Problème java
Bonjour , je reçois sans arrets un message lorsque je joue à des jeux sur le site pogo " java introuvable ou ne fonctionne pas " et à chaques fois je suis obligé de le réinstaller et c'est franchement chiant à la longue.
Et ce coup ci , j'ai reçu un message sur mon bureau ( bloc note ) avec ça ( je suis sur xp avec ie8 )
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x3fd29851, pid=4024, tid=2908
# JRE version: 6.0_22-b04
# Java VM: Java HotSpot(TM) Client VM (17.1-b03 mixed mode, sharing windows-x86 )
# Problematic frame:
# C [mshtml.dll+0x249851]
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x0c1fc400): JavaThread "Thread-0" [_thread_in_native, id=2908, stack(0x0c600000,0x0c700000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x000000f0
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x00000038, EDX=0x2ab23058
ESP=0x0c6ff824, EBP=0x0c6ff83c, ESI=0x03445230, EDI=0x7c8097e0
EIP=0x3fd29851, EFLAGS=0x00010246
Top of Stack: (sp=0x0c6ff824)
0x0c6ff824: 00000000 03445230 2ab1b4c8 3fbe0640
0x0c6ff834: 03445230 00000000 0c6ff850 3fbdddc9
0x0c6ff844: 03445230 0c1fc400 034df810 0c6ff860
0x0c6ff854: 3fbba576 03445230 2ab1b4c8 0c6ff8ac
0x0c6ff864: 6d403099 034df810 09589f37 0c1fc518
0x0c6ff874: 0c6ff8b4 034df810 00000000 00000000
0x0c6ff884: 2f554400 00000000 0c6ff88c 00000000
0x0c6ff894: 0c6ff8c0 2ab23058 00000000 2ab1b4c8
Instructions: (pc=0x3fd29851)
0x3fd29841: 14 2b 01 40 8b 3d f4 13 ae 3f 8b f1 ff d7 33 db
0x3fd29851: 39 98 f0 00 00 00 74 1f ff 35 14 2b 01 40 ff d7
Stack: [0x0c600000,0x0c700000], sp=0x0c6ff824, free space=3fe0c6ff358k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [mshtml.dll+0xfddc9]
C [mshtml.dll+0xda576]
C [jp2iexp.dll+0x3099]
j sun.plugin2.main.server.IExplorerPlugin.javaScriptReleaseObject(Lsun/plugin2/liveconnect/BrowserSideObject;)V+4
j sun.plugin2.main.server.LiveConnectSupport$PerPluginInfo.releaseAllObjects()V+34
j sun.plugin2.main.server.LiveConnectSupport.shutdown(I)V+42
j sun.plugin2.main.server.JVMInstance.unregisterApplet(I)V+63
j sun.plugin2.main.server.JVMInstance.dispose()V+67
j sun.plugin2.main.server.JVMInstance.access$2600(Lsun/plugin2/main/server/JVMInstance;)V+1
j sun.plugin2.main.server.JVMInstance$Listener.jvmExited(Lsun/plugin2/jvm/JVMLauncher;)V+86
j sun.plugin2.jvm.JVMLauncher.fireJVMExited()V+31
j sun.plugin2.jvm.JVMLauncher.access$300(Lsun/plugin2/jvm/JVMLauncher;)V+1
j sun.plugin2.jvm.JVMLauncher$JVMWatcher.run()V+50
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
V [jvm.dll+0xf3a9c]
V [jvm.dll+0x186591]
V [jvm.dll+0xf3c67]
V [jvm.dll+0xf3cdd]
V [jvm.dll+0x11da00]
V [jvm.dll+0x1e7004]
V [jvm.dll+0x185f3c]
C [MSVCR71.dll+0x9565]
C [KERNEL32.dll+0xb729]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.plugin2.main.server.IExplorerPlugin.iUnknownRelease(J)V+0
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x0c1fc400 JavaThread "Thread-0" [_thread_in_native, id=2908, stack(0x0c600000,0x0c700000)]
