Probleme avec apache
Bonjour à toute et à tous
désolé si je me suis trompé de forum mais comme c est un peut complexe comme probleme
j ai un server dedié avec apache sous linux (ubuntu)
et chez moi j ai un pc sous windows
se que j aimerai bien faire c est spammer mon server apache pour voire le maximum de connection car j ai beaucoup de mal à le regler car il me bloque à 40 connection simultanée
voila mon fichié apache.conf
# Based upon the NCSA server configuration files originally by Rob McCool.
# Changed extensively for the Debian package by Daniel Stone <daniel@sfarc.net>
# and also by Thom May <thom@debian.org>.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation
# (available at <URL:http://httpd.apache.org/docs/current/mod/core.html#lockfile>);
# you will save yourself a lot of trouble.
ServerRoot "/etc/apache2"
# The LockFile directive sets the path to the lockfile used when Apache
# is compiled with either USE_FCNTL_SERIALIZED_ACCEPT or
# USE_FLOCK_SERIALIZED_ACCEPT. This directive should normally be left at
# its default value. The main reason for changing it is if the logs
# directory is NFS mounted, since the lockfile MUST BE STORED ON A LOCAL
# DISK. The PID of the main server process is automatically appended to
# the filename.
LockFile /var/lock/apache2/accept.lock
# PidFile: The file in which the server should record its process
# identification number when it starts.
PidFile /var/run/apache2.pid
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers ......... number of server processes to start
# MinSpareServers ...... minimum number of server processes which are kept spare
# MaxSpareServers ...... maximum number of server processes which are kept spare
# MaxClients ........... maximum number of server processes allowed to start
# MaxRequestsPerChild .. maximum number of requests a server process serves
<IfModule prefork.c>
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 20
MaxRequestsPerChild 0
</IfModule>
# pthread MPM
# StartServers ......... initial number of server processes to start
# MinSpareThreads ...... minimum number of worker threads which are kept spare
# MaxSpareThreads ...... maximum number of worker threads which are kept spare
# ThreadsPerChild ...... constant number of worker threads in each server process
<IfModule worker.c>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
</IfModule>
# perchild MPM
# NumServers ........... constant number of server processes
# StartThreads ......... initial number of worker threads in each server process
# MaxThreadsPerChild ... maximum number of worker threads in each server process
# MaxRequestsPerChild .. maximum number of connections per server process (then it dies)
<IfModule perchild.c>
NumServers 5
StartThreads 5
MinSpareThreads 5
MaxSpareThreads 10
MaxThreadsPerChild 20
AcceptMutex fcntl
</IfModule>
User www-data
Group www-data
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Global error log.
ErrorLog /var/log/apache2/error.log
# Include module configuration:
Include /etc/apache2/mods-enabled/*.load
Include /etc/apache2/mods-enabled/*.conf
# Include all the user configurations:
Include /etc/apache2/httpd.conf
# Include ports listing
Include /etc/apache2/ports.conf
# Include generic snippets of statements
Include /etc/apache2/conf.d/[^.#]*
#Let's have some Icons, shall we?
Alias /icons/ "/usr/share/apache2/icons/"
<Directory "/usr/share/apache2/icons">
Options Indexes MultiViews
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# Set up the default error docs.
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# Putting this all together, we can Internationalize error responses.
