Problème Minecraft
Bonjour, j'ai un problème sur mon mac OS X depuis pas mal de temps mon Minecraft
[Version 1.5.2] Se charge et après me marque "MISSING TEXURE" et 3 Sec après marque sa :
Minecraft has crashed!
Minecraft has stopped running because it encountered a problem; Failed to start game
A full error report has been saved to /Users/herwan/Library/Application Support/minecraft/crash-reports/crash-2013-07-08_09.20.50-client.txt - Please include a copy of that file (Not this screen!) if you report this crash to anyone; without it, they will not be able to help fix the crash :(
--- BEGIN ERROR REPORT 49649618 --------
Full report at:
Please show that file to Mojang, NOT just this screen!
Generated 08/07/13 09:20
-- System Details --
Details:
Minecraft Version: 1.5.2
Operating System: Mac OS X (ppc) version 10.4.11
Java Version: 1.5.0_19, Apple Computer, Inc.
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), "Apple Computer, Inc."
Memory: 492987592 bytes (470 MB) / 530907136 bytes (506 MB) up to 1061814272 bytes (1012 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ATI Radeon 9600 XT OpenGL Engine GL version 1.5 ATI-1.4.18, ATI Technologies Inc.
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null
java.lang.RuntimeException: javax.imageio.IIOException: Can't create cache file!
at awv.c(SourceFile:100)
at awv.a(SourceFile:92)
at awv.<init>(SourceFile:56)
at net.minecraft.client.Minecraft.a(SourceFile:248)
at avv.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:507)
at java.lang.Thread.run(Thread.java:613)
Caused by: javax.imageio.IIOException: Can't create cache file!
at javax.imageio.ImageIO.createImageInputStream(ImageIO.java:333)
at javax.imageio.ImageIO.read(ImageIO.java:1321)
at awv.c(SourceFile:98)
... 6 more
Caused by: java.io.IOException: Permission denied
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.checkAndCreate(File.java:1343)
at java.io.File.createTempFile(File.java:1431)
at javax.imageio.stream.FileCacheImageInputStream.<init>(FileCacheImageInputStream.java:71)
at com.sun.imageio.spi.InputStreamImageInputStreamSpi.createInputStreamInstance(InputStreamImageInputStreamSpi.java:51)
at javax.imageio.ImageIO.createImageInputStream(ImageIO.java:329)
... 8 more
--- END ERROR REPORT e6969952 ----------
MERCI DE LAISSER VOS REPONSE D'AVANCE :)
AirOne
  1. Essaie de renommer le dossier "bin" de Minecraft dans ce dossier;
    Finder > Go > Go To Folder > type ~/Library/Application Support/minecraft.
    Essaie de repartir Minecraft et laisse-le télécharger les fichiers qui lui manque.
    (Personnellement, lorsque cela m'est arrivé j'avais tout simplement supprimer Minecraft, ensuite Java pour ensuite ré-installer Java et ensuite Minecraft. Long, mais efficace. Je ne connaissais pas la technique du renommage du dossier "bin", alors je ne l'ai jamais essayez. J'espère pour toi que sa fonctionnera ^^
    1. Merci j'avais effacer la version Java.