0x0b6e2000 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=2256, stack(0x0bf90000,0x0c090000)]
0x0b6c6400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3916, stack(0x0bd90000,0x0be90000)]
0x0b6b7800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3480, stack(0x0bc90000,0x0bd90000)]
0x0b6b5c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=1780, stack(0x0bb90000,0x0bc90000)]
0x0b6b4800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2444, stack(0x0ba90000,0x0bb90000)]
0x0b6b1000 JavaThread "Finalizer" daemon [_thread_blocked, id=3172, stack(0x0b990000,0x0ba90000)]
0x0b6ac400 JavaThread "Reference Handler" daemon [_thread_blocked, id=2528, stack(0x0b890000,0x0b990000)]
0x02747800 JavaThread "main" [_thread_in_native, id=1924, stack(0x08ce0000,0x08ee0000)]
Other Threads:
0x0b6ab000 VMThread [stack: 0x0b790000,0x0b890000] [id=960]
0x0b6d9800 WatcherThread [stack: 0x0be90000,0x0bf90000] [id=3056]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 2432K, used 1461K [0x28b10000, 0x28db0000, 0x295b0000)
eden space 2176K, 67% used [0x28b10000, 0x28c7d640, 0x28d30000)
from space 256K, 0% used [0x28d30000, 0x28d30000, 0x28d70000)
to space 256K, 0% used [0x28d70000, 0x28d70000, 0x28db0000)
tenured generation total 5504K, used 0K [0x295b0000, 0x29b10000, 0x2ab10000)
the space 5504K, 0% used [0x295b0000, 0x295b0000, 0x295b0200, 0x29b10000)
compacting perm gen total 12288K, used 850K [0x2ab10000, 0x2b710000, 0x2eb10000)
the space 12288K, 6% used [0x2ab10000, 0x2abe4940, 0x2abe4a00, 0x2b710000)
ro space 10240K, 51% used [0x2eb10000, 0x2f03baf8, 0x2f03bc00, 0x2f510000)
rw space 12288K, 54% used [0x2f510000, 0x2fba76d8, 0x2fba7800, 0x30110000)
Dynamic libraries:
0x00400000 - 0x0049c000 C:\Program Files\Internet Explorer\iexplore.exe
0x7c910000 - 0x7c9c9000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c906000 C:\WINDOWS\system32\KERNEL32.dll
0x60000000 - 0x6003e000 C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_69\midas32.dll
0x61000000 - 0x61027000 C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_69\plugin_base.m32
0x67000000 - 0x67048000 C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_69\plugin_nt.m32
0x64000000 - 0x64021000 C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_69\plugin_registry.m32
0x62000000 - 0x6202e000 C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_69\plugin_extra.m32
0x65000000 - 0x6501a000 C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_69\plugin_net.m32
0x63000000 - 0x630a6000 C:\Program Files\BitDefender\BitDefender 2010\Active Virus Control\midas32-v2_69\plugin_fragments.m32
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee3000 C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x7c9d0000 - 0x7d1f5000 C:\WINDOWS\system32\SHELL32.dll
0x774a0000 - 0x775de000 C:\WINDOWS\system32\ole32.dll
0x40b40000 - 0x40d28000 C:\WINDOWS\system32\iertutil.dll
