Problème launcher Minecraft
J'ai récemment acheté Minecraft, et depuis quelques jours quand je double-clique sur Minecraft.exe, j'ai un message qui me dit:
Bootstrap (v5)
Current time is Aug 26, 2014 5:53:53 PM
System.getProperty('os.name') == 'Windows 7'
System.getProperty('os.version') == '6.1'
System.getProperty('os.arch') == 'x86'
System.getProperty('java.version') == '1.7.0_67'
System.getProperty('java.vendor') == 'Oracle Corporation'
System.getProperty('sun.arch.data.model') == '32'
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma
Exception: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Recognized exception: the likely cause is a set of broken/missing root-certificates. Check your java install and perhaps reinstall it.
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 2/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 3/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 4/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 5/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 6/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 7/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 8/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 9/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 10/10)
Unable to download remote file. Check your internet connection/proxy settings.
FATAL ERROR: net.minecraft.bootstrap.FatalBootstrapError: Unable to download while being forced
at net.minecraft.bootstrap.Bootstrap.execute(Bootstrap.java:95)
at net.minecraft.bootstrap.Bootstrap.main(Bootstrap.java:381)
Please fix the error and restart.
Je suis sous Windows 7 Ultimate en 32 bits et je viens de réinstaller Java, mais rien à faire...
Merci d'avance pour votre aide,
Shelme
  1. j'ai trouvé le problème c'était Kaspersky qui était mal configuré
    1. va voi dans tes fichier
      1. De quels fichiers parles-tu? Car j'ai supprimé tous les dossiers "Sun" et "Java" après la désinstallation
