Problème lancement Minecraft
Alors voilà, je vous explique mon problème :
Avant, j'était sous Windows Vista, et Minecraft marchait correctement.
Depuis une semaine, je suis passé à Windows 8, et je n'arrive pas à lancer Minecraft.
Voici le message d'erreur :
This error is caused by a lack of up to date graphic drivers.
---- Minecraft Crash Report ----
// Ouch. That hurt :(
Time: 23/07/13 14:22
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:244)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at ats.O(SourceFile:297)
at ats.d(SourceFile:599)
at net.minecraft.client.main.Main.main(SourceFile:101)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.6.2
Operating System: Windows Vista (amd64) version 6.0
Java Version: 1.7.0_17, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 63003960 bytes (60 MB) / 94633984 bytes (90 MB) up to 954466304 bytes (910 MB)
JVM Flags: 1 total; -Xmx1G
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.6.2
LWJGL: 2.9.0
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Pack: Default
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null
Vous me direz : "Je n'ai qu'à faire une mise à jour des pilotes, et ça marchera !"
Et bien non, justement, j'ai fait la MAJ, et ça ne marche toujours pas.
Donc j'espère que vous pourrez m'aider :)
(Ah, et je sais que pleins de sujets là-dessus existent, mais aucun ne m'a aidé)
