Problème de drivers - Rapport whocrashed
J'ai de gros freezes allant jusqu'au BSOD et who crashed parle de drivers, je ne sais pas quoi faire...
Le rapport :
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Tue 24/04/2012 17:24:28 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042412-27549-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CC80)
Bugcheck code: 0xA0 (0x9, 0xFFFFFFFFC0000001, 0x1, 0x0)
Error: INTERNAL_POWER_ERROR
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the power policy manager experienced a fatal error.
This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Thu 19/04/2012 11:48:17 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041912-41090-01.dmp
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80002ADA866, 0xFFFFF88009E86ED0, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
On Mon 16/04/2012 20:22:12 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041612-30888-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x705C0)
Bugcheck code: 0x4E (0x2, 0x6ACD6, 0x15FFFF, 0x1)
Error: PFN_LIST_CORRUPT
Bug check description: This indicates that the page frame number (PFN) list is corrupted.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
On Mon 16/04/2012 18:04:02 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041612-26972-01.dmp
This was probably caused by the following module: fltmgr.sys (fltmgr+0x33099)
Bugcheck code: 0x19 (0x20, 0xFFFFF8A011AB0E00, 0xFFFFF8A011AB1100, 0x530010C)
Error: BAD_POOL_HEADER
file path: C:\Windows\system32\drivers\fltmgr.sys
product: Système d'exploitation Microsoft® Windows®
description: Gestionnaire de filtres de système de fichiers Microsoft
Bug check description: This indicates that a pool header is corrupt.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Mon 16/04/2012 09:15:57 GMT your computer crashed
crash dump file: C:\Windows\Minidump\041612-17768-01.dmp
Bugcheck code: 0x1A (0x41790, 0xFFFFFA8000843FC0, 0xFFFF, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred.
Le rapport :
Crash Dump Analysis
bonjour,
je sais pas si tu as tout lus ,mais c'est plus grave qu'un probleme de drivers je pense a voir ici et en français
entreprise : Microsoft Corporation
Description : noyau NT & système
Bug cocher description : cette vérification de bogue indique que le gestionnaire de puissance politique rencontrait une erreur fatale.
Ce problème peut être dû à un problème thermique.
L'accident a eu lieu dans le noyau Windows. Peut-être ce problème est causé par un autre conducteur qui ne peut être identifié à ce moment.
Le mardi 24 avril 2012 17:24:28 GMT votre ordinateur s'est écrasé
fichier de vidage : C:\Windows\memory.dmp
Cela a été probablement causé par le module suivant : ntkrnlmp.exe (nt !KeBugCheckEx + 0 x 0)
Le code d'erreur : 0xA0 (situées, 0xFFFFFFFFC0000001, 0 x 1, 0 x 0)
Erreur : INTERNAL_POWER_ERROR
Le jeu 19/04/2012 11:48:17 GMT votre ordinateur s'est écrasé
fichier de vidage : C:\Windows\Minidump\041912-41090-01.dmp
Cela a été probablement causé par le module suivant : ntoskrnl.exe (nt + 0x7CC80)
Le code d'erreur : 0x3B (0xC0000005, 0xFFFFF80002ADA866, 0xFFFFF88009E86ED0, 0 x 0)
Erreur : SYSTEM_SERVICE_EXCEPTION
chemin du fichier : C:\Windows\system32\ntoskrnl.exe
produit : système de d'exploitation Microsoft ® Windows ®
Bug cocher description : cela indique qu'une exception qui s'est passé lors de l'exécution d'une routine qui les transitions à partir de code non privilégié pour le code privilégié.
Cela semble être un bogue du pilote logiciel typique et n'est pas susceptible d'être causé par un problème matériel.
Le lundi 16 avril 2012 20:22:12 GMT votre ordinateur s'est écrasé
fichier de vidage : C:\Windows\Minidump\041612-30888-01.dmp
Cela a été probablement causé par le module suivant : ntoskrnl.exe (nt + 0x705C0)
Le code d'erreur : 0x4E (0 x 2, 0x6ACD6, 0x15FFFF, 0 x 1)
Erreur : PFN_LIST_CORRUPT
Bug cocher description : cela indique que la liste de nombre (PFN) page frame est endommagée.
Cela semble être un bogue du pilote logiciel typique et n'est pas susceptible d'être causé par un problème matériel. Cela peut être une affaire de corruption de la mémoire. Plus souvent une corruption de la mémoire se produit en raison d'erreurs de logiciel chez les conducteurs de voiturette, non en raison de modules de RAM défectueuses.
Le lundi 16 avril 2012 18:04:02 GMT votre ordinateur s'est écrasé
fichier de vidage : C:\Windows\Minidump\041612-26972-01.dmp
Cela a été probablement causé par le module suivant : fltmgr.sys (fltmgr + 0x33099)
Le code d'erreur : 0x19 (0 x 20, 0xFFFFF8A011AB0E00, 0xFFFFF8A011AB1100, 0x530010C)
Erreur : BAD_POOL_HEADER
chemin du fichier : C:\Windows\system32\drivers\fltmgr.sys
produit : Système d'exploitation Microsoft ® Windows ®
Description : Gestionnaire de filtres de système de fichiers Microsoft
Bug cocher description : cela indique qu'un en-tête de groupe est endommagé.
L'accident a eu lieu dans un module standard de Microsoft. La configuration de votre système peut être incorrecte. Peut-être ce problème est causé par un autre pilote sur votre système qui ne peut être identifié à ce moment.
Le lundi 16 avril 2012 09:15:57 GMT votre ordinateur s'est écrasé
fichier de vidage : C:\Windows\Minidump\041612-17768-01.dmp
Le code d'erreur : 0x1A (0x41790, 0xFFFFFA8000843FC0, 0xFFFF, 0 x 0)
Erreur : MEMORY_MANAGEMENT
Bug cocher description : cela indique qu'une erreur de gestion de mémoire grave s'est produite.
amclt a+ -
Ca chauferait trop dans le boitier ?
re,
a voir et lire ici::
https://fr.wikipedia.org/wiki/Noyau_de_syst%C3%A8me_d%27exploitation
amclt a+
