Probleme minecraft
Salut a tous,
J'ai un probleme qui d'après certains forum est deja sujet de discussion mais je n'ai pas trouvé la solution et ca serais vraiment genial de m'aider :
J'ai la version crackée de minecraft et quand je joue en mode solo le jeu au bout d'un certain temps (souvent 5min) la fenetre s'éteint et un bloc note s'inscrit en autonome sur mon bureau se qui donne (Vous n'etes pas obliger de lire jusqu'en bas sa prend un certain temps) :
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000084c1, pid=3008, tid=1516
# JRE version: 6.0_30-b12
# Java VM: Java HotSpot(TM) Client VM (20.5-b03 mixed mode windows-x86 )
# Problematic frame:
# C 0x000084c1
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x48f68c00): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=1516, stack(0x49aa0000,0x49af0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x000084c1
Registers:
EAX=0x84cb1700, EBX=0x00000000, ECX=0x6963de08, EDX=0x00000000
ESP=0x49aef5f0, EBP=0x49aef628, ESI=0x49aef614, EDI=0x49b4673b
EIP=0x000084c1, EFLAGS=0x00010246
Top of Stack: (sp=0x49aef5f0)
0x49aef5f0: 48f68d28 49aef614 000084c1 43500000
0x49aef600: 43700000 6941d590 00000000 40174ccc
0x49aef610: 0000013e 437910c8 05187708 5f073fdc
0x49aef620: 1b1371b8 43354160 49aefcd8 00cda607
0x49aef630: 6941d590 00000000 43846673 3f0e6abe
0x49aef640: 5f073dd4 00000000 00000000 00000000
0x49aef650: 00000040 00000000 ffa86e00 40071666
0x49aef660: 59633280 bfe4c327 d6efad43 40030073
Instructions: (pc=0x000084c1)
0x000084a1:
[error occurred during error reporting (printing registers, top of stack, instructions near pc), id 0xc0000005]
Register to memory mapping:
EAX=0x84cb1700 is an unknown value
EBX=0x00000000 is an unknown value
ECX=0x6963de08 is an unknown value
EDX=0x00000000 is an unknown value
ESP=0x49aef5f0 is pointing into the stack for thread: 0x48f68c00
EBP=0x49aef628 is pointing into the stack for thread: 0x48f68c00
ESI=0x49aef614 is pointing into the stack for thread: 0x48f68c00
EDI=0x49b4673b is an unknown value
Stack: [0x49aa0000,0x49af0000], sp=0x49aef5f0, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x000084c1
J wb.a(Lia;F)V
v ~StubRoutines::call_stub
V [jvm.dll+0xfac3b]
V [jvm.dll+0x18c3a1]
V [jvm.dll+0xfade1]
V [jvm.dll+0xfae3b]
V [jvm.dll+0xb5569]
V [jvm.dll+0x118f14]
V [jvm.dll+0x140ffc]
C [msvcr71.dll+0x9565] endthreadex+0xa0
C [kernel32.dll+0xb729] GetModuleFileNameA+0x1ba
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J org.lwjgl.opengl.GL13.nglMultiTexCoord2f(IFFJ)V
J wb.a(Lia;F)V
J afv.a(Lfb;Lfn;F)V
J adt.a(FJ)V
J adt.b(F)V
J net.minecraft.client.Minecraft.x()V
J net.minecraft.client.Minecraft.run()V
j java.lang.Thread.run()V+11
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x68110400 JavaThread "File IO Thread" daemon [_thread_in_native, id=4532, stack(0x679f0000,0x67a40000)]
0x4901e400 JavaThread "Thread-15" daemon [_thread_blocked, id=2160, stack(0x5af10000,0x5af60000)]
0x49027c00 JavaThread "Thread-14" daemon [_thread_blocked, id=5484, stack(0x5aec0000,0x5af10000)]
0x48f74400 JavaThread "Thread-13" daemon [_thread_in_native, id=5268, stack(0x5ae70000,0x5aec0000)]