0x45180000 - 0x452b3000 C:\WINDOWS\system32\urlmon.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x5cea0000 - 0x5cec6000 C:\WINDOWS\system32\ShimEng.dll
0x715c0000 - 0x71639000 C:\WINDOWS\AppPatch\AcLayers.DLL
0x76960000 - 0x76a16000 C:\WINDOWS\system32\USERENV.dll
0x72f50000 - 0x72f76000 C:\WINDOWS\system32\WINSPOOL.DRV
0x76320000 - 0x7633d000 C:\WINDOWS\system32\IMM32.DLL
0x00030000 - 0x00039000 C:\WINDOWS\system32\LPK.DLL
0x753c0000 - 0x7542b000 C:\WINDOWS\system32\USP10.dll
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
0x58b50000 - 0x58bea000 C:\WINDOWS\system32\comctl32.dll
0x40d30000 - 0x417c5000 C:\WINDOWS\system32\IEFRAME.dll
0x76340000 - 0x7638a000 C:\WINDOWS\system32\comdlg32.dll
0x00cb0000 - 0x00cb6000 C:\Program Files\Internet Explorer\xpshims.dll
0x5b090000 - 0x5b0c8000 C:\WINDOWS\system32\uxtheme.dll
0x74690000 - 0x746dc000 C:\WINDOWS\system32\MSCTF.dll
0x010b0000 - 0x010c3000 C:\WINDOWS\system32\SynTPFcs.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x01980000 - 0x01c5a000 C:\WINDOWS\system32\xpsp2res.dll
0x76f80000 - 0x76fff000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77000000 - 0x770d4000 C:\WINDOWS\system32\COMRes.dll
0x778e0000 - 0x779d8000 C:\WINDOWS\system32\SETUPAPI.dll
0x45380000 - 0x453c0000 C:\Program Files\Internet Explorer\ieproxy.dll
0x404a0000 - 0x40586000 C:\WINDOWS\system32\WININET.dll
0x01f90000 - 0x01f99000 C:\WINDOWS\system32\Normaliz.dll
0x719f0000 - 0x71a07000 C:\WINDOWS\system32\ws2_32.dll
0x719e0000 - 0x719e8000 C:\WINDOWS\system32\WS2HELP.dll
0x77b50000 - 0x77b72000 C:\WINDOWS\system32\appHelp.dll
0x76e90000 - 0x76ecc000 C:\WINDOWS\system32\RASAPI32.dll
0x76e40000 - 0x76e52000 C:\WINDOWS\system32\rasman.dll
0x6fee0000 - 0x6ff35000 C:\WINDOWS\system32\NETAPI32.dll
0x76e60000 - 0x76e8f000 C:\WINDOWS\system32\TAPI32.dll
0x76e30000 - 0x76e3e000 C:\WINDOWS\system32\rtutils.dll
0x76ae0000 - 0x76b0f000 C:\WINDOWS\system32\WINMM.dll
0x77c40000 - 0x77c65000 C:\WINDOWS\system32\msv1_0.dll
0x76730000 - 0x7673c000 C:\WINDOWS\system32\cryptdll.dll
0x76d10000 - 0x76d29000 C:\WINDOWS\system32\iphlpapi.dll
0x72220000 - 0x72225000 C:\WINDOWS\system32\sensapi.dll
0x71990000 - 0x719d0000 C:\WINDOWS\system32\mswsock.dll
0x023a0000 - 0x023f9000 C:\WINDOWS\system32\hnetcfg.dll
0x719d0000 - 0x719d8000 C:\WINDOWS\System32\wshtcpip.dll
0x75d30000 - 0x75dc1000 C:\WINDOWS\system32\MLANG.dll
0x76f70000 - 0x76f76000 C:\WINDOWS\system32\rasadhlp.dll
0x76ed0000 - 0x76ef7000 C:\WINDOWS\system32\DNSAPI.dll
0x02450000 - 0x02475000 C:\Program Files\Bonjour\mdnsNSP.dll
0x75140000 - 0x7516e000 C:\WINDOWS\system32\msctfime.ime
0x6d430000 - 0x6d43c000 C:\Program Files\Java\jre6\bin\jp2ssv.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\MSVCR71.dll
0x77210000 - 0x772c1000 C:\WINDOWS\system32\SXS.DLL
0x71ca0000 - 0x71cbb000 C:\WINDOWS\system32\actxprxy.dll
0x3fae0000 - 0x40092000 C:\WINDOWS\system32\mshtml.dll
0x02950000 - 0x02979000 C:\WINDOWS\system32\msls31.dll
