Probleme de lancement minecraft
J'ai un problème des que je veux allumer minecraft je clic sur play et tout et la minecraft me met crash report s'il vous plait aidé moi voila ce que ca me met
---- Minecraft Crash Report ----
// Surprise! Haha. Well, this is awkward.
Time: 08/08/16 21:53
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at ave.ap(Minecraft.java:649)
at ave.am(Minecraft.java:486)
at ave.a(Minecraft.java:404)
at net.minecraft.client.main.Main.main(SourceFile:124)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8.8
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 22062960 bytes (21 MB) / 146542592 bytes (139 MB) up to 523501568 bytes (499 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: LabyMod-1.8.8
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Very likely; Jar signature invalidated
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU: <unknown>
    Bonjour ! ^^
    Désinstalle le et réinstalle le. Met à jour java également.
    Bonne chance
    1. Est ce que tu as des mods ou des ressources packs ?
      Si oui supprime les et reessaye et si sa continue, va dans ton .minecraft et supprime tout ( sauf si tu as des trucs a garder )
      1. A ce que je vois dans ton message d'erreur j'ai vu que tu avais des mods donc supprime les ou mets les de coter et retente
      2. j'ai labymod
      3. j'ai deja la derniere version de java
