Probleme minecraft
Bonjour, j'ai un problème avec le jeu mine craft, je le lance et il se coupe quelques secondes après. Sachant qu'après j'ai ce rapport d'erreur sur mon bureau:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x51e2b517, pid=2984, tid=2288
# JRE version: 6.0_26-b03
# Java VM: Java HotSpot(TM) Client VM (20.1-b02 mixed mode windows-x86 )
# Problematic frame:
# C [atioglx1.dll+0x3fb517]
--------------- T H R E A D ---------------
Current thread (0x49165800): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=2288, stack(0x49870000,0x498c0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x000000be
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x00000000, EDX=0x498bf4f0
ESP=0x498bf4b0, EBP=0x520f8040, ESI=0x00000000, EDI=0x5212e0a8
EIP=0x51e2b517, EFLAGS=0x00010206
Top of Stack: (sp=0x498bf4b0)
0x498bf4b0: 5207e368 00000000 32323736 42364246
0x498bf4c0: 30305c7d 4f5c3030 476e6570 72505c4c
0x498bf4d0: 000000f0 00000065 00000000 00000000
0x498bf4e0: 00000000 00000000 51e4bc8b 498bf518
0x498bf4f0: 00000000 00000608 00000000 00008000
0x498bf500: 00001000 00000000 00000000 00000000
0x498bf510: 00000000 00000000 498bf474 498bf55c
0x498bf520: 498bf55c 7c91e920 7c920060 ffffffff
Instructions: (pc=0x51e2b517)
0x51e2b4f7: e8 74 f5 ff ff b8 01 00 00 00 5f 5d 5e 5b 83 c4
0x51e2b507: 30 c2 04 00 cc cc cc cc cc 83 ec 30 53 56 8b f1
0x51e2b517: 8a 86 be 00 00 00 84 c0 8b da 74 1c e8 68 07 00
0x51e2b527: 00 8a 86 be 00 00 00 84 c0 74 0d 5e b8 c8 00 00
Register to memory mapping:
EAX=0x00000000 is an unknown value
EBX=0x00000000 is an unknown value
ECX=0x00000000 is an unknown value
EDX=0x498bf4f0 is pointing into the stack for thread: 0x49165800
ESP=0x498bf4b0 is pointing into the stack for thread: 0x49165800
EBP=0x520f8040 is an unknown value
ESI=0x00000000 is an unknown value
EDI=0x5212e0a8 is an unknown value
Stack: [0x49870000,0x498c0000], sp=0x498bf4b0, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [atioglx1.dll+0x3fb517] atiPPHSN+0x356267
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.WindowsContextImplementation.nCreate(Ljava/nio/ByteBuffer;Ljava/nio/IntBuffer;Ljava/nio/ByteBuffer;)Ljava/nio/ByteBuffer;+0
j org.lwjgl.opengl.WindowsContextImplementation.create(Lorg/lwjgl/opengl/PeerInfo;Ljava/nio/IntBuffer;Ljava/nio/ByteBuffer;)Ljava/nio/ByteBuffer;+10
j org.lwjgl.opengl.Context.<init>(Lorg/lwjgl/opengl/PeerInfo;Lorg/lwjgl/opengl/ContextAttribs;Lorg/lwjgl/opengl/Context;)V+104
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribs;)V+88
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;)V+9
j org.lwjgl.opengl.Display.create()V+13
j net.minecraft.client.Minecraft.a()V+135
j net.minecraft.client.Minecraft.run()V+6
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x49165800 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=2288, stack(0x49870000,0x498c0000)]
0x49165400 JavaThread "Timer hack thread" daemon [_thread_blocked, id=1052, stack(0x49750000,0x497a0000)]
0x00876800 JavaThread "DestroyJavaVM" [_thread_blocked, id=2116, stack(0x008a0000,0x008f0000)]
0x490db800 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=860, stack(0x494b0000,0x49500000)]
0x490f0400 JavaThread "AWT-Shutdown" [_thread_blocked, id=1200, stack(0x49250000,0x492a0000)]
0x49050400 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3988, stack(0x492a0000,0x492f0000)]
0x00ec5800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=216, stack(0x48ff0000,0x49040000)]
0x00e88000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3860, stack(0x48ef0000,0x48f40000)]
0x00e79400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=3124, stack(0x48ea0000,0x48ef0000)]
0x00e77c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=2704, stack(0x01030000,0x01080000)]
0x00e76400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=876, stack(0x00fe0000,0x01030000)]
0x00e69800 JavaThread "Finalizer" daemon [_thread_blocked, id=2932, stack(0x00f90000,0x00fe0000)]
0x00e64c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=3752, stack(0x00f40000,0x00f90000)]
Other Threads:
0x00e61000 VMThread [stack: 0x00ef0000,0x00f40000] [id=1128]
0x00e8a000 WatcherThread [stack: 0x48f40000,0x48f90000] [id=1636]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157248K, used 49385K [0x030a0000, 0x0db40000, 0x185f0000)
eden space 139776K, 35% used [0x030a0000, 0x060da510, 0x0b920000)
from space 17472K, 0% used [0x0b920000, 0x0b920000, 0x0ca30000)
to space 17472K, 0% used [0x0ca30000, 0x0ca30000, 0x0db40000)
tenured generation total 349568K, used 0K [0x185f0000, 0x2db50000, 0x430a0000)
the space 349568K, 0% used [0x185f0000, 0x185f0000, 0x185f0200, 0x2db50000)
compacting perm gen total 12288K, used 8813K [0x430a0000, 0x43ca0000, 0x470a0000)
the space 12288K, 71% used [0x430a0000, 0x4393b5a8, 0x4393b600, 0x43ca0000)
No shared spaces configured.
