[TESO] problème espace disque pour MAJ
L'erreur 104 s'affiche quand je veux installer la dernière mise à jour de The Elder Scrolls Online.
"DowloadError_NotEnoughSpace"
Ma version actuelle est: 1.3.6.1380697,
Elle prend 65Go d'espace disc,
J'ai 50Go de libre...
Dois-je désinstaller/réinstaller ou la solution se trouve-t-elle ailleurs? (Libérer 30Go supplémentaire?...etc...).
Voici le résultat des tests de l'assistant:
_____________________________________________________
Dxdiag test failed!
TASKLIST RESULTS
Tasklist test failed!
SYSTEM INFO RESULTS
Sysinfo test failed!
64BIT REGISTRY QUERY RESULTS
Registry listing test failed!
Launcher Settings test failed!
64BIT User Toolbar List (Browser Helper Objects) Many entries could mean Malware!
BHO listing test failed!
UAC RESULTS
UAC is DIABLED, Registry value is 0
IPCONFIG RESULTS
ipconfig test failed!
HAS ANTIVIRUS RESULTS
Antivirus test failed!
HOSTS FILE RESULTS
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
#      102.54.94.97     rhino.acme.com          # source server
#       38.25.63.10     x.acme.com              # x client host
# localhost name resolution is handled within DNS itself.
#	127.0.0.1       localhost
#	::1             localhost
NETSTAT RESULTS
Netstat test failed!
PING RESULTS
pinging: patcher.elderscrollsonline.com
pinging: launcher.bethesda.net
pinging: live.patcher.elderscrollsonline.com
pinging: liveeu.patcher.elderscrollsonline.com
pinging: pts.patcher.elderscrollsonline.com
pinging: launcher.patcher.elderscrollsonline.com
Ping test failed!
Pathping RESULTS
pathing: patcher.elderscrollsonline.com
pathing: launcher.bethesda.net
pathing: live.patcher.elderscrollsonline.com
pathing: liveeu.patcher.elderscrollsonline.com
pathing: pts.patcher.elderscrollsonline.com
pathing: launcher.patcher.elderscrollsonline.com
Pathping test failed!
VERSION
1.4
Dxdiag test failed!
SYSTEM INFO RESULTS
UAC RESULTS
UAC is ENABLED
IPCONFIG RESULTS
HOSTS FILE RESULTS
# space.
# For example:
#	::1             localhost
# unchecky_begin
# These rules were added by the Unchecky program in order to block advertising software modules
0.0.0.0 0.0.0.0 # fix for traceroute and netstat display anomaly
0.0.0.0 tracking.opencandy.com.s3.amazonaws.com
0.0.0.0 media.opencandy.com
0.0.0.0 cdn.opencandy.com
0.0.0.0 api.opencandy.com
0.0.0.0 api.recommendedsw.com
0.0.0.0 installer.betterinstaller.com
0.0.0.0 installer.filebulldog.com
0.0.0.0 d3oxtn1x3b8d7i.cloudfront.net
0.0.0.0 inno.bisrv.com
0.0.0.0 nsis.bisrv.com
0.0.0.0 cdn.file2desktop.com
0.0.0.0 cdn.goateastcach.us
0.0.0.0 cdn.guttastatdk.us
0.0.0.0 cdn.inskinmedia.com
0.0.0.0 cdn.insta.oibundles2.com
0.0.0.0 cdn.insta.playbryte.com
0.0.0.0 cdn.llogetfastcach.us
0.0.0.0 cdn.montiera.com
0.0.0.0 cdn.msdwnld.com
0.0.0.0 cdn.mypcbackup.com
0.0.0.0 cdn.ppdownload.com
0.0.0.0 cdn.riceateastcach.us
0.0.0.0 cdn.shyapotato.us
0.0.0.0 cdn.solimba.com
0.0.0.0 cdn.tuto4pc.com
0.0.0.0 cdn.appround.biz
0.0.0.0 cdn.bigspeedpro.com
0.0.0.0 cdn.bispd.com
0.0.0.0 cdn.bisrv.com
0.0.0.0 cdn.cdndp.com
0.0.0.0 cdn.download.sweetpacks.com
0.0.0.0 cdn.dpdownload.com
0.0.0.0 cdn.visualbee.net
# unchecky_end
NETSTAT RESULTS
PING RESULTS
Ping test failed!
Pathping RESULTS
VERSION
1.4
  1. Concernant mon problème j'ai trouvé solution moi même, il s'agissait effectivement d'une réponse illogique du Launcher face à mon emplacement pourtant suffisant pour la MAJ.
    Après avoir libéré 80Go il arrive maintenant à faire cette MAJ de 30Go...
    Mon sujet est résolu mais si cependant quelqu'un tombant dessus peut m'expliquer d'où vient cette requête de TESO, je l'en remercie d'avance.
    Cordialement,
    1. si il te reste 50 en espace et qu'il faut 65... La question n'a même pas à être posée. Essai de mettre 2L d'eau dans une bouteille d'1L pour voir si tu y arrives
      1. Bon bah à priori ma syntaxe est à revoir:
        Actuellement mon jeu pèse 65Go et EN PLUS de ces 65Go DÉJÀ UTILISÉS j'ai 50Go de libre.
        Concernant ma parenthèse j'ai posé la question des 80Go parce que c'est apparemment le poids actuelle du jeu (soit 15Go (<50) de plus que ma version.
        Donc la question est de savoir si il me faut 80Go d'espace libre ou si le problème vient d'ailleurs.
