Probleme sur mon systeme sysfader et key:HKEY
explique moi ça svp j win sp3 et IE8
Scan saved at 20:37:24, on 09/08/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.20861)
Boot mode: Normal
Running processes:
C:\WINDOWS.0\System32\smss.exe
C:\WINDOWS.0\system32\winlogon.exe
C:\WINDOWS.0\system32\services.exe
C:\WINDOWS.0\system32\lsass.exe
C:\WINDOWS.0\system32\svchost.exe
C:\WINDOWS.0\System32\svchost.exe
C:\WINDOWS.0\system32\spoolsv.exe
C:\WINDOWS.0\Explorer.EXE
C:\Program Files\IDT\WDM\sttray.exe
C:\WINDOWS.0\system32\wuauclt.exe
E:\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.google.fr/?gws_rd=ssl
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [SysTrayApp] %ProgramFiles%\IDT\WDM\sttray.exe
O4 - HKCU\..\Run: [EPSON TX100 Series] C:\WINDOWS.0\System32\spool\DRIVERS\W32X86\3\E_FATIEDP.EXE /FU "C:\WINDOWS.0\TEMP\E_S6C.tmp" /EF "HKCU"
O4 - HKUS\S-1-5-20\..\RunOnce: [JkDefrag] rundll32 advpack.dll,LaunchINFSection JKDEFRAG.INF,RunOnce,1,N (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-20\..\RunOnce: [SweetRegistry] rundll32 advpack.dll,LaunchINFSection SweetReg.inf,PerUserStub (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-18\..\RunOnce: [JkDefrag] rundll32 advpack.dll,LaunchINFSection JKDEFRAG.INF,RunOnce,1,N (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [JkDefrag] rundll32 advpack.dll,LaunchINFSection JKDEFRAG.INF,RunOnce,1,N (User 'Default user')
O4 - Startup: Notification de cadeaux MSN.lnk = C:\Documents and Settings\Administrateur\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS.0\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS.0\Network Diagnostic\xpnetdiag.exe
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/...
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/...
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{761B44CA-F77C-48E7-931B-C702550D71DC}: NameServer = 208.67.222.222 208.67.220.220
O23 - Service: Audio Service (STacSV) - Unknown owner - j:\sound\idt\wdm\vista\STacSV.exe (file missing)
End of file - 3092 bytes
35 réponses
Analyse des échanges autour d'un log HijackThis sur Windows XP SP3 et IE7/IE8, montrant des entrées réseau et des services potentiellement indésirables et une préoccupation de sécurité. Des réponses suggèrent que le système a pu être installé par-dessus une version antérieure, proposent d'utiliser Malwarebytes et affichent des procédures pour nettoyer le poste, puis recommandent d'essayer des navigateurs alternatifs. En parallèle, certains échanges évoquent des problèmes matériels, comme un disque dur ou de la mémoire, et d'autres proposent des démarches pas à pas, incluant des liens et des tutoriels. Une des contributions montre des conseils concrets pour vérifier les sources, télécharger un outil de diagnostic et expliquer que les symptômes peuvent provenir d'un problème de configuration ou de mémoire.
    Vous pouvez répéter la question ?
    1. Salut carpoulou,
      J'ai un problème dans mon ordinateur personnel et avait pensé à ce problème est un bogue dans le système de note que les deux arrêts de sa propre initiative et sans avertissement, et de me montrer une page bleu. C'est la première chose que e La seconde est l'émergence de tout le temps une boîte de dialogue me disant que la mémoire est pleine ou et ne peut pas reed tels qu'ils apparaissent dans cette boîte, le problème est dans deux iexplore.exe ou explore.exe et sysfader.exe, En outre, depuis l'apparition de ce problème je ne peux pas télécharger un programme De l'Internet et deux pour Dans une tentative pour résoudre le problème que vous voulez installer Windows Vista ou Windows 7, mais , a rejeté et pas seulement accepter préalablement sp2 ou sp3 important que je ne sais pas quoi faire et toutes mes tentatives a échoué, et en dépit de mettre les problèmes sur le forum n'a pas rencontré de solution, sachant que de nombreuses personnes Souffrent de la même problème ......
        On va d'abord regarder si une infection est à l'origine de tes problèmes.
        Ta version de Windows est-elle légale ?
        Pour établir un diagnostic plus en profondeur de ton PC :
        Télécharge Random's System Information Tool (RSIT) de random/random et enregistre l'exécutable sur le Bureau.
        = = = = >>> En cliquant ici <<< = = = =
        * Double clique sur RSIT.exe pour le lancer.
        * Une première fenêtre s'ouvre, clique alors sur Continue (Disclaimer).
        * Si la dernière version de HijackThis n'est pas détectée sur ton PC, RSIT le téléchargera et te demandera d'accepter la licence.
