Erreur fatal java pour minecraft
A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x5222b4c7, pid=3744, tid=3628
# JRE version: 6.0_27-b07
# Java VM: Java HotSpot(TM) Client VM (20.2-b06 mixed mode windows-x86 )
# Problematic frame:
# C [atioglx1.dll+0x3fb4c7]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x49162400): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=3628, stack(0x49c70000,0x49cc0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x000000be
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x00000000, EDX=0x49cbf1a0
ESP=0x49cbf160, EBP=0x524f8040, ESI=0x00000000, EDI=0x5252e0a8
EIP=0x5222b4c7, EFLAGS=0x00010202
Top of Stack: (sp=0x49cbf160)
0x49cbf160: 5247e368 00000000 34343737 30454646
0x49cbf170: 30305c7d 4f5c3030 476e6570 72505c4c
0x49cbf180: 000000f0 00000065 00000000 00000000
0x49cbf190: 00000000 00000000 5224bc3b 49cbf1c8
0x49cbf1a0: 00000000 00000608 00000000 00008000
0x49cbf1b0: 00001000 00000000 00000000 00000000
0x49cbf1c0: 00000000 00000000 49cbf124 49cbf20c
0x49cbf1d0: 49cbf20c 7c91e920 7c920060 ffffffff
Instructions: (pc=0x5222b4c7)
0x5222b4a7: e8 74 f5 ff ff b8 01 00 00 00 5f 5d 5e 5b 83 c4
0x5222b4b7: 30 c2 04 00 cc cc cc cc cc 83 ec 30 53 56 8b f1
0x5222b4c7: 8a 86 be 00 00 00 84 c0 8b da 74 1c e8 68 07 00
0x5222b4d7: 00 8a 86 be 00 00 00 84 c0 74 0d 5e b8 c8 00 00
Register to memory mapping:
EAX=0x00000000 is an unknown value
EBX=0x00000000 is an unknown value
ECX=0x00000000 is an unknown value
EDX=0x49cbf1a0 is pointing into the stack for thread: 0x49162400
ESP=0x49cbf160 is pointing into the stack for thread: 0x49162400
EBP=0x524f8040 is an unknown value
ESI=0x00000000 is an unknown value
EDI=0x5252e0a8 is an unknown value
Stack: [0x49c70000,0x49cc0000], sp=0x49cbf160, free space=316k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [atioglx1.dll+0x3fb4c7] atiPPHSN+0x356217
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.WindowsContextImplementation.nCreate(Ljava/nio/ByteBuffer;Ljava/nio/IntBuffer;Ljava/nio/ByteBuffer;)Ljava/nio/ByteBuffer;+0
j org.lwjgl.opengl.WindowsContextImplementation.create(Lorg/lwjgl/opengl/PeerInfo;Ljava/nio/IntBuffer;Ljava/nio/ByteBuffer;)Ljava/nio/ByteBuffer;+10
j org.lwjgl.opengl.Context.<init>(Lorg/lwjgl/opengl/PeerInfo;Lorg/lwjgl/opengl/ContextAttribs;Lorg/lwjgl/opengl/Context;)V+104
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribs;)V+88
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;)V+9
j net.minecraft.client.Minecraft.a()V+151
j net.minecraft.client.Minecraft.run()V+6
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x49162400 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=3628, stack(0x49c70000,0x49cc0000)]
0x4913cc00 JavaThread "Timer hack thread" daemon [_thread_blocked, id=3640, stack(0x49680000,0x496d0000)]
0x00846800 JavaThread "DestroyJavaVM" [_thread_blocked, id=120, stack(0x008e0000,0x00930000)]
0x4909e800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=3604, stack(0x49300000,0x49350000)]
0x49000800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3188, stack(0x49250000,0x492a0000)]
0x48c9e400 JavaThread "AWT-Shutdown" [_thread_blocked, id=1000, stack(0x49200000,0x49250000)]
0x48c75800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3940, stack(0x48fb0000,0x49000000)]
0x48c38000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=2924, stack(0x48e80000,0x48ed0000)]
0x48c29400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=2256, stack(0x48e30000,0x48e80000)]
0x48c27c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=2932, stack(0x48de0000,0x48e30000)]
0x48c26400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2288, stack(0x48d90000,0x48de0000)]
0x48c19800 JavaThread "Finalizer" daemon [_thread_blocked, id=2872, stack(0x48d40000,0x48d90000)]
0x48c15000 JavaThread "Reference Handler" daemon [_thread_blocked, id=2560, stack(0x48cf0000,0x48d40000)]
Other Threads:
0x48c11000 VMThread [stack: 0x48ca0000,0x48cf0000] [id=1704]
0x48c4b800 WatcherThread [stack: 0x48ed0000,0x48f20000] [id=3928]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157248K, used 46590K [0x029e0000, 0x0d480000, 0x17f30000)
eden space 139776K, 33% used [0x029e0000, 0x0575fb68, 0x0b260000)
from space 17472K, 0% used [0x0b260000, 0x0b260000, 0x0c370000)
to space 17472K, 0% used [0x0c370000, 0x0c370000, 0x0d480000)
tenured generation total 349568K, used 0K [0x17f30000, 0x2d490000, 0x429e0000)
the space 349568K, 0% used [0x17f30000, 0x17f30000, 0x17f30200, 0x2d490000)
compacting perm gen total 12288K, used 8938K [0x429e0000, 0x435e0000, 0x469e0000)
the space 12288K, 72% used [0x429e0000, 0x4329a990, 0x4329aa00, 0x435e0000)
No shared spaces configured.
