Problème avec minecraft 1.7
Bonjour, a tousse j'ai petit problème avec minecraft 1.7 alors j'ouvre minecraft 1.7 puis je tape un pseudo puis il me mais sa ( jai aussi télécharger java )
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 04/04/12 20:48
Minecraft: Minecraft 1.2.5
OS: Windows 7 (x86) version 6.1
Java: 1.6.0_31, Sun Microsystems Inc.
VM: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
LWJGL: 2.4.2
[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:236)
at net.minecraft.client.Minecraft.run(SourceFile:657)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 19645bd2 ----------
    Problème déjà posé des millions de fois sur tous les forums imaginables. Voir ici
    Crdlmnt,