0x76ba0000 - 0x76bab000 C:\WINDOWS\system32\PSAPI.DLL
0x72ea0000 - 0x72f0f000 C:\WINDOWS\system32\ieapfltr.dll
0x779e0000 - 0x77a77000 C:\WINDOWS\system32\CRYPT32.dll
0x77a80000 - 0x77a92000 C:\WINDOWS\system32\MSASN1.dll
0x74660000 - 0x7468a000 C:\WINDOWS\system32\msimtf.dll
0x403e0000 - 0x40494000 C:\WINDOWS\system32\jscript.dll
0x10000000 - 0x105e4000 C:\WINDOWS\system32\Macromed\Flash\Flash10l.ocx
0x73e60000 - 0x73ebc000 C:\WINDOWS\system32\DSOUND.dll
0x73a80000 - 0x73a95000 C:\WINDOWS\system32\mscms.dll
0x431d0000 - 0x431ff000 C:\WINDOWS\system32\iepeers.dll
0x1b000000 - 0x1b00c000 C:\WINDOWS\system32\ImgUtil.dll
0x1b060000 - 0x1b06e000 C:\WINDOWS\system32\pngfilt.dll
0x76310000 - 0x76315000 C:\WINDOWS\system32\msimg32.dll
0x35c50000 - 0x35c89000 C:\WINDOWS\system32\Dxtrans.dll
0x76ac0000 - 0x76ad1000 C:\WINDOWS\system32\ATL.DLL
0x6d8f0000 - 0x6d8fa000 C:\WINDOWS\system32\ddrawex.dll
0x736b0000 - 0x736fb000 C:\WINDOWS\system32\DDRAW.dll
0x73b10000 - 0x73b16000 C:\WINDOWS\system32\DCIMAN32.dll
0x35cb0000 - 0x35d07000 C:\WINDOWS\system32\Dxtmsft.dll
0x76be0000 - 0x76c0e000 C:\WINDOWS\system32\WINTRUST.dll
0x76c40000 - 0x76c68000 C:\WINDOWS\system32\IMAGEHLP.dll
0x72c70000 - 0x72c79000 C:\WINDOWS\system32\wdmaud.drv
0x72c60000 - 0x72c68000 C:\WINDOWS\system32\msacm32.drv
0x77bb0000 - 0x77bc5000 C:\WINDOWS\system32\MSACM32.dll
0x77ba0000 - 0x77ba7000 C:\WINDOWS\system32\midimap.dll
0x05290000 - 0x05307000 C:\WINDOWS\system32\deployJava1.dll
0x71a10000 - 0x71a1a000 C:\WINDOWS\system32\WSOCK32.dll
0x76790000 - 0x767b8000 C:\WINDOWS\system32\schannel.dll
0x4eb80000 - 0x4ed2b000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6001.22319_x-ww_f0b4c2df\gdiplus.dll
0x73890000 - 0x73960000 C:\WINDOWS\system32\D3DIM700.DLL
0x47060000 - 0x47081000 C:\WINDOWS\system32\XmlLite.dll
0x73250000 - 0x732ba000 C:\WINDOWS\system32\vbscript.dll
0x748f0000 - 0x74a13000 C:\WINDOWS\system32\msxml3.dll
0x6d120000 - 0x6d128000 C:\WINDOWS\system32\dispex.dll
0x6d400000 - 0x6d41e000 C:\Program Files\Java\jre6\bin\jp2iexp.dll
0x76f60000 - 0x76f68000 C:\WINDOWS\System32\winrnr.dll
0x76f10000 - 0x76f3d000 C:\WINDOWS\system32\WLDAP32.dll
0x09290000 - 0x09537000 C:\PROGRA~1\Java\jre6\bin\client\jvm.dll
0x6d7a0000 - 0x6d7ac000 C:\PROGRA~1\Java\jre6\bin\verify.dll
0x6d320000 - 0x6d33f000 C:\PROGRA~1\Java\jre6\bin\java.dll
0x6d280000 - 0x6d288000 C:\PROGRA~1\Java\jre6\bin\hpi.dll
0x6d7e0000 - 0x6d7ef000 C:\PROGRA~1\Java\jre6\bin\zip.dll
0x6d420000 - 0x6d426000 C:\Program Files\Java\jre6\bin\jp2native.dll
0x6d1d0000 - 0x6d1e3000 C:\Program Files\Java\jre6\bin\deploy.dll
0x6d600000 - 0x6d613000 C:\Program Files\Java\jre6\bin\net.dll
0x6d620000 - 0x6d629000 C:\Program Files\Java\jre6\bin\nio.dll
0x6d6a0000 - 0x6d6e6000 C:\Program Files\Java\jre6\bin\regutils.dll
0x0c0a0000 - 0x0c1ea000 C:\Program Files\Java\jre6\bin\awt.dll
VM Arguments:
