Problème lancement de Minecraft
J'ai acheté Minecraft il y'a quelques minutes et le lancement me fait une erreur. Je dois avouer que j'ai payé 20 euros et j'ai l'impression de m'être fait avoir :(
HELP !
HELP !
Bootstrap (v5)
Current time is Apr 26, 2014 3:15:08 PM
System.getProperty('os.name') == 'Windows 7'
System.getProperty('os.version') == '6.1'
System.getProperty('os.arch') == 'x86'
System.getProperty('java.version') == '1.7.0_55'
System.getProperty('java.vendor') == 'Oracle Corporation'
System.getProperty('sun.arch.data.model') == '32'
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma
Exception: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Recognized exception: the likely cause is a set of broken/missing root-certificates. Check your java install and perhaps reinstall it.
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 2/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 3/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 4/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 5/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 6/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 7/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 8/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 9/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 10/10)
Unable to download remote file. Check your internet connection/proxy settings.
FATAL ERROR: net.minecraft.bootstrap.FatalBootstrapError: Unable to download while being forced
at net.minecraft.bootstrap.Bootstrap.execute(Bootstrap.java:95)
at net.minecraft.bootstrap.Bootstrap.main(Bootstrap.java:381)
12 réponses
Le problème décrit est le lancement de Minecraft qui échoue avec une erreur SSL et un échec de téléchargement du launcher, lié à des certificats racines manquants et à une vérification PKIX. Des éléments de réponse essentiels suggèrent de vérifier l’installation Java et peut-être la réinstaller, vérifier la connexion Internet/proxy, et envisager une réinstallation du launcher ou du jeu. Des réponses notables recommandent une désinstallation et réinstallation, et des éléments contextuels mentionnent l’OS, l’architecture 32/64 bits et des facteurs externes comme l’antivirus ou les pilotes.
Désinstalle et réinstalle
A tu installé Java ?
Je l'ai mis à jour V.7 aucun résultat, l'anti virus a été vérifié toujours rien. HELP me :(
Déjà fait toujours rien
Tu a quoi comme OS ? (Windows 7, 8...) Quel version (32 ou 64 bits)
Windows 7 edition familiale avec 32 bits. Merci de m'aider
Met a jours tes driver graphique (le site tous les drivers peut t'aider si besoin)
Tu n'as pas un message d'erreur plus court que celui que tu a donné au début ?
Voltox -> Window 7, son OS.
Ton problème vient surement de la version de JAVA.
"Check your java install and perhaps reinstall it."
Dans ce cas, désinstalle-le complètement et proprement et installe de nouveau.
Alex.-
Alors non tu ne t'es pas fais avoir pour la simple et bonne raison que tu n'achète pas vraiment le jeu en lui même mais plutôt un pseudo. Ainsi tu pourra en te connectant sur le site officiel de Minecraft, télécharger le jeu autant de fois que tu le souhaite. Le problème vient de toi (enfin de ton ordi) et non du jeu en lui même. ;)
Bon je ne pense pas que cela vienne des pilotes graphiques mais tu peux toujours essayer...
Essaye de désactiver, ton anti-virus et ton firewall (pare-feu). Puis réessaye. -
J'ai mis à jour mes pilotes, toujours le même message d'erreur...
J'ai dépense 20 euros pour rien ou quoi ??!!!??? -
à mon avis le jeu a un défaut et il faut l'emmener à un vendeur de jeu vidéo pour qu'il regarde ce qui ne va pas . ou alors ton ordinateur à un défaut ou pas assez de mémoire et à ce moment là il faut aussi aller voir un vendeur de jeu vidéo .
Une aide svp !!
