Minecraft veux pas demarrer sur win7
Bonjour, j'ai acheter minecraft et donc telecharger mais quand je le lanse il apparait
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 10/02/13 22:13
-- System Details --
Details:
Minecraft Version: 1.4.7
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.6.0_18, Sun Microsystems Inc.
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
Memory: 482339104 bytes (459 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at asq.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT d292321b ----------
que faire svp aider moi
Details:
LWJGL: 2.4.2
svp aider mon c'est comme meme 20euro pour rien apres
ModérateurBonjour,
https://www.commentcamarche.net/faq/9265-identifier-son-materiel-avec-aida64
Copie-colle le résumé généré par AIDA64 dans ton prochain message.-
Version AIDA64 v2.80.2300/fr
Module de test 3.0.492-x32
Site web http://www.aida64.com/
Type de rapport Rapport rapide [ TRIAL VERSION ]
Ordinateur ADMIN-PC
Générateur admin
Système d'exploitation Microsoft Windows 7 Ultimate 6.1.7601.17944 (Win7 RTM)
Date 2013-02-10
Heure 22:33
--------[ Résumé ]------------------------------------------------------------------------------------------------------
Ordinateur:
Type de système PC avec processeur x86 ACPI
Service Pack du système [ TRIAL VERSION ]
Internet Explorer 9.0.8112.16421 (IE 9.0)
DirectX DirectX 11.0
Nom du système ADMIN-PC
Nom de l'utilisateur admin
Domaine de connexion [ TRIAL VERSION ]
Date / Heure 2013-02-10 / 22:33
Carte mère:
Type de processeur AMD Athlon XP, 2075 MHz (12.5 x 166) 2800+
Nom de la carte mère Asus A7V8X-LA (Kamet2) (3 PCI, 1 AGP, 2 DDR DIMM, Audio, Video, LAN, IEEE-1394)
Chipset de la carte mère VIA VT8378 UniChrome KM400
Mémoire système [ TRIAL VERSION ]
DIMM1: SK Hynix HYMD232 646B8J-J 256 Mo PC2700 DDR SDRAM (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
DIMM2: Corsair Value Select VS512MB333 [ TRIAL VERSION ]
Type de Bios Award (12/19/03)
Port de communication Communications Port (COM1)
Port de communication ECP Printer Port (LPT1)
Moniteur:
Carte vidéo Standard VGA Graphics Adapter (128 Mo)
Accélérateur 3D ATI Radeon 9200 SE (RV280)
Moniteur Compaq FP7317 [17" LCD] (THT34206C5)
Multimédia:
Carte audio TerraTec Aureon 5.1 Fun Sound Card
Stockage:
Contrôleur IDE Contrôleur IDE Bus Master VIA - 0571
Contrôleur IDE Contrôleur VIA Serial ATA - 3149
Lecteur de disquettes Lecteur de disquettes
Disque dur SAMSUNG SP0802N ATA Device (80 Go, 7200 RPM, Ultra-ATA/133)
Lecteur optique ASUS CRW-4824AH ATA Device (48x/24x/52x CD-RW)
Lecteur optique IDE-DVD ROM 16x ATA Device (16x DVD-ROM)
État des disques durs SMART OK
Partitions:
C: (NTFS) [ TRIAL VERSION ]
D: (NTFS) 26341 Mo (26216 Mo libre)
Taille totale [ TRIAL VERSION ]
Entrée:
Clavier Clavier standard PS/2
Souris Souris compatible PS/2
Réseau:
Adresse IP principale [ TRIAL VERSION ]
Adresse MAC principale 34-BD-F9-02-FA-F3
Carte réseau BeeWi Wi-Fi BWA411 Adaptor (192. [ TRIAL VERSION ])
Carte réseau VIA Rhine II Fast Ethernet Adapter
Modem PCI CX11252-11 Soft Modem
Périphériques:
Contrôleur FireWire VIA VT6307 Fire IIM IEEE1394 Host Controller (PHY: VIA VT6307)
Contrôleur USB1 VIA VT8237 USB Universal Host Controller
Contrôleur USB2 VIA VT8237 USB 2.0 Enhanced Host Controller
Périphérique USB BeeWi Wi-Fi BWA411 Adaptor
Périphérique USB Périphérique USB composite
Périphérique USB Trust Webcam
DMI:
Distributeur du Bios Phoenix Technologies, LTD
Version du Bios 3.06
Fabricant du système Compaq Presario 061
Nom du système DW173A-ABF S6099FR FR410
Version du système 0bQ0411RE101KAME210
N° de série du système [ TRIAL VERSION ]
UUID du système [ TRIAL VERSION ]
Fabricant de la carte mère ASUSTek Computer INC.
Nom de la carte mère Kamet2
Version de la carte mère 2.01
N° de série de la carte mère [ TRIAL VERSION ]
Fabricant du châssis Hewlett-Packard
Version du châssis
N° de série du châssis [ TRIAL VERSION ]
Identifiant du châssis [ TRIAL VERSION ]
Type du châssis Desktop Case
Sockets mémoire (Total/Libres) 2 / 0
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
Modérateur"ATI Radeon 9200 SE"
--> Il n'existe aucun pilote pour Vista ou Windows 7 pour cette carte graphique.
On peut essayer d'installer celui pour Windows XP.
---> Télécharge et installe 7-Zip :
https://www.commentcamarche.net/telecharger/utilitaires/2197-7-zip/
---> Télécharge ce pilote :
http://www2.ati.com/drivers/6-11-pre-r300_xp-2k_dd_ccc_wdm_38185.exe
---> Clique droit sur le fichier "6-11-pre-r300_xp-2k_dd_ccc_wdm_38185", choisis "7-Zip" puis "Extraire vers "6-11-pre-r300_xp-2k_dd_ccc_wdm_38185\". Tu obtiens un dossier nommé "6-11-pre-r300_xp-2k_dd_ccc_wdm_38185".
---> Va dans le gestionnaire de périphériques.
---> Clique droit sur ta carte graphique et choisis "Mettre à jour le pilote...".
---> Choisis "Rechercher un pilote sur mon ordinateur".
---> Clique sur "Parcourir" et choisis le dossier "2KXP_INF" situé dans 6-11-pre-r300_xp-2k_dd_ccc_wdm_38185 > $HWNDPARENT > Driver.
---> Clique sur "Suivant". -
ok mes quand je fait ca je trouve pas de plugin suplémentaire bon je dois te quiter car je dois aller dormir