=>0x48f68c00 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=1516, stack(0x49aa0000,0x49af0000)]
0x490eb400 JavaThread "Timer hack thread" daemon [_thread_blocked, id=1376, stack(0x49af0000,0x49b40000)]
0x003a6c00 JavaThread "DestroyJavaVM" [_thread_blocked, id=4160, stack(0x008c0000,0x00910000)]
0x48fe4800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=2744, stack(0x49250000,0x492a0000)]
0x48fe1400 JavaThread "AWT-Shutdown" [_thread_blocked, id=4512, stack(0x491a0000,0x491f0000)]
0x48f56800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=4300, stack(0x491f0000,0x49240000)]
0x48c27400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4320, stack(0x49150000,0x491a0000)]
0x48be9800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3948, stack(0x48e30000,0x48e80000)]
0x48bda800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=5944, stack(0x48de0000,0x48e30000)]
0x48bd9000 JavaThread "Attach Listener" daemon [_thread_blocked, id=660, stack(0x48d90000,0x48de0000)]
0x48bd7c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5428, stack(0x48d40000,0x48d90000)]
0x48bca800 JavaThread "Finalizer" daemon [_thread_blocked, id=5008, stack(0x48cf0000,0x48d40000)]
0x48bc5c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=1920, stack(0x48ca0000,0x48cf0000)]
Other Threads:
0x48bc2000 VMThread [stack: 0x48c50000,0x48ca0000] [id=4268]
0x48beb400 WatcherThread [stack: 0x48e80000,0x48ed0000] [id=2892]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157376K, used 84873K [0x02990000, 0x0d450000, 0x17ee0000)
eden space 139904K, 58% used [0x02990000, 0x0790f9e8, 0x0b230000)
from space 17472K, 19% used [0x0c340000, 0x0c6a2d58, 0x0d450000)
to space 17472K, 0% used [0x0b230000, 0x0b230000, 0x0c340000)
tenured generation total 349568K, used 63442K [0x17ee0000, 0x2d440000, 0x42990000)
the space 349568K, 18% used [0x17ee0000, 0x1bcd4ab0, 0x1bcd4c00, 0x2d440000)
compacting perm gen total 14592K, used 14511K [0x42990000, 0x437d0000, 0x46990000)
the space 14592K, 99% used [0x42990000, 0x437bbc80, 0x437bbe00, 0x437d0000)
No shared spaces configured.
Code Cache [0x00910000, 0x00e48000, 0x02910000)
total_blobs=2419 nmethods=2097 adapters=255 free_code_cache=28129792 largest_free_block=8576
Dynamic libraries:
0x00400000 - 0x00425000 C:\WINDOWS\system32\javaw.exe
0x7c910000 - 0x7c9c9000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c906000 C:\WINDOWS\system32\kernel32.dll
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee3000 C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d7f0000 - 0x6da9f000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x76ae0000 - 0x76b0f000 C:\WINDOWS\system32\WINMM.dll
0x6d7a0000 - 0x6d7ac000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d320000 - 0x6d33f000 C:\Program Files\Java\jre6\bin\java.dll
0x6d7e0000 - 0x6d7ef000 C:\Program Files\Java\jre6\bin\zip.dll
0x6d000000 - 0x6d14c000 C:\Program Files\Java\jre6\bin\awt.dll
0x72f50000 - 0x72f76000 C:\WINDOWS\system32\WINSPOOL.DRV
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x76320000 - 0x7633d000 C:\WINDOWS\system32\IMM32.dll
