Probleme sur mon systeme sysfader et key:HKEY
explique moi ça svp j win sp3 et IE8
Scan saved at 20:37:24, on 09/08/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.20861)
Boot mode: Normal
Running processes:
C:\WINDOWS.0\System32\smss.exe
C:\WINDOWS.0\system32\winlogon.exe
C:\WINDOWS.0\system32\services.exe
C:\WINDOWS.0\system32\lsass.exe
C:\WINDOWS.0\system32\svchost.exe
C:\WINDOWS.0\System32\svchost.exe
C:\WINDOWS.0\system32\spoolsv.exe
C:\WINDOWS.0\Explorer.EXE
C:\Program Files\IDT\WDM\sttray.exe
C:\WINDOWS.0\system32\wuauclt.exe
E:\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.google.fr/?gws_rd=ssl
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [SysTrayApp] %ProgramFiles%\IDT\WDM\sttray.exe
O4 - HKCU\..\Run: [EPSON TX100 Series] C:\WINDOWS.0\System32\spool\DRIVERS\W32X86\3\E_FATIEDP.EXE /FU "C:\WINDOWS.0\TEMP\E_S6C.tmp" /EF "HKCU"
O4 - HKUS\S-1-5-20\..\RunOnce: [JkDefrag] rundll32 advpack.dll,LaunchINFSection JKDEFRAG.INF,RunOnce,1,N (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-20\..\RunOnce: [SweetRegistry] rundll32 advpack.dll,LaunchINFSection SweetReg.inf,PerUserStub (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-18\..\RunOnce: [JkDefrag] rundll32 advpack.dll,LaunchINFSection JKDEFRAG.INF,RunOnce,1,N (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [JkDefrag] rundll32 advpack.dll,LaunchINFSection JKDEFRAG.INF,RunOnce,1,N (User 'Default user')
O4 - Startup: Notification de cadeaux MSN.lnk = C:\Documents and Settings\Administrateur\Application Data\Microsoft\Notification de cadeaux MSN\lsnfier.exe
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS.0\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS.0\Network Diagnostic\xpnetdiag.exe
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/...
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/...
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{761B44CA-F77C-48E7-931B-C702550D71DC}: NameServer = 208.67.222.222 208.67.220.220
O23 - Service: Audio Service (STacSV) - Unknown owner - j:\sound\idt\wdm\vista\STacSV.exe (file missing)
End of file - 3092 bytes
35 réponses
Analyse des échanges autour d'un log HijackThis sur Windows XP SP3 et IE7/IE8, montrant des entrées réseau et des services potentiellement indésirables et une préoccupation de sécurité. Des réponses suggèrent que le système a pu être installé par-dessus une version antérieure, proposent d'utiliser Malwarebytes et affichent des procédures pour nettoyer le poste, puis recommandent d'essayer des navigateurs alternatifs. En parallèle, certains échanges évoquent des problèmes matériels, comme un disque dur ou de la mémoire, et d'autres proposent des démarches pas à pas, incluant des liens et des tutoriels. Une des contributions montre des conseils concrets pour vérifier les sources, télécharger un outil de diagnostic et expliquer que les symptômes peuvent provenir d'un problème de configuration ou de mémoire.
    Très bien !
    On va tout de même faire la fin de désinfection (étape importante), t'es OK ?
    1. Mon ami, je vous remercie beaucoup pour tout le travail et les difficultés sont faites pour moi et mille merci merci merci a chaque personne qui m'a aidé
      1. Salut mon amis Crapoulou,
        Désolé pour l'interruption de communication entre nous, il est important que j'ai découvert que la raison pour laquelle le problèmes qui se trouvaient dans mon PC c un Problème de matériel spécial, pas de Systéme, j'ai osé et j'ai acheté un disque dur, mais en vain et j'ai pensé que je me levai pour changer la RAM remplacer la mémoire de disque dur et elle vivait La solution idéale pour tous les problèmes, la cause réelle est un ordinateur dans la corruption de la mémoire vivante et non pas dans le système d'exploitation ....
        Merci beaucoup mon ami
          Tu pourrais formater, si tu as le cd de XP.
          Fais un scan en ligne avec Bitdefender et colle le rapport
          = = = = >>> En cliquant ici <<< = = = =
          Scan à faire sous Internet Explorer.
          * En bas, à gauche de la fenêtre, clique sur BitDefender SCAN ONLINE
          * Dans la nouvelle fenêtre, clique sur I agree
          * La fenêtre change encore, clique sur Click here to scan
          * Les signatures se chargent, etc.
          Poste en réponse le rapport de scan qui se trouve ici C:\windows\bdoscan8\scanres.txt ou bien scanres.html
          1. j deja firefox et google chrome mes les 2 navigateur ne marche pas il se bloque au demarage de navigation , , dis moi si je achete un autre disque dur tu pence que ca va régler ?
            1. ok voila mon amis ;
              http://www.cijoint.fr/cjlink.php?file=cj201008/cijAowy7pL.jpg
                Après cette manipulation et redémarré l'ordinateur, toujours le message de sysfader.exe ?
                Fais moi une capture d'écran de ce sysfader.exe stp.
                Envoie-la sur cijoint après en me donnant l'adresse de consultation.
                1. slt,
                  r1 de sPéciale , le Probleme reste et le message de sysfader.exe reste et le redemarage avec la pPage bleu reste !!!!!!! me tété va eclater !!
                    Il semblerait que Sysfader provienne de Nvidia.
                    Essaye cette manipulation :
                    démarrer/parametres/panneau de config/affichages/apparences/effets et vous décochez les 4 premières boites.
