Macro Excel VBA : graphiques automatique
bjr, j'ai 1 macro qui génère automatiquement des graphes/graphiques, ça marche.
Mais, 1 fois le graphe créé, sur une boucle, je n'arrive pas à reprndre le graphe pour modifier le style de la courbe, quelqu'un connait-il la solution ?
Merci.
[code]
Sub ifcourbes()
' ifcourbes Macro
' Macro enregistrée le 12/02/2007 par ericE
Sheets("tableau").Select
Range("AN6").Select
'maxlig = Range("B65535").End(xlUp).Row
maxlign = 6
For i = 2 To maxlign
'Sheets("tableau").Select
recup = Cells(i, 35)
If Cells(i, 31) < 500 Then
Select Case recup
Case ""
Cells(i, 42) = "tropfort"
Case Is > 0.7
Cells(i, 42) = "vu1"
Case 0.6 To 0.7
Cells(i, 42) = "vu11"
Case Is < 0.6
Cells(i, 42) = "vu121"
End Select
Else
Select Case recup
Case ""
Cells(i, 43) = "nonvu"
Case Is > 0.7
appelfonction = casfort(i)
Case 0.6 To 0.7
Cells(i, 43) = "vu11"
Case Is < 0.6
Cells(i, 43) = "vu121"
End Select
End If
Next
Range("AN6").Select
End Sub
Function casfort(j) As Integer
'Public ChartList As Integer
Dim sha As ChartObject
maxlign = 5
m = 1
For j = 2 To maxlign
'k = j + 22
Sheets("fort").Select
Cells(j * 22, 1).Select
'Cells(j * 25, 1).Select
'Cells(j * 22, 1).Select
Charts.Add
'ChartList = ActiveSheet.ChartObjects.Count
'm = ChartList * 15
'ActiveChart.ChartType = xlLine
'ActiveChart.ApplyCustomType ChartType:=xlBuiltIn, TypeName:= _
"Courbes à deux axes"
ActiveChart.SetSourceData Source:=Sheets("tableau").Range("A1:AM123"), _
PlotBy:=xlRows
ActiveChart.SeriesCollection.NewSeries
ActiveChart.SeriesCollection(1).XValues = _
"=(tableau!R1C3,tableau!R1C4,tableau!R1C6,tableau!R1C8,tableau!R1C10)"
'k = j + 1
'lignier2 = "=(tableau!R" & j & "C3," & "tableau!R" & j & "C4," _
& "tableau!R" & j & "C6," & "tableau!R" & j & "C8," & "tableau!R" & j & "C10)"
lignier1 = "=(tableau!R" & j & "C3," & "tableau!R" & j & "C4," _
lignier2 = "=(tableau!R" & j & "C5," & "tableau!R" & j & "C7," _
& "tableau!R" & j & "C9," & "tableau!R" & j & "C11," & "tableau!R" & j & "C13)"
'title2 = "=(tableau!R" & j & "C1," & "tableau!R" & j & "C2"
valide1 = Sheets("tableau").Cells(j, 1)
validier = Sheets("tableau").Cells(j, 2)
valide = valide1 & " " & validier
ActiveChart.SeriesCollection(1).Values = lignier1
ActiveChart.SeriesCollection(1).Name = "=""Em"""
ActiveChart.SeriesCollection(2).Values = lignier2
ActiveChart.SeriesCollection(2).Name = "=""Energie"""
ActiveChart.Location Where:=xlLocationAsObject, Name:="TBpforte"
Sheets("TBpforte").Select
ActiveChart.PlotArea.Select
ActiveWindow.Visible = False
With ActiveChart
.HasTitle = True
.ChartTitle.Characters.Text = valide
.Axes(xlCategory, xlPrimary).HasTitle = True
.Axes(xlCategory, xlPrimary).AxisTitle.Characters.Text = "mois"
.Axes(xlValue, xlPrimary).HasTitle = True
.Axes(xlValue, xlPrimary).AxisTitle.Characters.Text = "KW"
.Axes(xlCategory, xlSecondary).HasTitle = False
.Axes(xlValue, xlSecondary).HasTitle = False
End With
With ActiveChart.Axes(xlCategory)
.HasMajorGridlines = False
