Problème Minecraft
Bonjour à tous, aujourd'hui j'ai un énorme problème ! En effet quand je lance mon launcher Minecraft, sa m'indique ceci :
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 11/06/13 20:49
-- System Details --
Details:
Minecraft Version: 1.5.2
Operating System: Windows Vista (x86) version 6.0
Java Version: 1.7.0_21, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 459130072 bytes (437 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:235)
at avv.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:507)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT d1672d38 ----------
Cela m'emêche de jouer, J'aimerais une réponse au plus vite, svp merci !
  1. Bonjour, il te faut mettre le pilote de ta carte graphique à jour, va sur le site du fabriquant de ton pc et récupère le driver correspondant.
    1. Je suis chez Packard Bell, tu pourrais m'aider s'il te plait ?
      1. Ok, alors vas sur cette page sélectionne ton modèle de Pc ou entre le numéro de série. Ensuite tu aura la liste de tous les pilotes pour ton pc, toi choisis les pilotes VGA, télécharges les et lances les.
        1. Je fais comment pour savoir le model de mon ordinateur ?
          1. il doit être indiqué quelque part par une étiquette, ou le numéro de série est peut-être sous l'ordinateur, tout est coller dessus
