Problème Latex
Je ne comprends pas mon erreur, car la ligne 72 ou il y a trois erreurs est vide.
Message d'erreur :
! Missing $ inserted.
<inserted text>
l.72
I've inserted a begin-math/end-math symbol since I think
you left one out. Proceed, with fingers crossed.
! Missing } inserted.
<inserted text>
l.72
I've inserted something that you may have forgotten.
(See the <inserted text> above.)
With luck, this will get me unwedged. But if you
really didn't forget anything, try typing '2' now; then
my insertion and my current dilemma will both disappear.
Underfull \hbox (badness 10000) in paragraph at lines 66--72
! Extra }, or forgotten \endgroup.
\par ...m \@noitemerr {\@@par }\fi \else {\@@par }
\fi
l.72
I've deleted a group-closing symbol because it seems to be
spurious, as in '$x}$'. But perhaps the } is legitimate and
you forgot something else, as in '\hbox{$x}'. In such cases
the way to recover is to insert both the forgotten and the
deleted material, e.g., by typing 'I$}'.
Savez-vous pourquoi ils affichent ce message? Merci
    sans ton code source, très difficile de t'aider.
    D'après ce que je lit, soit tu as utiliser un "$" dans ton texte, soit il manque une accolade fermante.
    En tout cas, je pense qu'il y a des erreurs.
