VBA programme ne fait rien
Bonjour, ce matin mon programme marchait mais maitenant il ne marche plus, le voici. Merci pour votre aide !
Sub REMPLISSAGEbase()
For i = 2 To 360
For j = 3 To 759
If Range("D" & i).Value = "Film" And Range("F" & i).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("C" & j).Value Then Workbooks("BASEc.xlsx").Sheets(1).Range("BQ" & j).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("BQ" & j).Text & vbCrLf & " Film: " & Range("C" & i).Value & " " & Range("I" & i).Value & " " & Range("J" & i).Value & " Original:" & Range("L" & i).Value & " French:" & Range("M" & i).Value & " " & Range("Q" & i).Value & " " & Range("R" & i).Value
Next
Next
For i = 2 To 360
For j = 3 To 759
If Range("D" & i).Value = "Trailer" And Range("F" & i).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("C" & j).Value Then Workbooks("BASEc.xlsx").Sheets(1).Range("BQ" & j).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("BQ" & j).Text & vbCrLf & " BA: " & Range("C" & i).Value & " " & Range("I" & i).Value & " " & Range("J" & i).Value & " Original:" & Range("L" & i).Value & " French:" & Range("M" & i).Value & " " & Range("Q" & i).Value & " " & Range("R" & i).Value
Next
Next
For i = 2 To 360
For j = 3 To 759
If Range("D" & i).Value = "Bonus" And Range("F" & i).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("C" & j).Value Then Workbooks("BASEc.xlsx").Sheets(1).Range("BQ" & j).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("BQ" & j).Text & vbCrLf & " Bonus: " & Range("C" & i).Value & " " & Range("I" & i).Value & " " & Range("J" & i).Value & " Original:" & Range("L" & i).Value & " French:" & Range("M" & i).Value & " " & Range("Q" & i).Value & " " & Range("R" & i).Value
Next
Next
Dim k As Integer
For i = 2 To 360
k = 0
For j = 3 To 759
If Range("F" & i).Value <> Workbooks("BASEc.xlsx").Sheets(1).Range("C" & j).Value Then k = k + 1
Next
If k = 757 Then Range("F" & i).Interior.Color = RGB(255, 0, 0)
Next
For i = 2 To 360
For j = 3 To 759
If Range("F" & i).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("C" & j).Value And Range("R" & i) Like "*1920*" Then Workbooks("BASEc.xlsx").Sheets(1).Range("BP" & j).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("BP" & j).Text & vbCrLf & Range("D" & i).Value & ": " & "HD"
If Range("F" & i).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("C" & j).Value And Range("R" & i) Like "*720*" Then Workbooks("BASEc.xlsx").Sheets(1).Range("BP" & j).Value = Workbooks("BASEc.xlsx").Sheets(1).Range("BP" & j).Text & vbCrLf & Range("D" & i).Value & ": " & "SD"
Next
Next
End Sub
ContributeurBonjour,
1°) Quand tu poste du code il doit être indenté et tu dois le baliser comme code, le sélectionner et clic sur le bouton <> juste au dessus de l'éditeur.
2°) Avant que je n'examine tout ton code... il n'a aucune raison que ça marche au matin et plus deux heurs après. Tu DOIS avoir modifier quelque chose.. réfléchis.
Tu dis.
A+ -
magic, cette fois il a marché, sans rien changer.
Merci -
Maléfique Magiciel a du encore frapper !!! ^^
ContributeurSalut polux,
Mais non, mais non, une entité supérieure à bien voulu l'aider, eh oui, ça existe (les entités supérieurs). :-) parenthèse fermente x 10
A+
Si tu te cognes à un pot et que ça sonne creux, c'est pas forcément le pot qui est vide. ;-)(Confucius)
Note: Je ne répond pas aux MP pour les questions techniques. Et ma boule de cristal est calut Polux,
Mais non, mais non...ssée . -
en passant, ca m'a fait la meme chose, au fait le programme ne se lance simplement pas je pense, ca fait execution en cours (et quelque fois "ne repond pas") puis ca fait rien. je relance et ca marche.
voila, bye !