Code Cache [0x010a0000, 0x011a8000, 0x030a0000)
total_blobs=557 nmethods=339 adapters=154 free_code_cache=32493312 largest_free_block=192
Dynamic libraries:
0x00400000 - 0x00424000 C:\WINDOWS\system32\javaw.exe
0x7c910000 - 0x7c9c9000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c906000 C:\WINDOWS\system32\kernel32.dll
0x64d00000 - 0x64d31000 C:\Program Files\Alwil Software\Avast5\snxhk.dll
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee3000 C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
0x76320000 - 0x7633d000 C:\WINDOWS\system32\IMM32.DLL
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d7f0000 - 0x6da9f000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x76ae0000 - 0x76b0f000 C:\WINDOWS\system32\WINMM.dll
0x6d7a0000 - 0x6d7ac000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d320000 - 0x6d33f000 C:\Program Files\Java\jre6\bin\java.dll
0x76ba0000 - 0x76bab000 C:\WINDOWS\system32\PSAPI.DLL
0x6d7e0000 - 0x6d7ef000 C:\Program Files\Java\jre6\bin\zip.dll
0x6d000000 - 0x6d14b000 C:\Program Files\Java\jre6\bin\awt.dll
0x72f50000 - 0x72f76000 C:\WINDOWS\system32\WINSPOOL.DRV
0x774a0000 - 0x775de000 C:\WINDOWS\system32\ole32.dll
0x58b50000 - 0x58bea000 C:\WINDOWS\system32\comctl32.dll
0x5b090000 - 0x5b0c8000 C:\WINDOWS\system32\uxtheme.dll
0x6d230000 - 0x6d27f000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x74690000 - 0x746dc000 C:\WINDOWS\system32\MSCTF.dll
0x49340000 - 0x49369000 C:\Program Files\ScanSoft\OmniPageSE2.0\ophookSE2.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x75140000 - 0x7516e000 C:\WINDOWS\system32\msctfime.ime
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x76960000 - 0x76a16000 C:\WINDOWS\system32\USERENV.dll
0x6fee0000 - 0x6ff35000 C:\WINDOWS\system32\netapi32.dll
0x6d600000 - 0x6d613000 C:\Program Files\Java\jre6\bin\net.dll
0x719f0000 - 0x71a07000 C:\WINDOWS\system32\WS2_32.dll
0x719e0000 - 0x719e8000 C:\WINDOWS\system32\WS2HELP.dll
0x71990000 - 0x719d0000 C:\WINDOWS\System32\mswsock.dll
0x76ed0000 - 0x76ef7000 C:\WINDOWS\system32\DNSAPI.dll
0x76d10000 - 0x76d29000 C:\WINDOWS\system32\iphlpapi.dll
0x76f60000 - 0x76f68000 C:\WINDOWS\System32\winrnr.dll
0x76f10000 - 0x76f3d000 C:\WINDOWS\system32\WLDAP32.dll
0x76f70000 - 0x76f76000 C:\WINDOWS\system32\rasadhlp.dll
0x6d620000 - 0x6d629000 C:\Program Files\Java\jre6\bin\nio.dll
0x498c0000 - 0x4992b000 C:\Documents and Settings\Philippe\Application Data\.minecraft\bin\natives\lwjgl.dll
0x5f070000 - 0x5f13c000 C:\WINDOWS\system32\OPENGL32.dll
0x6cef0000 - 0x6cf11000 C:\WINDOWS\system32\GLU32.dll
0x736b0000 - 0x736fb000 C:\WINDOWS\system32\DDRAW.dll
0x73b10000 - 0x73b16000 C:\WINDOWS\system32\DCIMAN32.dll
0x6d350000 - 0x6d356000 C:\Program Files\Java\jre6\bin\jawt.dll
0x69000000 - 0x694ff000 C:\WINDOWS\system32\atioglxx.dll
0x51a30000 - 0x520a8000 C:\WINDOWS\system32\atioglx1.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m -Dsun.java2d.noddraw=true -Dsun.java2d.d3d=false -Dsun.java2d.opengl=false -Dsun.java2d.pmoffscreen=false
java_command: net.minecraft.LauncherFrame
Launcher Type: SUN_STANDARD
Environment Variables:
CLASSPATH=.;C:\Program Files\QuickTime\QTSystem\QTJava.zip
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Satsuki Decoder Pack\Filtres;c:\program files\java\jre6\bin
USERNAME=Philippe
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 44 Stepping 2, AuthenticAMD
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (1 cores per cpu, 1 threads per core) family 15 model 44 stepping 2, cmov, cx8, fxsr, mmx, sse, sse2, sse3, mmxext, 3dnow, 3dnowext
Memory: 4k page, physical 523760k(101488k free), swap 1276148k(154600k free)
vm_info: Java HotSpot(TM) Client VM (20.1-b02) for windows-x86 JRE (1.6.0_26-b03), built on May 4 2011 00:50:59 by "java_re" with MS VC++ 7.1 (VS2003)
time: Sat Jun 25 19:09:07 2011
elapsed time: 11 seconds
Merci de votre aide
  1. et si sa ne marche toujours pas vous pouvez essayer une mise a jour des pilote graphique
    1. Normal Vous avez pas la version de minecraft entier vous vous avez le jeu il faut le dossier .minecraft