# We use Alias to redirect any /error/HTTP_<error>.html.var response to
# our collection of by-error message multi-language collections. We use
# includes to substitute the appropriate text.
# You can modify the messages' appearance without changing any of the
# default HTTP_<error>.html.var files by adding the line;
# Alias /error/include/ "/your/include/path/"
# which allows you to create your own set of files by starting with the
# /usr/local/apache2/error/include/ files and
# copying them to /your/include/path/, even on a per-VirtualHost basis.
<IfModule mod_negotiation.c>
<IfModule mod_include.c>
Alias /error/ "/usr/share/apache2/error/"
<Directory "/usr/share/apache2/error">
AllowOverride None
Options IncludesNoExec
AddOutputFilter Includes html
AddHandler type-map var
Order allow,deny
Allow from all
LanguagePriority en es de fr
ForceLanguagePriority Prefer Fallback
</Directory>
ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var
ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var
ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var
ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var
ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var
ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var
ErrorDocument 410 /error/HTTP_GONE.html.var
ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var
ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var
ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var
ErrorDocument 415 /error/HTTP_SERVICE_UNAVAILABLE.html.var
ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var
ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var
ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var
ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var
ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var
</IfModule>
</IfModule>
DirectoryIndex index.html index.cgi index.pl index.php index.xhtml
# UserDir is now a module
#UserDir public_html
#UserDir disabled root
#<Directory /home/*/public_html>
# AllowOverride FileInfo AuthConfig Limit
# Options Indexes SymLinksIfOwnerMatch IncludesNoExec
#</Directory>
AccessFileName .htaccess
<Files ~ "^\.ht">
Order allow,deny
Deny from all
</Files>
UseCanonicalName Off
TypesConfig /etc/mime.types
DefaultType text/plain
HostnameLookups Off
IndexOptions FancyIndexing VersionSort
AddIconByEncoding (CMP,/icons/compressed.gif) x-compress x-gzip
AddIconByType (TXT,/icons/text.gif) text/*
AddIconByType (IMG,/icons/image2.gif) image/*
AddIconByType (SND,/icons/sound2.gif) audio/*
AddIconByType (VID,/icons/movie.gif) video/*
# This really should be .jpg.
AddIcon /icons/binary.gif .bin .exe
AddIcon /icons/binhex.gif .hqx
AddIcon /icons/tar.gif .tar
AddIcon /icons/world2.gif .wrl .wrl.gz .vrml .vrm .iv
AddIcon /icons/compressed.gif .Z .z .tgz .gz .zip
AddIcon /icons/a.gif .ps .ai .eps
AddIcon /icons/layout.gif .html .shtml .htm .pdf
AddIcon /icons/text.gif .txt
AddIcon /icons/c.gif .c
AddIcon /icons/p.gif .pl .py
AddIcon /icons/f.gif .for
AddIcon /icons/dvi.gif .dvi
AddIcon /icons/uuencoded.gif .uu
AddIcon /icons/script.gif .conf .sh .shar .csh .ksh .tcl
AddIcon /icons/tex.gif .tex
AddIcon /icons/bomb.gif core
AddIcon /icons/back.gif ..
AddIcon /icons/hand.right.gif README
AddIcon /icons/folder.gif ^^DIRECTORY^^
AddIcon /icons/blank.gif ^^BLANKICON^^
# This is from Matty J's patch. Anyone want to make the icons?
#AddIcon /icons/dirsymlink.jpg ^^SYMDIR^^
#AddIcon /icons/symlink.jpg ^^SYMLINK^^
DefaultIcon /icons/unknown.gif
ReadmeName README.html
HeaderName HEADER.html
IndexIgnore .??* *~ *# HEADER* RCS CVS *,t
AddEncoding x-compress Z
AddEncoding x-gzip gz tgz
AddLanguage da .dk
AddLanguage nl .nl
AddLanguage en .en
AddLanguage et .et
AddLanguage fr .fr
AddLanguage de .de
AddLanguage el .el
AddLanguage it .it
AddLanguage ja .ja
AddLanguage pl .po
AddLanguage ko .ko
AddLanguage pt .pt
AddLanguage no .no
AddLanguage pt-br .pt-br
AddLanguage ltz .ltz
AddLanguage ca .ca
AddLanguage es .es
AddLanguage sv .se
AddLanguage cz .cz
AddLanguage ru .ru
AddLanguage tw .tw
AddLanguage zh-tw .tw
LanguagePriority en da nl et fr de el it ja ko no pl pt pt-br ltz ca es sv tw
