Probleme inconu
svp aidez-moi voila mon script et toujours j'obtiens la réponse "Failed update post"
edit.php
<?php
include_once './includes/config.php';
<!DOCTYPE html>
<html dir="ltr">
<head>
<meta name="author" content="" />
<meta charset="utf-8" />
<link rel="stylesheet" href="css/style.css" type="text/css" />
<title>edit content</title>
</head>
<body>
<?php
if(isset($_GET['id'])){
$result = mysql_query("SELECT * FROM news WHERE id=".$_GET['id']);
$row = mysql_fetch_array($result, MYSQL_ASSOC);
<form method="post" action="editt.php">
<input type="text" name="title" value="<?php echo $row['title']; ?>" /><br/>
<textarea name="subject" rows="10" cols="50" ><?php echo $row['subject']; ?></textarea>
<input type="hidden" name="id" value="<?php echo $row['id']; ?>" /><br/>
<input type="submit" name="submit" value="edit" />
</form>
<?php
else {
<?php
$query = mysql_query("SELECT * FROM news ORDER BY id");
while ($row = mysql_fetch_array($query)) {
<div style="text-align: center">
<h3><?php echo $row['title']; ?></h3>
<span><a href="edit.php?id=<?php echo $row['id']; ?>">edit</a></span>
</div>
<?php
</body>
</html>
editt.php
<?php
if(isset($_POST['submit'])){
$id = htmlspecialchars(addslashes(trim($_POST['id'])));
$title = htmlspecialchars(addslashes(trim($_POST['title'])));
$subject = htmlspecialchars(addslashes(trim($_POST['subject'])));
$query = "UPDATE news SET title=".$title.", subject=".$subject." WHERE id=".$id;
$result = mysql_query($query);
if($result){
echo 'success update post';
echo '<a href="index.php">home</a>';
else {
echo 'Failed update post';
echo '<a href="edit.php">edit</a>';
edit.php
<?php
<!DOCTYPE html>
<html dir="ltr">
<head>
</head>
<body>
<?php
</form>
<?php
else {
<?php
</div>
<?php
</body>
</html>
editt.php
<?php
if($result){
else {
Ok dans ce cas en mode debug:
EN dessous de :
Mets un
var_dump($query);
Ensuite tente d'executer la réponse obtenue du var_dump dans phpmyadmin voir si cela fonctionnes.
oui j'ai vérifié dans phpmyadmin mais rien, la table est la meme.
Tout sa ce passe bien le probleme vien de ces deux ligne je sais pas comment mais le probleme est ici:
Si j'échange ces deus ligne par:
echo $id.'<br>';
echo $title.'<br>';
echo $subject.'<br>';
j'obtiens le id et title et subject édité mais lorsque je fais UPDATE dans le sql elle m'envoie "Failed". -
mysql_affected_rows -- Retourne le nombre de lignes affectées lors de la dernière opération MySQL
De plus as tu vérifié si l'enregistrement se fait bien en regardant dans la table?
