Probleme minecraft
bonjour j'ai un pc sous windows vista
ou il y a minecraft mais après l'interface j'ai ça:
---- Minecraft Crash Report ----
// Daisy, daisy...
Time: 24/12/13 15:18
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:244)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at atv.O(SourceFile:297)
at atv.d(SourceFile:599)
at net.minecraft.client.main.Main.main(SourceFile:101)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.6.4
Operating System: Windows Vista (x86) version 6.0
Java Version: 1.7.0_45, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode, sharing), Oracle Corporation
Memory: 6544928 bytes (6 MB) / 26808320 bytes (25 MB) up to 518979584 bytes (494 MB)
JVM Flags: 2 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.6.4
LWJGL: 2.9.0
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Pack: Default
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null
j'espere que quelqu'un sait ce que sait
merci vincent
  1. Bonjour vince77130
    Je pense que c'est du a ta carte graphique il me semble alors
    1. Vérifie les drivers de ta carte graphique en téléchargeant le module qui est ici:
    https://www.touslesdrivers.com/index.php?v_page=29
    Et en suivant les indications.
    2. Si tu a installé un ou plusieurs drivers,redémarrez ton ordinateur et vérifie si le problème est résolu.
    3.Si le problème n'est toujours pas résolu,fait un clique droit sur le bureau.Clique sur propriétés puis paramètres puis avancé puis dépannage.Là,baisse ton accélération matérielle jusqu'à la 3ème petite barre en partant de la gauche.Clique sur Ok.
    Logiquement ton minecraft devrait remarcher si il ne remarche pas alors la je ne sais pas.
    1. j'ai deja fait les demarche 1 et 2 mais pour la trois quand je clique droi sur le bureau je n'ais pas parametre
      1. Le parametre va a la propriéter d'affichage
        Si tu prefère : Panneau de configuration > affichage > parametre
        1. Bonjour, quelle est ta carte graphique ? Est-elle à jour ?