Code Cache [0x00960000, 0x00a68000, 0x02960000)
total_blobs=559 nmethods=335 adapters=160 free_code_cache=32486912 largest_free_block=0
Dynamic libraries:
0x00400000 - 0x00424000 C:\WINDOWS\system32\javaw.exe
0x7c910000 - 0x7c9c9000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c906000 C:\WINDOWS\system32\kernel32.dll
0x64d00000 - 0x64d34000 C:\Program Files\Alwil Software\Avast5\snxhk.dll
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee3000 C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
0x76320000 - 0x7633d000 C:\WINDOWS\system32\IMM32.DLL
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d7f0000 - 0x6da9f000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x76ae0000 - 0x76b0f000 C:\WINDOWS\system32\WINMM.dll
0x6d7a0000 - 0x6d7ac000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d320000 - 0x6d33f000 C:\Program Files\Java\jre6\bin\java.dll
0x6d7e0000 - 0x6d7ef000 C:\Program Files\Java\jre6\bin\zip.dll
0x6d000000 - 0x6d14c000 C:\Program Files\Java\jre6\bin\awt.dll
0x72f50000 - 0x72f76000 C:\WINDOWS\system32\WINSPOOL.DRV
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x774a0000 - 0x775de000 C:\WINDOWS\system32\ole32.dll
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x5b090000 - 0x5b0c8000 C:\WINDOWS\system32\uxtheme.dll
0x6d230000 - 0x6d27f000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x74690000 - 0x746dc000 C:\WINDOWS\system32\MSCTF.dll
0x75140000 - 0x7516e000 C:\WINDOWS\system32\msctfime.ime
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x76960000 - 0x76a16000 C:\WINDOWS\system32\USERENV.dll
0x6fee0000 - 0x6ff35000 C:\WINDOWS\system32\netapi32.dll
0x6d600000 - 0x6d613000 C:\Program Files\Java\jre6\bin\net.dll
0x719f0000 - 0x71a07000 C:\WINDOWS\system32\WS2_32.dll
0x719e0000 - 0x719e8000 C:\WINDOWS\system32\WS2HELP.dll
0x71990000 - 0x719d0000 C:\WINDOWS\System32\mswsock.dll
0x76ed0000 - 0x76ef7000 C:\WINDOWS\system32\DNSAPI.dll
0x76d10000 - 0x76d29000 C:\WINDOWS\system32\iphlpapi.dll
0x76f60000 - 0x76f68000 C:\WINDOWS\System32\winrnr.dll
0x76f10000 - 0x76f3d000 C:\WINDOWS\system32\WLDAP32.dll
0x76f70000 - 0x76f76000 C:\WINDOWS\system32\rasadhlp.dll
0x6d620000 - 0x6d629000 C:\Program Files\Java\jre6\bin\nio.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.DLL
0x49cc0000 - 0x49d2b000 C:\Documents and Settings\Perso\Application Data\.minecraft\bin\natives\lwjgl.dll
0x5f070000 - 0x5f13c000 C:\WINDOWS\system32\OPENGL32.dll
0x6cef0000 - 0x6cf11000 C:\WINDOWS\system32\GLU32.dll
0x736b0000 - 0x736fb000 C:\WINDOWS\system32\DDRAW.dll
0x73b10000 - 0x73b16000 C:\WINDOWS\system32\DCIMAN32.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x6d350000 - 0x6d356000 C:\Program Files\Java\jre6\bin\jawt.dll
0x69000000 - 0x694d9000 C:\WINDOWS\system32\atioglxx.dll
0x51e30000 - 0x524a8000 C:\WINDOWS\system32\atioglx1.dll
0x76ba0000 - 0x76bab000 C:\WINDOWS\system32\PSAPI.DLL
VM Arguments:
jvm_args: -Xms512m -Xmx1024m -Dsun.java2d.noddraw=true -Dsun.java2d.d3d=false -Dsun.java2d.opengl=false -Dsun.java2d.pmoffscreen=false
java_command: net.minecraft.LauncherFrame
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\system32\WindowsPowerShell\v1.0;c:\program files\java\jre6\bin
USERNAME=Perso
