Problème Minecraft
Bonjour à tous
Voilà ce que je vois lorsque je veux ouvrir minecraft!!!
Merci de m'aider
A bientôt Mfan,fan
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 07/11/12 09:24
- Minecraft Version: 1.4.2
- Operating System: Windows XP (x86) version 5.1
- Java Version: 1.7.0_09, Oracle Corporation
- Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
- Memory: 420949472 bytes (401 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
- JVM Flags: 2 total; -Xms512m -Xmx1024m
- AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
- LWJGL: 2.4.2
- OpenGL: ~ERROR~ NullPointerException: null
- Is Modded: Probably not
- Type: Client
- Texture Pack: ~ERROR~ NullPointerException: null
- Profiler Position: N/A (disabled)
- Vec3 Pool Size: ~ERROR~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT ce86b7d0 ----------
Merci de m'aider
A bientôt Mfan,fan
- LWJGL: 2.4.2
- Type: Client
Merci de ta réponse
Voilà ce que ça donne
Que ferais tu
je ne suis pas assez doué!!!!
---pour ------------------
Generated 07/11/12 15:59
- Java Version: 1.6.0_18, Sun Microsystems Inc.
- Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
- Memory: 466606736 bytes (444 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
- LWJGL: 2.4.2
- Type: Client
--- END ERROR REPORT 2c7e1872 -----------
dans ce cas je peux te donner mon .minecraft avec des mods déjà dessus que tu pourra enlever si tu le souhaite mais si tu veux je t'enverrai ça depuis skype sauf que je suis en vacances donc je suis sur un mac,mac étant SUPER COMPLIQUE je ne suis pas sous windows7 un problème que je tente de regler mais depuis chez moi sous windows7 je pourrai te donner tout ça sinon j'y peux riens
Tu n'est pas le seul a avoir eu ce problème content de voir que tu es en 1.4.2, il faut que tu fasse une recherche d'un fichier qui s'appelle OpenGL tu doit supprimer ce fichier et faire une force Update et moi après ça marchait, après dernière solution tu supprime ton minecraft.jar et tu faire une force Update tiens moi au courant si ça marche ou pas
perso ça avait réglé mon problème
