Probleme minecraft !!
---- Minecraft Crash Report ----
// Ooh. Shiny.
Time: 14/12/14 09:56
Description: Updating screen events
java.lang.IllegalStateException: failed to create a child event loop
at io.netty.util.concurrent.MultithreadEventExecutorGroup.<init>(MultithreadEventExecutorGroup.java:68)
at io.netty.channel.MultithreadEventLoopGroup.<init>(MultithreadEventLoopGroup.java:49)
at io.netty.channel.nio.NioEventLoopGroup.<init>(NioEventLoopGroup.java:61)
at io.netty.channel.nio.NioEventLoopGroup.<init>(NioEventLoopGroup.java:52)
at re.a(SourceFile:44)
at re.b(SourceFile:41)
at ur.c(SourceFile:10)
at rd.a(SourceFile:121)
at bss.a(SourceFile:1923)
at bxf.i(SourceFile:172)
at bxg.a(SourceFile:224)
at bvi.p(SourceFile:309)
at bxf.k(SourceFile:82)
at bxe.p(SourceFile:382)
at bss.r(SourceFile:1480)
at bss.at(SourceFile:880)
at bss.a(SourceFile:317)
at net.minecraft.client.main.Main.main(SourceFile:124)
Caused by: io.netty.channel.ChannelException: failed to open a new selector
at io.netty.channel.nio.NioEventLoop.openSelector(NioEventLoop.java:128)
at io.netty.channel.nio.NioEventLoop.<init>(NioEventLoop.java:120)
at io.netty.channel.nio.NioEventLoopGroup.newChild(NioEventLoopGroup.java:87)
at io.netty.util.concurrent.MultithreadEventExecutorGroup.<init>(MultithreadEventExecutorGroup.java:64)
... 17 more
Caused by: java.io.IOException: Unable to establish loopback connection
at sun.nio.ch.PipeImpl$Initializer.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.nio.ch.PipeImpl.<init>(Unknown Source)
at sun.nio.ch.SelectorProviderImpl.openPipe(Unknown Source)
at java.nio.channels.Pipe.open(Unknown Source)
at sun.nio.ch.WindowsSelectorImpl.<init>(Unknown Source)
at sun.nio.ch.WindowsSelectorProvider.openSelector(Unknown Source)
at io.netty.channel.nio.NioEventLoop.openSelector(NioEventLoop.java:126)
... 20 more
Caused by: java.net.ConnectException: Connection timed out: connect
at sun.nio.ch.Net.connect0(Native Method)
at sun.nio.ch.Net.connect(Unknown Source)
at sun.nio.ch.SocketChannelImpl.connect(Unknown Source)
at java.nio.channels.SocketChannel.open(Unknown Source)
at sun.nio.ch.PipeImpl$Initializer$LoopbackConnector.run(Unknown Source)
... 29 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Affected screen --
Details:
Screen name: bxp
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8.1
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 103378976 bytes (98 MB) / 230248448 bytes (219 MB) up to 518979584 bytes (494 MB)
JVM Flags: 2 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M
IntCache: cache: 0, tcache: 0, allocated: 13, tallocated: 95
Launched Version: 1.8.1-XRay
LWJGL: 2.9.1
OpenGL: Radeon HD 6470M GL version 4.1.10524 Compatibility Profile Context, ATI Technologies Inc.
GL Caps: Using GL 1.3 multitexturing.
Using GL 1.3 texture combiners.
Using framebuffer objects because OpenGL 3.0 is supported and separate blending is supported.
Shaders are available because OpenGL 2.1 is supported.
VBOs are available because OpenGL 1.5 is supported.
Using VBOs: No
Is Modded: Very likely; Jar signature invalidated
Type: Client (map_client.txt)
Resource Packs: []
Current Language: Français (France)
Profiler Position: N/A (disabled)
Aidez moi, svp , merci d'avance =)
  1. ---- Minecraft Crash Report ----
    // I'm sorry, Dave.
    Time: 20/12/14 18:14
    at bwd.a(SourceFile:210)
    at bxe.a(SourceFile:342)
    at bwd.a(SourceFile:350)
    at bxe.k(SourceFile:405)
    ... 17 more
    ... 20 more
    ... 29 more
    -- Head --
    Stacktrace:
    Details:
    Screen name: bxp
    Stacktrace:
    Details:
    Memory: 100852976 bytes (96 MB) / 261828608 bytes (249 MB) up to 518979584 bytes (494 MB)
    JVM Flags: 3 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -Xmx512M
    LWJGL: 2.9.1
    Using VBOs: No
    Is Modded: Probably not. Jar signature remains and client brand is untouched.
    Resource Packs: []
    Current Language: English (US)
    1. salut Florentlife ,
      j'ai essai ce que tu m'as dis mais toujours le meme probleme :x
      merci =)
      1. Salut,
        Tu as installé Xray mais es-tu sur de bien l'avoir installé ? Ce rapport d'erreur est surement du à tes mods mal installé :/
        Je te conseille :
        ==> Touche windows + touche R tape %appdata%
        ==> tu vas dans le dossier .minecraft
        ==> tu vas dans saves
        ==> tu sauvegardes tes maps
        ==> tu supprime ton fichier .minecraft
        ==> tu relance ton launcher avec une version sans mods
        Normalement ca devrais remarchez tu n'auras plus qu'a faire :
        ==> tu ouvres ton fichier minecraft
        ==> tu colles les maps sauvegardé
        ==> tu redémarre ton launcher
        Flroentlfie
