Probleme doctype - bloque script
j ai deux script different sur ma page, quand je met doctype ca bloque l un des deux et quand je l enleve ou remplace c est l autre qui ne fonctionne plus... helpppp
<!DOCTYPE HTML PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
<head>
<head>
<title>Menu HTML / Javascript : Aperçu</title>
<!-- nettuts -->
<!-- traduit et adapté par outils-web.com -->
<!-- chargement des feuilles de style -->
<link href="css/style.css" rel="stylesheet" type="text/css" />
<script language="JavaScript1.2" type="text/javascript">
if (screen.width==800||screen.height==600)
document.write('<body background="a.jpg">');
else if (screen.width==1024||screen.height==768)
document.write('<body background="b.jpg">');
else if (screen.width==1280||screen.height==1024)
document.write('<body background="c.jpg">');
else if (screen.width==1600||screen.height==1200)
document.write('<body background="d.jpg">');
else
</script>
</head>
<ul id="nav">
<li class="current"><a href="#">Accueil</a></li><!-- n1 -->
<li><a href="#">Projets</a><!-- n1 -->
<ul>
<li><a href="#">Scripts <img src="images/multi.png" border="0" width="15" height="15" align="absmiddle"></a><!-- n2 -->
<ul>
<li><a href="#">Javascript</a></li><!-- n3 -->
<li><a href="#">jQuery</a></li><!-- n3 -->
</ul>
</li>
<li><a href="#">Diaporamas <img src="images/multi.png" border="0" width="15" height="15" alt="" align="absmiddle"></a><!-- n2 -->
<ul>
<li><a href="#">Flash</a></li><!-- n3 -->
</ul>
</li>
<li><a href="#">Lightbox</a></li><!-- n2 -->
<li><a href="#">Kits graphiques</a></li><!-- n2 -->
</ul>
</li>
<li><a href="#">Multi-Niveaux</a>
<ul>
<li><a href="#">niveau 1 <img src="images/multi.png" border="0" width="15" height="15" alt="" align="absmiddle"></a>
<ul>
<li><a href="#">Niveau 2</a></li>
<li><a href="#">Niveau 2 <img src="images/multi.png" border="0" width="15" height="15" alt="" align="absmiddle"></a>
<ul>
<li><a href="#">Niveau 3</a></li>
</ul>
</li>
</ul>
</li>
<li><a href="#">Niveau 1</a></li>
<li><a href="#">Niveau 1 <img src="images/multi.png" border="0" width="15" height="15" alt="" align="absmiddle"></a>
<ul>
</ul>
</li>
</ul>
</li>
<li><a href="#">Liens</a></li>
<li><a href="#">Contact</a></li>
</ul>
<br /><br /><br /><br /><br /> <p> </p>
<p align="center"><br />
<!--#include file=../footer_scr.asp-->
</head>
<body>
<img name="imgalea" WIDTH="50%" HEIGHT="50%" id="imgalea" "40%" src="img5.jpg" align="center"
border="0" position="fixed" style="filter:progid:DXImageTransform.Microsoft.Fade(Duration=2.0,overlap=1.0)" >
<script language="JavaScript1.2">
var prefix='img'
var extension='jpg'
var nbimages=5
var delai=2800
var newi=0
function changeimage()
newi = newi+1
if (newi == nbimages+1) newi = 1
if(document.getElementById) o=document.getElementById('imgalea');
else if(document.images) o=document.images.imgalea;
if(o)
if(o.filters) o.filters[0].apply();
o.src=prefix+newi+'.'+extension
if(o.filters) document.getElementById('imgalea').filters[0].play();
setTimeout("changeimage()",delai)
changeimage()
</script>
</body>
</html>
merciiiii
  1. lolllll ok et comment je peux la fermer avant mon deuxieme script?
    merciii
    1. ben à la fin de la ligne DOCTYPE
      fin je code jamais selon les normes W3C, donc je met pas de doctype, mais normalement, je crois que c'est comme ça...
    2. ca ne fonctionne pas faut l ecrire comment?
      </DOCTYPE> ?
    3. ben non, fermer la balise...
      tu l'ouvre (<) mais tu ne la referme pas (>)
    4. <!doctype
      fonctionne toujours pas, suis genée de pas y arrivé suis desolé de t embeter avec des questions comme ca :)
    5. mais pourquoi tu ne la ferme pas, cette balise ? :'(
      <!DOCTYPE HTML PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" >
  2. heu... faut la fermer ta balise doctype ^^
    1. et pourquoi tu ouvres deux balises head ?