0x774a0000 - 0x775de000 C:\WINDOWS\system32\ole32.dll
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x5b090000 - 0x5b0c8000 C:\WINDOWS\system32\uxtheme.dll
0x6d230000 - 0x6d27f000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x76960000 - 0x76a16000 C:\WINDOWS\system32\USERENV.dll
0x6fee0000 - 0x6ff35000 C:\WINDOWS\system32\netapi32.dll
0x6d600000 - 0x6d613000 C:\Program Files\Java\jre6\bin\net.dll
0x719f0000 - 0x71a07000 C:\WINDOWS\system32\WS2_32.dll
0x719e0000 - 0x719e8000 C:\WINDOWS\system32\WS2HELP.dll
0x71990000 - 0x719d0000 C:\WINDOWS\System32\mswsock.dll
0x76ed0000 - 0x76ef7000 C:\WINDOWS\system32\DNSAPI.dll
0x76d10000 - 0x76d29000 C:\WINDOWS\system32\iphlpapi.dll
0x76cf0000 - 0x76d08000 C:\WINDOWS\system32\MPRAPI.dll
0x77c90000 - 0x77cc2000 C:\WINDOWS\system32\ACTIVEDS.dll
0x76dc0000 - 0x76de5000 C:\WINDOWS\system32\adsldpc.dll
0x76f10000 - 0x76f3d000 C:\WINDOWS\system32\WLDAP32.dll
0x76ac0000 - 0x76ad1000 C:\WINDOWS\system32\ATL.DLL
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x76e30000 - 0x76e3e000 C:\WINDOWS\system32\rtutils.dll
0x71b50000 - 0x71b63000 C:\WINDOWS\system32\SAMLIB.dll
0x778e0000 - 0x779d8000 C:\WINDOWS\system32\SETUPAPI.dll
0x76f60000 - 0x76f68000 C:\WINDOWS\System32\winrnr.dll
0x76f70000 - 0x76f76000 C:\WINDOWS\system32\rasadhlp.dll
0x6d620000 - 0x6d629000 C:\Program Files\Java\jre6\bin\nio.dll
0x62e40000 - 0x62e99000 C:\WINDOWS\system32\hnetcfg.dll
0x719d0000 - 0x719d8000 C:\WINDOWS\System32\wshtcpip.dll
0x49b40000 - 0x49bab000 C:\Documents and Settings\Ryan WEPPE\Application Data\.minecraft\bin\natives\lwjgl.dll
0x5f070000 - 0x5f13c000 C:\WINDOWS\system32\OPENGL32.dll
0x6cef0000 - 0x6cf11000 C:\WINDOWS\system32\GLU32.dll
0x736b0000 - 0x736fb000 C:\WINDOWS\system32\DDRAW.dll
0x73b10000 - 0x73b16000 C:\WINDOWS\system32\DCIMAN32.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x6d350000 - 0x6d356000 C:\Program Files\Java\jre6\bin\jawt.dll
0x69000000 - 0x69667000 C:\WINDOWS\system32\atioglxx.dll
0x49490000 - 0x494a3000 C:\Documents and Settings\Ryan WEPPE\Application Data\.minecraft\bin\natives\jinput-dx8.dll
0x6d2d0000 - 0x6d30a000 C:\WINDOWS\system32\DINPUT8.dll
0x68d50000 - 0x68d59000 C:\WINDOWS\system32\HID.DLL
0x76be0000 - 0x76c0e000 C:\WINDOWS\system32\WINTRUST.dll
0x779e0000 - 0x77a77000 C:\WINDOWS\system32\CRYPT32.dll
0x77a80000 - 0x77a92000 C:\WINDOWS\system32\MSASN1.dll
0x76c40000 - 0x76c68000 C:\WINDOWS\system32\IMAGEHLP.dll
0x5ae40000 - 0x5ae52000 C:\Documents and Settings\Ryan WEPPE\Application Data\.minecraft\bin\natives\jinput-raw.dll
0x5af60000 - 0x5b089000 C:\Documents and Settings\Ryan WEPPE\Application Data\.minecraft\bin\natives\OpenAL32.dll
0x7c9d0000 - 0x7d1f5000 C:\WINDOWS\system32\SHELL32.dll
0x73e60000 - 0x73ebc000 C:\WINDOWS\system32\dsound.dll
0x72c70000 - 0x72c79000 C:\WINDOWS\system32\wdmaud.drv
0x72c60000 - 0x72c68000 C:\WINDOWS\system32\msacm32.drv
0x77bb0000 - 0x77bc5000 C:\WINDOWS\system32\MSACM32.dll
0x77ba0000 - 0x77ba7000 C:\WINDOWS\system32\midimap.dll
0x73e30000 - 0x73e34000 C:\WINDOWS\system32\KsUser.dll
0x6d780000 - 0x6d788000 C:\Program Files\Java\jre6\bin\sunmscapi.dll