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 8 Stepping 1, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (1 cores per cpu, 1 threads per core) family 6 model 8 stepping 1, cmov, cx8, fxsr, mmx, sse, mmxext, 3dnow, 3dnowext
Memory: 4k page, physical 785908k(393252k free), swap 1923424k(1134884k free)
vm_info: Java HotSpot(TM) Client VM (20.2-b06) for windows-x86 JRE (1.6.0_27-b07), built on Jul 19 2011 01:04:42 by "java_re" with MS VC++ 7.1 (VS2003)
time: Sat Oct 08 12:45:57 2011
elapsed time: 3 seconds
quoi faire merci
Registers:
Other Threads:
Heap
Dynamic libraries:
VM Arguments:
USERNAME=Perso
OS=Windows_NT
quoi faire merci
ModérateurAs-tu vérifié s'il y avait infection ?
Je te suggère d'ouvrir un nouveau sujet dans le forum --> virus/sécurité pour qu'une analyse du système soit faite afin de vérifier s'il y a infection.
Bonne chance.
ModérateurBonjour,
Va dans démarrer, panneau de configuration, ajout et suppression, désinstalle tous les Java.
Redémarre le pc, ensuite va dans: C\program files et supprime Java .
Par la suite, lance --> CCleaner pour un nettoyage dans windows, applications et régistre.
Finalement installe la dernière version de --> Java offline
ben voila sa continu
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x5221b4c7, pid=2292, tid=3596
# JRE version: 7.0-b147
# Java VM: Java HotSpot(TM) Client VM (21.0-b17 mixed mode windows-x86 )
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# http://bugreport.sun.com/bugreport/crash.jsp
Current thread (0x49420400): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=3596, stack(0x49c60000,0x49cb0000)]
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x00000000, EDX=0x49caf370
ESP=0x49caf330, EBP=0x524e8040, ESI=0x00000000, EDI=0x5251e0a8
EIP=0x5221b4c7, EFLAGS=0x00010202
Top of Stack: (sp=0x49caf330)
0x49caf330: 5246e368 00000000 34343737 30454646
0x49caf340: 30305c7d 4f5c3030 476e6570 72505c4c
0x49caf350: 000000f0 00000065 00000000 00000000
0x49caf360: 00000000 00000000 5223bc3b 49caf398
0x49caf370: 00000000 00000608 00000000 00008000
0x49caf380: 00001000 00000000 00000000 00000000
0x49caf390: 00000000 00000000 49caf2f4 49caf3dc
0x49caf3a0: 49caf3dc 7c91e920 7c920060 ffffffff
Instructions: (pc=0x5221b4c7)
0x5221b4a7: e8 74 f5 ff ff b8 01 00 00 00 5f 5d 5e 5b 83 c4
0x5221b4b7: 30 c2 04 00 cc cc cc cc cc 83 ec 30 53 56 8b f1
0x5221b4c7: 8a 86 be 00 00 00 84 c0 8b da 74 1c e8 68 07 00
0x5221b4d7: 00 8a 86 be 00 00 00 84 c0 74 0d 5e b8 c8 00 00
EDX=0x49caf370 is pointing into the stack for thread: 0x49420400
ESP=0x49caf330 is pointing into the stack for thread: 0x49420400
EBP=0x524e8040 is an unknown value
EDI=0x5251e0a8 is an unknown value
Stack: [0x49c60000,0x49cb0000], sp=0x49caf330, free space=316k
=>0x49420400 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=3596, stack(0x49c60000,0x49cb0000)]
0x493fb400 JavaThread "Timer hack thread" daemon [_thread_blocked, id=3592, stack(0x49a70000,0x49ac0000)]
0x00866c00 JavaThread "DestroyJavaVM" [_thread_blocked, id=3272, stack(0x00910000,0x00960000)]
0x48fbd000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=188, stack(0x49700000,0x49750000)]
0x48e94c00 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3304, stack(0x491f0000,0x49240000)]
0x48e93400 JavaThread "AWT-Shutdown" [_thread_blocked, id=3744, stack(0x491a0000,0x491f0000)]
0x48e91c00 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3292, stack(0x49150000,0x491a0000)]