        * Lorsque l'analyse sera terminée, deux fichiers texte s'ouvriront (probablement avec le bloc-notes).
        * Poste le contenu de log.txt.
        Si tu as des soucis pour envoyer le fichier, héberge-le sur cijoint.fr.
        Aide en images.
        1. voila chére amis , j'attend ta repence
          http://cijoint.fr/index.php
            Regarde la vidéo pour faire exactement pareil.
            Ce lien est le lien du site, je l'ai déjà, merci.
            1. je suis trés trés désolé j'arrve pas trouve ce vidéo , il ce trouve sur la page , mes il marche pas f moi une difinition par etape svp aide moi
                Clique sur Parcourir
                Sélectionne ton fichier sur ton ordinateur
                Clique sur "Cliquez ici pour déposer le fichier"
                Un lien va s'afficher juste en-dessus de ce bouton :
                Le dépôt du fichier log.txt a été réalisé avec succès !
                Veuillez noter le lien ci-dessous qui vous permettra d'accéder à ce fichier.
                C'est ce même lien que vous devrez transmettre à vos correspondants
                http://www.cijoint.fr/cjlink.php?file=.....
                C'est ce lien qu'il faut m'envoyer.
                1. merci voila c fait
                  http://www.cijoint.fr/cjlink.php?file=cj201008/cijBH9uvSb.txt
                    Je regarderai ce soir car là j'suis au boulot.
                    Tu as installé ton Windows par-dessus un autre ?!
                      Télécharge Malwarebytes' Anti-Malware
                      - Enregistre le sur le bureau
                      - Double clique sur le fichier téléchargé pour lancer le processus d'installation
                      - Lorsqu'il te le sera demandé, mets à jour Malwarebytes anti malware
                      - Si le pare-feu demande l'autorisation de se connecter pour malwarebytes, acceptes
                      - Une fois la mise à jour terminée, ferme Malwarebytes
                      - Double-clique sur l'icône de malwarebytes pour le relancer
                      - Dans l'onglet, Recherche, probablement ouvert par défaut,
                      - Sélectionne Exécuter un examen complet
                      - Clique sur Rechercher
                      - Le scan démarre
                      - A la fin de l'analyse, un message s'affiche : L'examen s'est terminé normalement. Cliquez sur `Afficher les résultats' pour afficher tous les objets trouvés.
                      - Clique sur Ok pour poursuivre.
                      - Si des malwares ont été détectés, cliques sur Afficher les résultats
                      - Sélectionnes tout (ou laisses cochés) et cliques sur Supprimer la sélection Malwarebytes va détruire les fichiers et clés de registre et en mettre une copie dans la quarantaine.
                      - Malwarebytes va ouvrir le bloc-notes et y copier le rapport d'analyse.
                      - Rends toi dans l'onglet rapport/log
                      - Tu clique dessus pour l'afficher.
                      - Une fois affiché, cliques sur édition en haut du bloc notes, et puis sur sélectionner tout
                      - Tu recliques sur édition et puis sur copier et tu reviens sur le forum et dans ta réponse
                      - Tu clique droit dans le cadre de la réponse et coller
                      Si tu as besoin d'aide regarde ce tutorial ICI
                      1. Salut Crapoulou,
                        j telecharger ce vous m'avi dis mes dans la cénne de mise ajour et dans le 100% elle s'afiche cette fenetre me dis :
                        une erreur s'ese produit veuillez transmettre ce code d'erreur à notre equipe de support
                        MBAM_Error_load_database(0.5)
                        j essai plus de 06 fois mes c le mémé proble
                        en peut pas essai avec un autre logiciel ou programme ?!
                          tu le désinstalles
                          tu fais un bon nettoyage avec CCleaner
                          * tuto et téléchargement pour ccleaner : https://www.malekal.com/tutoriel-ccleaner/
                          https://www.01net.com/telecharger/windows/Utilitaire/nettoyeurs_et_installeurs/fiches/46630.html
                          https://www.ccleaner.com/ccleaner/download
                          http://perso.orange.fr/jesses/Docs/Logiciels/CCleaner.htm
                          https://www.pcastuces.com/pratique/securite/nettoyer_windows/page1.htm­page1.htm
                          ( attention de ne pas installer la Yahoo ToolBar qui ne sert à rien )
                          lors de l'utilisation de la partie nettoyage de la base de registre la première fois , prendre "Tenter de réparer" plusieurs fois en relançant CCleaner
                          et tu réinstalles MBAM
                          si tu as toujours des ennuis pour la mise à jour , télécharges ce fichier
                          http://mbam.malwarebytes.org/database/mbam-rules.exe
                          dans ce cas , double cliquer sur mbam-rules.exe pour lancer la mise à jour , et relancer MBAM
                      • 1
                      • 2