0x76ba0000 - 0x76bab000 C:\WINDOWS\system32\PSAPI.DLL
VM Arguments:
jvm_args: -Xms512m -Xmx1024m -Dsun.java2d.noddraw=true -Dsun.java2d.d3d=false -Dsun.java2d.opengl=false -Dsun.java2d.pmoffscreen=false
java_command: net.minecraft.LauncherFrame
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ATI Technologies\ATI Control Panel;c:\program files\java\jre6\bin
USERNAME=Ryan WEPPE
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 13 Stepping 8, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (1 cores per cpu, 1 threads per core) family 6 model 13 stepping 8, cmov, cx8, fxsr, mmx, sse, sse2
Memory: 4k page, physical 1047856k(293928k free), swap 2679416k(473564k free)
vm_info: Java HotSpot(TM) Client VM (20.5-b03) for windows-x86 JRE (1.6.0_30-b12), built on Nov 10 2011 01:51:00 by "java_re" with MS VC++ 7.1 (VS2003)
time: Thu Dec 22 21:14:39 2011
elapsed time: 1789 seconds
OU ENCORE
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6927653f, pid=3024, tid=4212
# C [atioglxx.dll+0x27653f]
Current thread (0x49051c00): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=4212, stack(0x49920000,0x49970000)]
siginfo: ExceptionCode=0xc0000005, writing address 0x00000000
Registers:
EAX=0x00000000, EBX=0x4996f08c, ECX=0x00000012, EDX=0x00000000
ESP=0x4996dd50, EBP=0x4996ef64, ESI=0x00000000, EDI=0x00000000
EIP=0x6927653f, EFLAGS=0x00010246
Top of Stack: (sp=0x4996dd50)
0x4996dd50: 00000000 00000001 5a7be4e8 51a29040
0x4996dd60: 00000001 4dafd7e8 51a29040 00000000
0x4996dd70: 00000000 9c99d7de 82d5927f 00000000
0x4996dd80: 00000000 2453287b 8517b4a7 ad2c8d87
0x4996dd90: 589b17b0 9774b982 f8840a27 48476fd7
0x4996dda0: 12c0d13a b1a1a265 ea27e916 05469284
0x4996ddb0: 6200d4df cb68244b aa3e608f c5b13887
0x4996ddc0: 6b6c461a aa8fe0aa 6e6030ed b95844d5
Instructions: (pc=0x6927653f)
0x6927651f: 01 00 00 89 54 24 20 e8 d2 22 32 00 8b d0 89 55
0x6927652f: 0c 83 c4 04 8b fa 33 f6 33 c0 56 b9 12 00 00 00
0x6927653f: f3 ab 8b 7c 24 18 89 32 c7 42 04 00 10 00 00 89
0x6927654f: 72 08 c6 42 0c 00 c6 42 0d 00 66 89 72 14 66 89
EAX=0x00000000 is an unknown value
EBX=0x4996f08c is pointing into the stack for thread: 0x49051c00
ECX=0x00000012 is an unknown value
ESP=0x4996dd50 is pointing into the stack for thread: 0x49051c00
EBP=0x4996ef64 is pointing into the stack for thread: 0x49051c00
ESI=0x00000000 is an unknown value
EDI=0x00000000 is an unknown value
Stack: [0x49920000,0x49970000], sp=0x4996dd50, free space=311k
[error occurred during error reporting (printing native stack), id 0xc0000005]
j org.lwjgl.opengl.GL11.nglDrawArrays(IIIJ)V+0
j org.lwjgl.opengl.GL11.glDrawArrays(III)V+20
j cv.a()I+432
j eh.b(IIF)V+424
j eh.c(IIF)V+15
j eh.a(IIF)V+4
j adt.b(F)V+758
j net.minecraft.client.Minecraft.x()V+341
j net.minecraft.client.Minecraft.run()V+40
0x49588400 JavaThread "Resource download thread" daemon [_thread_in_native, id=4960, stack(0x5ee20000,0x5ee70000)]
0x49030c00 JavaThread "Thread-10" daemon [_thread_blocked, id=2268, stack(0x5ad70000,0x5adc0000)]
0x490d7800 JavaThread "Thread-9" daemon [_thread_blocked, id=4988, stack(0x5ad20000,0x5ad70000)]