0x48de8000 JavaThread "Service Thread" daemon [_thread_blocked, id=3284, stack(0x490b0000,0x49100000)]
0x48dda000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=1728, stack(0x49060000,0x490b0000)]
0x48dd8400 JavaThread "Attach Listener" daemon [_thread_blocked, id=3312, stack(0x49010000,0x49060000)]
0x48dd7000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2780, stack(0x48fc0000,0x49010000)]
0x48cb0000 JavaThread "Finalizer" daemon [_thread_blocked, id=2644, stack(0x48d70000,0x48dc0000)]
0x48cab000 JavaThread "Reference Handler" daemon [_thread_blocked, id=3280, stack(0x48d20000,0x48d70000)]
Other Threads:
0x48ca5800 VMThread [stack: 0x48cd0000,0x48d20000] [id=3276]
0x48dfbc00 WatcherThread [stack: 0x49100000,0x49150000] [id=3288]
Heap
def new generation total 157248K, used 46584K [0x02a10000, 0x0d4b0000, 0x17f60000)
eden space 139776K, 33% used [0x02a10000, 0x0578e270, 0x0b290000)
from space 17472K, 0% used [0x0b290000, 0x0b290000, 0x0c3a0000)
to space 17472K, 0% used [0x0c3a0000, 0x0c3a0000, 0x0d4b0000)
tenured generation total 349568K, used 0K [0x17f60000, 0x2d4c0000, 0x42a10000)
the space 349568K, 0% used [0x17f60000, 0x17f60000, 0x17f60200, 0x2d4c0000)
compacting perm gen total 12288K, used 7800K [0x42a10000, 0x43610000, 0x46a10000)
the space 12288K, 63% used [0x42a10000, 0x431ae200, 0x431ae200, 0x43610000)
Code Cache [0x00990000, 0x00a98000, 0x02990000)
total_blobs=600 nmethods=355 adapters=178 free_code_cache=31717Kb largest_free_block=32478656
Dynamic libraries:
0x00400000 - 0x0042f000 C:\WINDOWS\system32\javaw.exe
0x78aa0000 - 0x78b5e000 C:\Program Files\Java\jre7\bin\msvcr100.dll
0x6d940000 - 0x6dc61000 C:\Program Files\Java\jre7\bin\client\jvm.dll
0x71a10000 - 0x71a1a000 C:\WINDOWS\system32\WSOCK32.dll
0x6d8d0000 - 0x6d8dc000 C:\Program Files\Java\jre7\bin\verify.dll
0x6d370000 - 0x6d390000 C:\Program Files\Java\jre7\bin\java.dll
0x6d920000 - 0x6d933000 C:\Program Files\Java\jre7\bin\zip.dll
0x6d000000 - 0x6d142000 C:\Program Files\Java\jre7\bin\awt.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x6d660000 - 0x6d674000 C:\Program Files\Java\jre7\bin\net.dll
0x6d680000 - 0x6d68f000 C:\Program Files\Java\jre7\bin\nio.dll
0x6d840000 - 0x6d860000 C:\Program Files\Java\jre7\bin\sunec.dll
0x6d2c0000 - 0x6d2ea000 C:\Program Files\Java\jre7\bin\fontmanager.dll
0x6d870000 - 0x6d8a1000 C:\Program Files\Java\jre7\bin\t2k.dll
0x49cb0000 - 0x49d1b000 C:\Documents and Settings\Perso\Application Data\.minecraft\bin\natives\lwjgl.dll
0x6d3a0000 - 0x6d3a6000 C:\Program Files\Java\jre7\bin\jawt.dll
0x51e20000 - 0x52498000 C:\WINDOWS\system32\atioglx1.dll
VM Arguments:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\system32\WindowsPowerShell\v1.0;c:\program files\java\jre7\bin
USERNAME=Perso
OS=Windows_NT
CPU:total 1 (1 cores per cpu, 1 threads per core) family 6 model 8 stepping 1, cmov, cx8, fxsr, mmx, sse, mmxext, 3dnowpref
Memory: 4k page, physical 785908k(315696k free), swap 1923424k(1047420k free)
vm_info: Java HotSpot(TM) Client VM (21.0-b17) for windows-x86 JRE (1.7.0-b147), built on Jun 27 2011 02:25:52 by "java_re" with unknown MS VC++:1600
time: Sat Oct 08 13:49:14 2011
elapsed time: 12 seconds -
ok merci j'y vais a plus tard
ModérateurDe rien,
Bonne journée.