                    Source.
                      Proposer une meilleure traduction
                      Difficile à comprendre tout ce message mais on fait avec !
                      Je regarderai ce soir.
                      1. fiouu !!!! salut crapoulou....pour suivre ^^
                        bonne chasse :)
                    2. Bonjour ,
                      mon amis crapoulou ,
                      Très désolé pour le dérangement, il est important que j'ai suivi les étapes mentionnées par toi, mais sans faire appel a irrité beaucoup de choses et d'information, j'ai fait plusieurs tentatives, mais sans aucun résultat significatif, vous avez le programme d'installation mentionnée à plusieurs reprises, et à la fin de l'installation me dit qu'il ya un bug dans Votre système, et j'ai nettoyé normaliser un développement a suivi les étapes mentionnées par un autre collègue, et malgré plusieurs fois sans succès, et le résultat est négatif, dites-moi ce qu'il faut faire dossier SYSFADER.EXE ne me laisse pas télécharger un programme facilement que j'ai eu un gros problème avec ce fichier Et je ne peux pas lire mes e-mails est important J'espère garder avec moi et m'aider étape par étape et j'espère que d'essayer avec moi toutes les solutions possibles, et je n'ai pas beaucoup d'informations sur la façon de réparer les systèmes Merci mon ami et je suis en attente d'une réponse . Merci beaucoup et à la fois de m'aider
                        Essaye de faire ça :
                        Affiche les fichiers et dossiers cachés ainsi que les fichiers du système :
                        - Mes documents
                        - Outils
                        - Options des dossiers
                        - Onglet « Affichage »
                        - Coche Afficher les fichiers et dossiers cachés
                        - Décoche "Masquer les fichiers protégés du système d'exploitation (recommandé)"
                        Rands-toi dans ce dossier :
                        C:\Documents and Settings\All Users\Application Data\Malwarebytes\Malwarebytes' Anti-Malware
                        Supprime ce fichier :
                        rules.ref
                        Lorsque MBAM t'affiche le message d'erreur, laisse MBAM faire les mises à jour.
                        1. Salut Crapoulou,
                          j telecharger ce vous m'avi dis mes dans la cénne de mise ajour et dans le 100% elle s'afiche cette fenetre me dis :
                          une erreur s'ese produit veuillez transmettre ce code d'erreur à notre equipe de support
                          MBAM_Error_load_database(0.5)
                          j essai plus de 06 fois mes c le mémé proble
                          en peut pas essai avec un autre logiciel ou programme ?!
                            tu le désinstalles
                            tu fais un bon nettoyage avec CCleaner
                            * tuto et téléchargement pour ccleaner : https://www.malekal.com/tutoriel-ccleaner/
                            https://www.01net.com/telecharger/windows/Utilitaire/nettoyeurs_et_installeurs/fiches/46630.html
                            https://www.ccleaner.com/ccleaner/download
                            http://perso.orange.fr/jesses/Docs/Logiciels/CCleaner.htm
                            https://www.pcastuces.com/pratique/securite/nettoyer_windows/page1.htm­page1.htm
                            ( attention de ne pas installer la Yahoo ToolBar qui ne sert à rien )
                            lors de l'utilisation de la partie nettoyage de la base de registre la première fois , prendre "Tenter de réparer" plusieurs fois en relançant CCleaner
                            et tu réinstalles MBAM
                            si tu as toujours des ennuis pour la mise à jour , télécharges ce fichier
                            http://mbam.malwarebytes.org/database/mbam-rules.exe
                            dans ce cas , double cliquer sur mbam-rules.exe pour lancer la mise à jour , et relancer MBAM
                        2. Modérateur
                          Télécharge Malwarebytes' Anti-Malware
                          - Enregistre le sur le bureau
                          - Double clique sur le fichier téléchargé pour lancer le processus d'installation
                          - Lorsqu'il te le sera demandé, mets à jour Malwarebytes anti malware
                          - Si le pare-feu demande l'autorisation de se connecter pour malwarebytes, acceptes
                          - Une fois la mise à jour terminée, ferme Malwarebytes
                          - Double-clique sur l'icône de malwarebytes pour le relancer
                          - Dans l'onglet, Recherche, probablement ouvert par défaut,
                          - Sélectionne Exécuter un examen complet
                          - Clique sur Rechercher
                          - Le scan démarre
                          - A la fin de l'analyse, un message s'affiche : L'examen s'est terminé normalement. Cliquez sur `Afficher les résultats' pour afficher tous les objets trouvés.
                          - Clique sur Ok pour poursuivre.
                          - Si des malwares ont été détectés, cliques sur Afficher les résultats
                          - Sélectionnes tout (ou laisses cochés) et cliques sur Supprimer la sélection Malwarebytes va détruire les fichiers et clés de registre et en mettre une copie dans la quarantaine.
                          - Malwarebytes va ouvrir le bloc-notes et y copier le rapport d'analyse.
                          - Rends toi dans l'onglet rapport/log
                          - Tu clique dessus pour l'afficher.
                          - Une fois affiché, cliques sur édition en haut du bloc notes, et puis sur sélectionner tout
                          - Tu recliques sur édition et puis sur copier et tu reviens sur le forum et dans ta réponse
                          - Tu clique droit dans le cadre de la réponse et coller
                          Si tu as besoin d'aide regarde ce tutorial ICI
                            Je regarderai ce soir car là j'suis au boulot.
                            Tu as installé ton Windows par-dessus un autre ?!
                            • 1
                            • 2