AddDefaultCharset ISO-8859-1
AddCharset ISO-8859-1 .iso8859-1 .latin1 .fr
AddCharset ISO-8859-2 .iso8859-2 .latin2 .cen
AddCharset ISO-8859-3 .iso8859-3 .latin3
AddCharset ISO-8859-4 .iso8859-4 .latin4
AddCharset ISO-8859-5 .iso8859-5 .latin5 .cyr .iso-ru
AddCharset ISO-8859-6 .iso8859-6 .latin6 .arb
AddCharset ISO-8859-7 .iso8859-7 .latin7 .grk
AddCharset ISO-8859-8 .iso8859-8 .latin8 .heb
AddCharset ISO-8859-9 .iso8859-9 .latin9 .trk
AddCharset ISO-2022-JP .iso2022-jp .jis
AddCharset ISO-2022-KR .iso2022-kr .kis
AddCharset ISO-2022-CN .iso2022-cn .cis
AddCharset Big5 .Big5 .big5
# For russian, more than one charset is used (depends on client, mostly):
AddCharset WINDOWS-1251 .cp-1251 .win-1251
AddCharset CP866 .cp866
AddCharset KOI8-r .koi8-r .koi8-ru
AddCharset KOI8-ru .koi8-uk .ua
AddCharset ISO-10646-UCS-2 .ucs2
AddCharset ISO-10646-UCS-4 .ucs4
AddCharset UTF-8 .utf8
AddCharset GB2312 .gb2312 .gb
AddCharset utf-7 .utf7
AddCharset utf-8 .utf8
AddCharset big5 .big5 .b5
AddCharset EUC-TW .euc-tw
AddCharset EUC-JP .euc-jp
AddCharset EUC-KR .euc-kr
AddCharset shift_jis .sjis
#AddType application/x-httpd-php .php
#AddType application/x-httpd-php-source .phps
AddType application/x-tar .tgz
# To use CGI scripts outside /cgi-bin/:
#AddHandler cgi-script .cgi
# To use server-parsed HTML files
<FilesMatch "\.shtml(\..+)?$">
SetOutputFilter INCLUDES
</FilesMatch>
# If you wish to use server-parsed imagemap files, use
#AddHandler imap-file map
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch "RealPlayer 4\.0" force-response-1.0
BrowserMatch "Java/1\.0" force-response-1.0
BrowserMatch "JDK/1\.0" force-response-1.0
# The following directive disables redirects on non-GET requests for
# a directory that does not include the trailing slash. This fixes a
# problem with Microsoft WebFolders which does not appropriately handle
# redirects for folders with DAV methods.
BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
BrowserMatch "^WebDrive" redirect-carefully
BrowserMatch "^gnome-vfs" redirect-carefully
BrowserMatch "^WebDAVFS/1.[012]" redirect-carefully
# Allow server status reports, with the URL of http://servername/server-status
# Change the ".your_domain.com" to match your domain to enable.
#<Location /server-status>
# SetHandler server-status
# Order deny,allow
# Deny from all
# Allow from .your_domain.com
#</Location>
merci à vous de m aidé
# Allow remote server configuration reports, with the URL of
# http://servername/server-info (requires that mod_info.c be loaded).
#<Location /server-info>
# SetHandler server-info
# Order deny,allow
# Deny from all
#</Location>
# Include the virtual host configurations:
Include /etc/apache2/sites-enabled/[^.#]*
merci à vous
  1. alors j ai testé 150 à la place de 20 et toujours meme probleme
    et dans les log faut que je regarde quoi (j connais pas trop en linux)
    mais je poste un extrai
    May 26 20:15:18 ARF syslog-ng[8573]: STATS: dropped 13
    May 26 20:25:18 ARF syslog-ng[8573]: STATS: dropped 313
    May 26 20:35:18 ARF syslog-ng[8573]: STATS: dropped 760
    May 26 20:45:19 ARF syslog-ng[8573]: STATS: dropped 824
    May 26 20:55:19 ARF syslog-ng[8573]: STATS: dropped 834
    May 26 21:05:19 ARF syslog-ng[8573]: STATS: dropped 863
    May 26 21:15:19 ARF syslog-ng[8573]: STATS: dropped 865
    May 26 21:25:19 ARF syslog-ng[8573]: STATS: dropped 887
    May 26 21:35:19 ARF syslog-ng[8573]: STATS: dropped 898
    May 26 21:45:19 ARF syslog-ng[8573]: STATS: dropped 821
    May 26 21:55:19 ARF syslog-ng[8573]: STATS: dropped 822
    May 26 22:05:19 ARF syslog-ng[8573]: STATS: dropped 840
    May 26 22:15:19 ARF syslog-ng[8573]: STATS: dropped 816
    May 26 22:25:19 ARF syslog-ng[8573]: STATS: dropped 844
    May 26 22:35:20 ARF syslog-ng[8573]: STATS: dropped 746
    May 26 22:45:21 ARF syslog-ng[8573]: STATS: dropped 15
    1. <IfModule prefork.c>
      StartServers 5
      MinSpareServers 5
      MaxSpareServers 10
      MaxClients 20
      </IfModule>
      Est ce que le probléme ne vient pas de MaxClients 20
      Ou encore regarde les logs dans
      /var/log/messages
