Probleme: minecraft !?...
Quand je démare minecraft je rentre mon pseudo et mon mot de passe et sa mafiche sa:
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 25/04/11 11:52
Minecraft: Minecraft Beta 1.2_01
OS: Windows 7 (x86) version 6.1
Java: 1.6.0_24, Sun Microsystems Inc.
VM: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
LWJGL: 2.4.2
[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:280)
at net.minecraft.client.Minecraft.run(SourceFile:643)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT d4ed2b70 ------
comment faire pour jouer !?
merci...
  1. C'est Trés Simple As-Tu Payer Pour Y jouer ??
    1. C'est Pasque Ta Pris La Version 1.2 et il ont fait la version 1.3 sinon si c Pas Sa , Quand tu ve dans le dossier ta - Minecraft et - Minecraft SP va sur Minecraft SP
    2. ok
      je vai esséyer....
    3. Alors sa Marche ??
