Problème WSUS
J'utilise un serveur WSUS dans mon domaine mais certains PC n'envoient pas ou plus de rapport au serveur et donc ils ne téléchargent pas les mises à jour. En regardant dans le log windows update j'ai le message d'erreur suivant :
2009-03-25 11:54:18:437 1284 b24 PT WARNING: PTError: 0x8024400e
2009-03-25 11:54:18:437 1284 b24 PT WARNING: SyncUpdates_WithRecovery failed.: 0x8024400e
2009-03-25 11:54:18:437 1284 b24 PT WARNING: Sync of Updates: 0x8024400e
2009-03-25 11:54:18:437 1284 b24 PT WARNING: SyncServerUpdatesInternal failed: 0x8024400e
2009-03-25 11:54:18:437 1284 b24 Agent * WARNING: Failed to synchronize, error = 0x8024400E
2009-03-25 11:54:18:437 1284 b24 Agent * WARNING: Exit code = 0x8024400E
2009-03-25 11:54:18:437 1284 b24 Agent *********
2009-03-25 11:54:18:437 1284 b24 Agent ** END ** Agent: Finding updates [CallerId = AutomaticUpdates]
2009-03-25 11:54:18:437 1284 b24 Agent *************
2009-03-25 11:54:18:437 1284 b24 Agent WARNING: WU client failed Searching for update with error 0x8024400e
2009-03-25 11:54:18:437 1284 b80 AU >>## RESUMED ## AU: Search for updates [CallId = {106F7738-6F6F-4155-869D-431B31B8013C}]
2009-03-25 11:54:18:437 1284 b80 AU # WARNING: Search callback failed, result = 0x8024400E
2009-03-25 11:54:18:437 1284 b80 AU # WARNING: Failed to find updates with error code 8024400E
2009-03-25 11:54:18:437 1284 b80 AU #########
2009-03-25 11:54:18:437 1284 b80 AU ## END ## AU: Search for updates [CallId = {106F7738-6F6F-4155-869D-431B31B8013C}]
2009-03-25 11:54:18:437 1284 b80 AU #############
2009-03-25 11:54:18:437 1284 b80 AU AU setting next detection timeout to 2009-03-25 14:47:37
2009-03-25 11:54:18:437 1284 b80 AU Setting AU scheduled install time to 2009-03-25 12:00:00
2009-03-25 11:54:22:955 1284 b24 Report REPORT EVENT: {E3F61E5B-5716-495F-995F-DB5B36A42C28} 2009-03-25 11:54:18:437+0100 1 148 101 {00000000-0000-0000-0000-000000000000} 0 8024400e AutomaticUpdates Failure Software Synchronization Windows Update Client failed to detect with error 0x8024400e.
  1. salut,
    t'es sûre de la config des postes pour qu'ils contactent le serveur wsus ! ça se fait soit par GPO soit en changeant la config du update sur la base du registre
    1. Oui, parfaitement sur étant donné que cela fonctionnait avant et que les autres pc fonctionnent parfaitement, le problème à l'air de venir surtout quand on formate un des PC. (oui le tout en gpo)