jvm_args: -Xbootclasspath/a:C:\PROGRA~1\Java\jre6\lib\deploy.jar;C:\PROGRA~1\Java\jre6\lib\javaws.jar;C:\PROGRA~1\Java\jre6\lib\plugin.jar -Xmx32m -Djava.awt.headless=true -Dkernel.background.download=false -Dkernel.download.dialog=false -XX:MaxDirectMemorySize=64m
java_command: <unknown>
Launcher Type: generic
Environment Variables:
CLASSPATH=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip
PATH=C:\Program Files\Internet Explorer;;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI Control Panel;C:\Program Files\QuickTime\QTSystem\
USERNAME=Vialard
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 47 Stepping 2, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (1 cores per cpu, 1 threads per core) family 15 model 47 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnow, 3dnowext
Memory: 4k page, physical 522736k(221964k free), swap 1275328k(487292k free)
vm_info: Java HotSpot(TM) Client VM (17.1-b03) for windows-x86 JRE (1.6.0_22-b04), built on Sep 15 2010 00:56:36 by "java_re" with MS VC++ 7.1 (VS2003)
time: Mon Nov 22 20:15:47 2010
elapsed time: 2981 seconds
Que dois je faire svp ?
    Va dans démarrer, panneau de configuration, ajout et suppression, désinstalle tous les Java.
    Redémarre le pc, ensuite va dans: C\program files et supprime Java .
    Par la suite, lance --> CCleaner pour un nettoyage dans windows, applications et régistre.
    Finalement, installe la dernière version de --> Java offline .
    L'être humain est à son mieux quand les choses sont au pire.
    1. bonjour ekim55 , tout d'abord merci pour l'aide que tu m'apporte.
      J'ai bien fais ce que tu me disais sauf que dans : C\program files il n'y avais pas de dossier java , donc j'ai ensuite fais ccleaner , dois je poursuivre avec la réinstallation ou le fameux dossier java est ailleurs ?
      1. Salut , ça n'a malheureusement pas résolue mon problème , dés que j'eteins mon pc , ça ne marche pas
          Désinstalle de nouveau java avec --> Javara.
          Après installation, lance-le, clique sur effacer les anciennes versions, ensuite clique sur autres options, coche-les tous et effacer.
          Va dans: C\program files et supprime java, si présent.
          Lance CCleaner pour un nettoyage.
          Par la suite, la procédure qui est proposée est de supprimer les clés dans le régistre.
          Avant de procéder, il est souhaitable de faire une sauvegarde du --> régistre.
          Ensuite va dans démarrer, exécuter, tape: regedit et OK.
          En haut, clique sur édition, rechercher (Ctrl+F), tape: java, coche les cases clés, valeurs, données et fais suivant.
          La recherche commence, quand un fichier apparait, supprime tout ce qui est rapport à java et regarde aussi dans le volet droit, ensuite fais F3 pour continuer la recherche et fais de même jusqu'à la fin de la recherche.
          Essaie de nouveau d'installer le --> java offline.
            Y a pas de quoi,
            N'oublie pas de mettre le sujet résolu.
            Bonne journée.
