Minecraft Help
je vien de mettre a jours mes pilotes et mes drivers
et mon minecraft affiche l'erreur dans le post suivant merci de bien vouloir m'aider
cordiaement
  1. [spoiler]Bad video card drivers!
    Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
    This can usually be fixed by updating the video card drivers.
    --- BEGIN ERROR REPORT 7fe0271 --------
    Generated 24/03/12 22:41
    Minecraft: Minecraft 1.2.4
    OS: Windows Vista (x86) version 6.0
    Java: 1.7.0_03, Oracle Corporation
    VM: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
    LWJGL: 2.4.2
    [failed to get system properties (java.lang.NullPointerException)]
    org.lwjgl.LWJGLException: Pixel format not accelerated
    at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
    at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
    at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
    at org.lwjgl.opengl.Display.createWindow(Display.java:311)
    at org.lwjgl.opengl.Display.create(Display.java:856)
    at org.lwjgl.opengl.Display.create(Display.java:784)
    at org.lwjgl.opengl.Display.create(Display.java:765)
    at net.minecraft.client.Minecraft.a(SourceFile:230)
    at net.minecraft.client.Minecraft.run(SourceFile:650)
    at java.lang.Thread.run(Unknown Source)
    --- END ERROR REPORT d6433f67 ----------
    /spoiler
    1. je peux te dire que le problème vient de ta carte graphique. tu l'as mit a jour ?
