Probleme carte graphique
bon voici mon problème:
je crois que ma carte graphique plante lorsque je navigue ou bien je fais qlq chose ( exel , photoshop .....)
mon ecran plante est me fais comme ça
[url=https://imageshack.com/][img=http://img705.imageshack.us/img705/2465/60048426.th.png][/url]
[url=https://imageshack.com/][img=http://img63.imageshack.us/img63/4715/sanstitrewa.th.png][/url]
et quand je joue au jeu bah le pc tout entier plante ecran noir le pc freeze ou bien parfois y a un ecran bleu et puis le pc redemarre .
svp j'ai vraiment besoin d'aide !!!!!
bon voici le rapport dxdiag
System Information
Time of this report: 12/26/2009, 13:52:43
Machine name: XPSP2-E2DAE3510
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.090206-1233)
Language: French (Regional Setting: French)
System Manufacturer: Hewlett-Packard
System Model: Compaq 610
BIOS: KBC Version 26.07
Processor: Intel(R) Core(TM)2 Duo CPU T5870 @ 2.00GHz (2 CPUs)
Memory: 2040MB RAM
Page File: 658MB used, 2751MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 965 Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 965 Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A12&SUBSYS_308A103C&REV_0C
Display Memory: 384.0 MB
Current Mode: 1366 x 768 (32 bit) (60Hz)
Monitor: Écran Plug-and-Play
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.5029 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/21/2009 12:43:54, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 1/21/2009 12:42:56, 6278560 bytes
Device Identifier: {D7B78E66-6952-11CF-2960-8010ADC2CB35}
Vendor ID: 0x8086
Device ID: 0x2A12
SubSys ID: 0x308A103C
Revision ID: 0x000C
Revision ID: 0x000C
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
PS: ce probleme m'embete bcp j'ai perdu des tonnes de heure de travaille
Safari 532.0
8 réponses
  1. bon c'est une Mobile Intel(R) 965 Express Chipset Family
    1. enficher veux dire si elle est bien fixé sur ta carte mère, au besoin tu la retires et tu la remets, à mon avis ça vient d'elle, elle me semble HS
      1. bon c'est carte integre ( j'ai un laptop compaq 610)
        on m'as déjà dit qu'il y avait des hotfix pour régler ce problème mais bon je n'ai pas réussi à en trouver !!
