[JAVA] probleme d'outputstream
je cré un fichier excel avec POI et veux l'exporter.
mon code (je tiens a dire que le meme code au caractere pres marche dans une autre de mes appli) appeler par struts
package web.actions;
import java.io.IOException;
import java.io.OutputStream;
import javax.servlet.ServletException;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import org.apache.poi.hssf.usermodel.HSSFCell;
import org.apache.poi.hssf.usermodel.HSSFRow;
import org.apache.poi.hssf.usermodel.HSSFSheet;
import org.apache.poi.hssf.usermodel.HSSFWorkbook;
import org.apache.struts.action.Action;
import org.apache.struts.action.ActionForm;
import org.apache.struts.action.ActionForward;
import org.apache.struts.action.ActionMapping;
public class TestExport extends Action {
public ActionForward execute(ActionMapping mapping, ActionForm form,
HttpServletRequest request, HttpServletResponse response) throws IOException, ServletException {
response.setContentType("application/vnd.ms-excel" );
HSSFWorkbook wb = new HSSFWorkbook();
HSSFSheet sheet = wb.createSheet("new sheet" );
// Create a row and put some cells in it. Rows are 0 based.
HSSFRow row = sheet.createRow((short)0);
// Create a cell and put a value in it.
HSSFCell cell = row.createCell((short)0);
cell.setCellValue(1);
// Or do it on one line.
row.createCell((short)1).setCellValue(1.2);
row.createCell((short)2).setCellValue("This is a string" );
row.createCell((short)3).setCellValue(true);
// Write the output
OutputStream out = response.getOutputStream();
wb.write(out);
out.close();
return null;
le resultat dans IE
ÐÏࡱá;þÿ þÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿRoot EntryÿÿÿÿÿÿÿÿWorkbookÿÿÿÿÿÿÿÿÿÿÿÿÉÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ÓÌAá°Áâ\pantoine B°a=œ¯¼=h\:¾#8X@"·Ú1ÈÿArial1ÈÿArial1ÈÿArial1ÈÿArial"$"#,##0_);\("$"#,##0\)!"$"#,##0_);[Red]\("$"#,##0\)""$"#,##0.00_);\("$"#,##0.00\)'""$"#,##0.00_);[Red]\("$"#,##0.00\)7*2_("$"* #,##0_);_("$"* \(#,##0\);_("$"* "-"_);_(@_).))_(* #,##0_);_(* \(#,##0\);_(* "-"_);_(@_)?,:_("$"* #,##0.00_);_("$"* \(#,##0.00\);_("$"* "-"??_);_(@_)6+1_(* #,##0.00_);_(* \(#,##0.00\);_(* "-"??_);_(@_)àõÿ À àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ àõÿ ôÀ à À à+õÿ øÀ à)õÿ øÀ à,õÿ øÀ à*õÿ øÀ à õÿ øÀ “€ÿ“€ÿ“€ÿ“€ÿ“€ÿ“€ÿ`…| new sheetŒüThis is a stringÿ W » ÌÁ dü©ñÒMbP?_*+‚€%ÿÁƒ„¡"d,,à?à?Uð?333333ó?ý ÿ>¶@ ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ þÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿþÿÿÿ
Cela n'a pas l'air de venir de POI car on retrouve les informations du fichier excel dans le code binaire ci dessus. Donc pour moi c'est un probleme d'outputstream. Eventuellement de la fonction POI write(). je suis dessus depuis un moment et c'est assez urgent pour moi merci pour l'aide.
Firefox 3.0
9 réponses
  1. Hum je connais ce genre de soucis étant dans de la prog également.
    Bon courage alors sachant qu'il te reste que demain vu que vendredi est férié
    1. merci, moi aussi je suis content d'etre debloquer ^^ mais bon pour la dead line de cette semaine ca va etre chaud vu que ca m'a bouffé un jour et demi ^^
      1. L'environnement peut-être.
        EN tout cas content de voir que tu as finis par trouver et désolé de ne pas avoir été d'une grande aide pour le coup
        1. un de mes collegues a trouvé la solution. cela venait de "inline" dans le header qu'il fallait mettre en "attachement".
          Mais on ne comprend pas pourquoi le meme code marchait sur d'autres appli
          1. Hum ou bien sûr out .flush.
            Je n'ai aps fait attention mais teste le ça te coute rien et tu seras sûr que l'outputstream sera bien vidé dans le fichier
            1. non c'est pas ca (je suppose au fait que ct out.flush() et non wb.flush() que tu voulais dire). Mais je pense pas vraiment que ca vienne du code etant donné que si je mets ce code dans une autre appli en changeant une de mes actions struts vers celle ci, ca marche. Je pense plutot que c la config de l'appli mais j'ai deja tester de changer les librairies donc j'ai pas d'autres idees
                tente
                // Write the output
                wb.write(out);
                //Le flush te permet d'être sûr de bien tout écrire dans le fichier
                wb.flush();
                wb.close();
                out.close();