0x49040400 JavaThread "Thread-8" daemon [_thread_in_native, id=3836, stack(0x5acd0000,0x5ad20000)]
=>0x49051c00 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=4212, stack(0x49920000,0x49970000)]
0x49091800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=5636, stack(0x498d0000,0x49920000)]
0x003a6c00 JavaThread "DestroyJavaVM" [_thread_blocked, id=628, stack(0x008c0000,0x00910000)]
0x48fac800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=4132, stack(0x49290000,0x492e0000)]
0x48fccc00 JavaThread "AWT-Shutdown" [_thread_blocked, id=5272, stack(0x49240000,0x49290000)]
0x48c49800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3720, stack(0x491f0000,0x49240000)]
0x48c27400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4924, stack(0x49150000,0x491a0000)]
0x48be9800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=936, stack(0x48e30000,0x48e80000)]
0x48bdac00 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=5080, stack(0x48de0000,0x48e30000)]
0x48bd9000 JavaThread "Attach Listener" daemon [_thread_blocked, id=2080, stack(0x48d90000,0x48de0000)]
0x48bd7c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4000, stack(0x48d40000,0x48d90000)]
0x48bca800 JavaThread "Finalizer" daemon [_thread_blocked, id=5972, stack(0x48cf0000,0x48d40000)]
0x48bc5c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=5976, stack(0x48ca0000,0x48cf0000)]
Other Threads:
0x48bc2000 VMThread [stack: 0x48c50000,0x48ca0000] [id=2824]
0x48beb400 WatcherThread [stack: 0x48e80000,0x48ed0000] [id=3600]
Heap
def new generation total 157248K, used 81155K [0x02990000, 0x0d430000, 0x17ee0000)
eden space 139776K, 58% used [0x02990000, 0x078d0f30, 0x0b210000)
from space 17472K, 0% used [0x0b210000, 0x0b210000, 0x0c320000)
to space 17472K, 0% used [0x0c320000, 0x0c320000, 0x0d430000)
tenured generation total 349568K, used 0K [0x17ee0000, 0x2d440000, 0x42990000)
the space 349568K, 0% used [0x17ee0000, 0x17ee0000, 0x17ee0200, 0x2d440000)
compacting perm gen total 12288K, used 12283K [0x42990000, 0x43590000, 0x46990000)
the space 12288K, 99% used [0x42990000, 0x4358ee10, 0x4358f000, 0x43590000)
Code Cache [0x00910000, 0x00a60000, 0x02910000)
total_blobs=767 nmethods=475 adapters=227 free_code_cache=32179264 largest_free_block=192
Dynamic libraries:
0x49970000 - 0x499db000 C:\Documents and Settings\Ryan WEPPE\Application Data\.minecraft\bin\natives\lwjgl.dll
0x5ab10000 - 0x5ab23000 C:\Documents and Settings\Ryan WEPPE\Application Data\.minecraft\bin\natives\jinput-dx8.dll
0x5aca0000 - 0x5acb2000 C:\Documents and Settings\Ryan WEPPE\Application Data\.minecraft\bin\natives\jinput-raw.dll
0x5adc0000 - 0x5aee9000 C:\Documents and Settings\Ryan WEPPE\Application Data\.minecraft\bin\natives\OpenAL32.dll
0x5ee70000 - 0x5eec9000 C:\WINDOWS\system32\hnetcfg.dll
VM Arguments:
USERNAME=Ryan WEPPE
OS=Windows_NT
Memory: 4k page, physical 1047856k(4460k free), swap 4092312k(5196k free)
time: Thu Dec 22 21:21:08 2011
elapsed time: 97 seconds
Merci bcp de me preciser et surtout de trouver et reparer la cause de cela .
  1. Salut , pour moi change de version de java plus jeune je pense voila a + skyloxx
