Minecraft crash HELP !!!
J'ai déjà achetez minecraft sur un ordi portable maintenat j'aimerais y jouer sur ordi fix pour que ça lag moins Donc j'ai telecharger minecraft j'ai entré mon pseude mon mot de passe jusque là ça marche mais apres je clique sur play pui c'est à ce moment là qu'il crash
Je n'ai pas de shaders, mods, texture pack rien
Ca m'affaiche ce ci :
---- Minecraft Crash Report ----
// Why is it breaking :(
Time: 03/01/16 15:15
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:252)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bsu.am(SourceFile:523)
at bsu.aj(SourceFile:352)
at bsu.a(SourceFile:299)
at net.minecraft.client.main.Main.main(SourceFile:120)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8
Operating System: Windows 10 (x86) version 10.0
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 3956464 bytes (3 MB) / 148774912 bytes (141 MB) up to 523501568 bytes (499 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8
LWJGL: 2.9.1
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs: []
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Merci de votre aide
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
LWJGL: 2.9.1
GL Caps:
Using VBOs: No
Resource Packs: []
Merci de votre aide
je suis peut être ton sauveur, regarde cette vidéo très explicative que j'ai réaliser moi même : https://www.youtube.com/watch?v=IB2dfm__-Hg -
regarde si java est à jour
ou essaye de le réinstaller sur ton ordinateur
et regarde aussi si il y a pas 2 logiciels en conflits sa arrive souvent
