Shader Pour PC Peu Puissant??
je cherche un shader ou du moin une solution a mon probleme...Voila alors,j'ai installer le mod shader puis j'ai mit mes shader dans mon dossier (la base x) )mais quand je met le shader mon minecraft CRash !!! Je ne sais pas d'ou vien le probleme ;-; Aide? (Si vous avez un shader a me proposer !? :p) voici ce que ca me marque quand mon jeu crash :
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000001d66d6a0, pid=1560, tid=916
# JRE version: Java(TM) SE Runtime Environment (8.0_40-b26) (build 1.8.0_40-b26)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.40-b25 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig75icd64.dll+0x7d6a0]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# C:\Users\Tristan\AppData\Roaming\.minecraft\hs_err_pid1560.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
AL lib: (EE) alc_cleanup: 1 device not closed
Java HotSpot(TM) 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Voila , Voila merci d'avance ^^ !
8 réponses
  1. Slt,
    Sans le détail de ta config, je vois pas comment on pourra répondre efficacement.
