Probleme su CoD
voila j'ai un pb avec le jeux call of duty!
lorsque je veux le lancer...une fenêtre apparait que m'indique une erreur fatal du jeux..et qui dit
"couldn't load default_mp.cfg. Make sure Call Of Duty is run from the correct folder"!===>je clique sur OK
et une autra fenêtre apparait..c'est la console et qui me donne ça:
CODUO MP 1.41 build win-x86 Aug 23 2004
----- FS_Startup -----
Current language: english
Current search path:
C:\Program Files\Call of Duty\uo\zz_gfm_raiders.pk3 (91 files)
C:\Program Files\Call of Duty\uo\zzz_mp_amfreville.pk3 (39 files)
C:\Program Files\Call of Duty\uo\zzzz_mp_riveredge.pk3 (6 files)
C:\Program Files\Call of Duty\uo\zzzmp_uo_Algiers.pk3 (34 files)
C:\Program Files\Call of Duty\uo\zzz-outpost.pk3 (10 files)
C:\Program Files\Call of Duty\uo\wawa_3dAim.pk3 (13 files)
C:\Program Files\Call of Duty\uo\user_Bedroom.pk3 (10 files)
C:\Program Files\Call of Duty\uo\user-ZekesMegaPiano_xXezekielXx.pk3 (55 files)
C:\Program Files\Call of Duty\uo\svr_godfrieds_rank3_uniforms_mod.pk3 (75 files)
C:\Program Files\Call of Duty\uo\Poison_XxXs_Mod.pk3 (91 files)
C:\Program Files\Call of Duty\uo\Poison_X3X_Mod.pk3 (199 files)
C:\Program Files\Call of Duty\uo\Poison_X2_Mod.pk3 (208 files)
C:\Program Files\Call of Duty\uo\platinium_war3_mod.pk3 (55 files)
C:\Program Files\Call of Duty\uo\platinium_war2_mod.pk3 (55 files)
C:\Program Files\Call of Duty\uo\platinium_NBSsniper1_mod.pk3 (55 files)
C:\Program Files\Call of Duty\uo\pakuo06.pk3 (12 files)
C:\Program Files\Call of Duty\uo\pakuo05.pk3 (3 files)
C:\Program Files\Call of Duty\uo\pakuo04.pk3 (7646 files)
C:\Program Files\Call of Duty\uo\pakuo03.pk3 (2275 files)
C:\Program Files\Call of Duty\uo\pakuo02.pk3 (790 files)
C:\Program Files\Call of Duty\uo\pakuo01.pk3 (1652 files)
C:\Program Files\Call of Duty\uo\pakuo00.pk3 (6231 files)
C:\Program Files\Call of Duty\uo\mp_hollenberg.pk3 (18 files)
C:\Program Files\Call of Duty\uo\mp_fartville_beta1.pk3 (11 files)
C:\Program Files\Call of Duty\uo\mp_el_mechili.pk3 (26 files)
C:\Program Files\Call of Duty\uo\Mogadishu.pk3 (26 files)
C:\Program Files\Call of Duty\uo\hobbiton_mtl.pk3 (42 files)
C:\Program Files\Call of Duty\uo\hh_ratskitchen.pk3 (56 files)
C:\Program Files\Call of Duty\uo\GhostTown.pk3 (8 files)
C:\Program Files\Call of Duty\uo\german_town.pk3 (31 files)
C:\Program Files\Call of Duty\uo\CHK_Homeland.pk3 (42 files)
C:\Program Files\Call of Duty\uo\Bayville.pk3 (23 files)
C:\Program Files\Call of Duty\uo\barbecue.pk3 (25 files)
C:\Program Files\Call of Duty/uo
C:\Program Files\Call of Duty\main\zzz_Rifle_RangeV1.3.1.pk3 (66 files)
C:\Program Files\Call of Duty\main\paka.pk3 (41 files)
C:\Program Files\Call of Duty\main\pak9.pk3 (149 files)
C:\Program Files\Call of Duty\main\pak8.pk3 (235 files)
C:\Program Files\Call of Duty\main\pak6.pk3 (3 files)
C:\Program Files\Call of Duty\main\pak5.pk3 (4858 files)
C:\Program Files\Call of Duty\main\pak4.pk3 (1668 files)
C:\Program Files\Call of Duty\main\pak3.pk3 (1992 files)
C:\Program Files\Call of Duty\main\pak2.pk3 (694 files)
C:\Program Files\Call of Duty\main\pak1.pk3 (2642 files)
C:\Program Files\Call of Duty\main\pak0.pk3 (12816 files)
C:\Program Files\Call of Duty/main
File Handles:
51353 files in pk3 files
----- CL_Shutdown -----
Hunk_Clear: reset the hunk ok
Couldn't load default_mp.cfg. Make sure Call of Duty is run from the correct folder.
avec la même phrase que précedement mais qui clignote en rouge!
voila je voulais savoir comment je pourrai arranger le truc svp!
merci d'avance
File Handles:
merci d'avance
bonjours je c que mon probleme n'est pas le meme mais comment autorise t'on les cheat sur cod 1 je ne comprend rien merci d'avance
Merci le pb est résolue
rebonjour tout le monde!
j'ai toujours le même problème avec CoD!
j'ai ré-installé le jeu deux fois..mais il m'affiche toujours le même message!
que puis-je faire?
help me please!! -
c'est vraiment la dernière solution!!
bon ben je crois que je vais le reinstaller!
merci -
une réinstallation s'impose