.HasMinorGridlines = False
End With
With ActiveChart.Axes(xlValue)
.HasMajorGridlines = True
End With
ActiveChart.HasDataTable = False
ActiveChart.Axes(xlCategory).Select
ActiveChart.Axes(xlValue).Select
ActiveChart.SeriesCollection(2).Select
With Selection.Border
.Weight = xlThin
.LineStyle = xlAutomatic
End With
With Selection
.MarkerBackgroundColorIndex = xlAutomatic
.MarkerForegroundColorIndex = 46
.MarkerStyle = xlDiamond
.Smooth = False
.MarkerSize = 5
.Shadow = False
End With
.ColorIndex = 46
.Weight = xlThin
.LineStyle = xlContinuous
End With
With Selection
.MarkerBackgroundColorIndex = 46
.Smooth = False
.MarkerSize = 5
.Shadow = False
End With
Next
Range("A1").Select
'Rows("1:15").Select
Rows("1:30").Select
Selection.Delete Shift:=xlUp
'Range("A1").Select
Columns("A:B").EntireColumn.Delete
'Columns("A:C").EntireColumn.Delete
End Function
[/code]
msg : "La méthode Select de la classe Axis a échoué."
ActiveChart.Axes(xlCategory).Select à déboder
pb : "ActiveChart.PlotArea.Select" ne marche pas sur une boucle
pour 1 seule courbe, c'est OK, sinon, non sur une boucle !
quelqu'un sait-il ?
Techneric
Internet Explorer 6.0
  1. voila ca ne repond pa a ton prblm mai j généré un pti code qui cree des graph sur plusieur feuilles ...
    Sub Macro3()
    ' Macro3 Macro
    ' Macro enregistrée le 02/06/2007 par Boomscud
    For i = 1 To 50
    Sheets("Feuil" & i & "").Select
    Range("A2:B5").Select
    Charts.Add
    ActiveChart.ChartType = xlLineMarkers
    ActiveChart.SetSourceData Source:=Sheets("Feuil" & i & "").Range("A2:B5"), PlotBy:= _
    xlColumns
    ActiveChart.Location Where:=xlLocationAsObject, Name:="Feuil" & i & ""
    ActiveChart.ApplyDataLabels Type:=xlDataLabelsShowNone, LegendKey:=False
    Next i
    End Sub
    si la feuille n'exisye pa la macro ne marche pa et c mn prblm pour le momen... si t'a la solution envoi la merci
      Moi aussi j'ai une macro qui crée des graphiques et les mêmes sur une seul feuille. Mon probleme est que je n'arrive pas à placer tout mes graphes comme je veux.
      Pouvez vous m'aider??
      1. j ai trouver ca sur un forum ca devrait t'aider reste a l adapter
        Dim ch As ChartObject
        Dim Grap As String
        Dim Hauteur As Long
        Dim X As Long
        Application.ScreenUpdating = False
        X = 250
        For Each ch In ActiveSheet.ChartObjects
        Grap = ch.Name
        ActiveSheet.ChartObjects(Grap).Activate
        ActiveSheet.Shapes(Grap).ScaleWidth 0.91, msoFalse, msoScaleFromTopLeft 'redéfinir dimensions
        ActiveSheet.Shapes(Grap).ScaleHeight 0.75, msoFalse, msoScaleFromTopLeft 'redéfinir dimensions
        Hauteur = ActiveSheet.Shapes(Grap).Height
        ActiveSheet.Shapes(Grap).Left = 1 'redéfinir position dans feuille
        ActiveSheet.Shapes(Grap).Top = X 'redéfinir position dans feuille
        X = X + Hauteur + 10
        Next ch
        Application.ScreenUpdating = True
        Range("a1").Selection
