernatePersistence.java:73)
at org.jboss.as.jpa.service.PersistenceUnitService.createContainerEntityManagerFactory(PersistenceUnitService.java:143)
at org.jboss.as.jpa.service.PersistenceUnitService.start(PersistenceUnitService.java:77)
at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1824) [jboss-msc-1.0.1.GA.jar:1.0.1.GA]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1759) [jboss-msc-1.0.1.GA.jar:1.0.1.GA]
... 3 more
Caused by: org.hibernate.AnnotationException: Unknown mappedBy in: metier.Compte.CT, referenced property unknown: metier.Client.C
at org.hibernate.cfg.OneToOneSecondPass.doSecondPass(OneToOneSecondPass.java:157)
at org.hibernate.cfg.Configuration.originalSecondPassCompile(Configuration.java:1573)
at org.hibernate.cfg.Configuration.secondPassCompile(Configuration.java:1346)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1711)
at org.hibernate.ejb.EntityManagerFactoryImpl.<init>(EntityManagerFactoryImpl.java:76)
at org.hibernate.ejb.Ejb3Configuration.buildEntityManagerFactory(Ejb3Configuration.java:899)
... 9 more
23:45:48,365 INFO [org.jboss.as.server.controller] (DeploymentScanner-threads - 1) Deployment of "Gestion-Hotel.jar" was rolled back with failure message {"Failed services" => {"jboss.persistenceunit.\"Gestion-Hotel.jar#UP_GestionHotel\"" => "org.jboss.msc.service.StartException in service jboss.persistenceunit.\"Gestion-Hotel.jar#UP_GestionHotel\": Failed to start service"}}
23:45:48,369 INFO [org.jboss.as.server.deployment] (MSC service thread 1-2) Stopped deployment Gestion-Hotel.jar in 6ms
23:45:48,371 ERROR [org.jboss.as.deployment] (DeploymentScanner-threads - 2) {"Composite operation failed and was rolled back. Steps that failed:" => {"Operation step-2" => {"Failed services" => {"jboss.persistenceunit.\"Gestion-Hotel.jar#UP_GestionHotel\"" => "org.jboss.msc.service.StartException in service jboss.persistenceunit.\"Gestion-Hotel.jar#UP_GestionHotel\": Failed to start service"}}}}
23:45:53,405 INFO [org.jboss.as.server.deployment] (MSC service thread 1-4) Starting deployment of "Gestion-Hotel.jar"
23:45:53,413 INFO [org.jboss.jpa] (MSC service thread 1-1) read persistence.xml for UP_GestionHotel
23:45:53,414 INFO [org.jboss.as.jpa] (MSC service thread 1-5) added javax.persistence.api, javaee.api, org.jboss.as.jpa, org.javassist dependencies to Gestion-Hotel.jar
23:45:53,414 INFO [org.jboss.as.jpa] (MSC service thread 1-5) added (default provider) org.hibernate dependency to application deployment (since 1 PU(s) didn't specify jboss.as.jpa.providerModule)
23:45:53,414 INFO [org.jboss.as.jpa] (MSC service thread 1-5) added org.hibernate dependency to application deployment
23:45:53,422 INFO [org.jboss.jpa] (MSC service thread 1-5) starting Persistence Unit Service 'Gestion-Hotel.jar#UP_GestionHotel'
23:45:53,423 INFO [org.hibernate.ejb.Ejb3Configuration] (MSC service thread 1-5) HHH00204:Processing PersistenceUnitInfo [
23:45:53,438 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-5) MSC00001: Failed to start service jboss.persistenceunit."Gestion-Hotel.jar#UP_GestionHotel": org.jboss.msc.service.StartException in service jboss.persistenceunit."Gestion-Hotel.jar#UP_GestionHotel": Failed to start service
... 3 more
Caused by: org.hibernate.AnnotationException: mappedBy reference an unknown target entity property: metier.Reservation.Client in metier.Client.reservation
at org.hibernate.cfg.annotations.CollectionBinder.bindStarToManySecondPass(CollectionBinder.java:665)
at org.hibernate.cfg.annotations.CollectionBinder$1.secondPass(CollectionBinder.java:625)
at org.hibernate.cfg.CollectionSecondPass.doSecondPass(CollectionSecondPass.java:65)
... 9 more
23:45:53,440 INFO [org.jboss.as.server.controller] (DeploymentScanner-threads - 1) Deployment of "Gestion-Hotel.jar" was rolled back with failure message {"Failed services" => {"jboss.persistenceunit.\"Gestion-Hotel.jar#UP_GestionHotel\"" => "org.jboss.msc.service.StartException in service jboss.persistenceunit.\"Gestion-Hotel.jar#UP_GestionHotel\": Failed to start service"}}
23:45:53,443 INFO [org.jboss.as.server.deployment] (MSC service thread 1-3) Stopped deployment Gestion-Hotel.jar in 2ms
23:45:53,444 ERROR [org.jboss.as.deployment] (DeploymentScanner-threads - 2) {"Composite operation failed and was rolled back. Steps that failed:" => {"Operation step-2" => {"Failed services" => {"jboss.persistenceunit.\"Gestion-Hotel.jar#UP_GestionHotel\"" => "org.jboss.msc.service.StartException in service jboss.persistenceunit.\"Gestion-Hotel.jar#UP_GestionHotel\": Failed to start service"}}}}
qui a une idée sur ça svp
et merci d'avance
Discussions similaires
JBoss Vs Tomcat
8 réponses
