Problème avec un jeu java.
J'ai un problème avec Minecraft, et j'ai donc voulut telechargé une version "améliorée" de ce jeu: Feed the patrick. J'ai donc Telechargé ce jeu et mit le groupement de modpack que je voulait. Sa ne marche pas et la console affiche cela:
http://feedthepatrick.fr/richie/version.xml: java.io.FileNotFoundException: http://feedthepatrick.fr/richie/version.xml
Completely unable to download the modpack file - check your connection: java.io.FileNotFoundException: http://feedthepatrick.fr/richie/modpacks.xml
From Console: Exception occurred during event dispatching:
From Console: java.lang.NumberFormatException: For input string: ""
From Console: at java.lang.NumberFormatException.forInputString(Unknown Source)
From Console: at java.lang.Integer.parseInt(Unknown Source)
From Console: at net.ftb.gui.dialogs.AdvancedOptionsDialog.saveSettingsInto(AdvancedOptionsDialog.java:155)
From Console: at net.ftb.gui.dialogs.AdvancedOptionsDialog$2.focusLost(AdvancedOptionsDialog.java:167)
From Console: at java.awt.AWTEventMulticaster.focusLost(Unknown Source)
From Console: at java.awt.Component.processFocusEvent(Unknown Source)
From Console: at java.awt.Component.processEvent(Unknown Source)
From Console: at java.awt.Container.processEvent(Unknown Source)
From Console: at java.awt.Component.dispatchEventImpl(Unknown Source)
From Console: at java.awt.Container.dispatchEventImpl(Unknown Source)
From Console: at java.awt.Component.dispatchEvent(Unknown Source)
From Console: at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
From Console: at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
From Console: at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
From Console: at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
From Console: at java.awt.EventQueue.access$000(Unknown Source)
From Console: at java.awt.EventQueue$1.run(Unknown Source)
From Console: at java.security.AccessController.doPrivileged(Native Method)
From Console: at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
From Console: at java.awt.EventQueue$2.run(Unknown Source)
From Console: at java.awt.EventQueue.dispatchEvent(Unknown Source)
From Console: at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
From Console: at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
From Console: at java.awt.Dialog$1.run(Unknown Source)
From Console: at java.awt.Dialog$3.run(Unknown Source)
From Console: at java.awt.Dialog.show(Unknown Source)
From Console: at java.awt.Component.show(Unknown Source)
From Console: at java.awt.Component.setVisible(Unknown Source)
From Console: at java.awt.Window.setVisible(Unknown Source)
From Console: at java.awt.Dialog.setVisible(Unknown Source)
From Console: at net.ftb.gui.panes.OptionsPane$5.actionPerformed(OptionsPane.java:181)
From Console: at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
From Console: at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
From Console: at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
From Console: at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
From Console: at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
From Console: at java.awt.Component.processMouseEvent(Unknown Source)
From Console: at javax.swing.JComponent.processMouseEvent(Unknown Source)
From Console: at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
From Console: at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
From Console: at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
From Console: at java.awt.Window.dispatchEventImpl(Unknown Source)
From Console: at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
From Console: at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
From Console: at java.awt.EventDispatchThread.run(Unknown Source)
Voila :p Help svp :/
